Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
115 registered members (1leater, 2K2AcuraTL, aircooled, ammolab, 240_Ed, 11 invisible), 2,033 guests, and 182 spiders.
Topics286,196
Posts4,903,982
Members67,576
Most Online2,967
Mar 10th, 2019
OEM Key fobs #4711367
03/30/18 10:10 AM
03/30/18 10:10 AM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
I just picked up a 08 Lucerne and while the key fobs work well it seems like you have to push pretty hard on the buttons to get them to work so I was thinking of getting a new one but wanted to check here first for first hand reviews. The ones on Amazon say the graphics wear off fast and some don't last long or loose distance.
Has any one here had experience with the cheap ones or the OEM replacements?
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: OEM Key fobs [Re: Duffyjr] #4711377
03/30/18 10:20 AM
03/30/18 10:20 AM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
I recently replaced the Key-Fob for our 2001 Impala with a new unit I bought on E-Bay for $7.97 including shipping. Along with the new Fob the package contains a business card giving you the online address of a site that provides the programming instructions. I printed out the instructions and programming the car to work with the new Fob was easy.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: OEM Key fobs [Re: Duffyjr] #4711379
03/30/18 10:21 AM
03/30/18 10:21 AM
USA
853okg Offline
853okg  Offline
USA
I have experience with the cheap ones. I've had really good luck with KeylessRide (I think that's the name) for several vehicles including a Jeep, a VW, and an Acura. These cheap fobs work great, I've never had a problem with them. They don't seem as robustly built as the OEM, but they work, if anything, better.
Re: OEM Key fobs [Re: Duffyjr] #4711443
03/30/18 11:26 AM
03/30/18 11:26 AM
Ohio
Tdbo Offline
Tdbo  Offline
Ohio
Have you tried cleaning the contacts in them and installing new batteries?
I did that on a 10 year old OEM remote on a car that I used to have and it worked like new.
Look for info on You Tube.
2012 Honda Accord LX-P 95K
2008 Ford Mustang Pony Package Convertible 17K
2006 Honda Odyssey EX-L 77K
2003 Ford Ranger 3.0 Supercab 116K
Re: OEM Key fobs [Re: Duffyjr] #4711459
03/30/18 11:41 AM
03/30/18 11:41 AM
California
boom10ful Offline
boom10ful  Offline
California
Try taking it apart and clean the buttons. Some have soldered on buttons and you can clean those with electronics cleaner or unsolder and replace them. If they have the touch buttons just clean the gold pads and get a white paper and scrape the black pad under the squishy part on the white paper to get rid of any gloss look on the black pad.
Re: OEM Key fobs [Re: Duffyjr] #4711512
03/30/18 12:35 PM
03/30/18 12:35 PM
California
nthach Offline
nthach  Offline
California
Try a new battery and taking a spudger or alcohol soaked q-tip to the contacts to clean them up first. You can even go a step further and take apart the remote and take a pencil eraser to carefully clean the board contacts for the keypad - the buttons are actually pads, the backside has a conductive coating - if the coating ain't worn this can buy you some time.
I've never use aftermarket remotes or keyfobs - they do work but the longevity is a concern.
Re: OEM Key fobs [Re: nthach] #4711556
03/30/18 01:33 PM
03/30/18 01:33 PM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
Thanks guys, I will try cleaning them, installing some new batteries and see what happens.
Looking on ebay I have to think some of those sellers are using the term OEM a little loose when pricing is any where from $17 to $100+, but then I have never looked into purchasing these before.
Re: OEM Key fobs [Re: Duffyjr] #4711611
03/30/18 02:33 PM
03/30/18 02:33 PM
MN
14Accent Offline
14Accent  Offline
MN
Check with your local parts store. They sell replacement cases that you put your factory circuit board in. Just clean the contacts with a pencil eraser. They come with new buttons, but yes the paint wears off very quick. 6 months or so.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: OEM Key fobs [Re: 14Accent] #4711615
03/30/18 02:39 PM
03/30/18 02:39 PM
Atlanta, GA
RoGuE Offline
RoGuE  Offline
Atlanta, GA
This.
I had to do the same with my 2007 Malibu remote, likely the same one as OP. You can't usually program a new remote on these without expensive equipment. The contacts behind the button wear out and you have to press harder and harder. Though I ordered my replacement shell on eBay. Make sure you get the right one as they changed the battery mount in the remote around this time.
2007 Chevrolet Malibu
2.2L Ecotec
Re: OEM Key fobs [Re: Duffyjr] #4711623
03/30/18 02:50 PM
03/30/18 02:50 PM
California
nthach Offline
nthach  Offline
California
It's only real OEM if it came in an GM or ACDelco package and has the FCC ID of the company who supplied it. GM went with Lear or Omron.
The aftermarket ones are clones of the OEM remote - the circuitry and RF components/microcontroller are all COTS commodities, Microchip has a good chunk of that market.
Re: OEM Key fobs [Re: Duffyjr] #4712005
03/31/18 01:13 AM
03/31/18 01:13 AM
Stillwater, MN
road_rascal Offline
road_rascal  Offline
Stillwater, MN
I fixed a set of wonky Saturn key fobs using a pad from Keyless fix. Worked great and it was around $20 for 2 pads.
2012 Toyota Rav4 V6 4WD (80,000 mi)
2018 Chevy Equinox 1.5T (12,000mi)
Re: OEM Key fobs [Re: road_rascal] #4712045
03/31/18 05:07 AM
03/31/18 05:07 AM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
I may have to try these. The remotes work fine and really even better than I thought they would. I walked to the end of my drive way which is about 100 feet from the garage and all the buttons work from that distance even the remote start.
I also started noticing that the fob the previous owner most of used the most requires more pressure.
Cleaning and new batteries did not help.
I did find one on Amazon that has a 12 month/12000 mile warranty for $32. If this one turns out to not have the range I will use it in the summer and save the originals for winter when I need the remote start.
