Belt question
Ndx
IL
Hi Guys,
Ordered new belt for E90 but not sure if it's ok to use... there is visible thread at some points please see pic
Update looks like this actually normal on that specific belt
These are made by wrapping cord around a large barrel-like object of the correct diameter. The rubber is applied like a tire and cured. When done, the whole wide belt (maybe 3-4 feet wide) is slid off and then cut to the correct widths to make the belts. That is why you see the cord.
What matters? Quality and strength of the cord itself; composition, application and curing of the rubber.
