4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
95 registered members (2010Civic, agpatel, 69Torino, Agnosto, 2015_PSD, 13 invisible), 1,671 guests, and 67 spiders.
Topics286,042
Posts4,901,372
Members67,551
Most Online2,967
Mar 10th, 2019
2013 Ford C-Max Energi M1EP 18,904 Miles on oil. #4710211
03/29/18 05:58 AM
03/29/18 05:58 AM
Virginia, USA
IveBeenRued Offline OP
Virginia, USA
Html:
OIL             Mobil 1 Extended Performance 0W-20
TOP-OFF OIL	.5 quart total (used about 6-8 ounces every 7500 miles)
FILTER		Fram Ultra XG3614
SUMP CAPACTIY	4.5 QT
MILES IN USE    18.9K
MILES           38.9K
SAMPLE TAKEN    07/30/2017
LAB:		Oil Analyzers Inc.
Wear Metals (ppm):
ALUMINUM        8
CHROMIUM        0
IRON            33
COPPER          10
LEAD            0
TIN             0
CADMIUM		0
SILVER          0
VANADIUM	0
NICKEL          0
Contaminant Metals (ppm):
SILICON         13
SODIUM          64
POTASSIUM       0
Multi-Source Metals (ppm):
TITANIUM        0
MOLYBDENUM      68
ANTIMONY	0
MANGANESE       2
LITHIUM		0
BORON		45
Additive Metals (ppm):
CALCIUM         1192
MAGNESIUM       544
PHOSPHORUS      536
ZINC            665
BARIUM          0
Contaminants:
FUEL DILUTION	<0.1% Vol
SOOT		<0.1% Vol
WATER           <0.1% - FTIR
Fluid Properties:
cSt @ 100 C	8.3
TBN		3.33
OXIDATION	22 abs/cm
NITRATION	16 abs/0.1mm
For those that are unaware, this is a plug-in hybrid. I charge it up nightly and it gets 12-20 miles on a charge depending on the season. My estimate is that during this interval, the internal combustion engine powered the vehicle for about 10-11K miles. Also, given that this is a hybrid, the engine experiences quite a few start-stop cycles in the Northern Virginia traffic. Average mileage was 53.6 MPG.
OEM recommended OIC interval on synthetic blended oil is 20K/2 years for this vehicle. Within 5 miles of this oil change a fuel injector failed which caused an extremely rough start-up and misfiring. I did not want it to throw my numbers off so I changed the oil early.
2013 Ford C-Max Energi 67,500 Miles
Mobil 1 EP 0W-20|Motorcraft filter
2012 Subaru Impreza Sport Ltd 127,000 miles
Mobil 1 EP 0W-20|Fram Ultra
Re: 2013 Ford C-Max Energi M1EP 18,904 Miles on oil. [Re: IveBeenRued] #4710215
03/29/18 06:10 AM
03/29/18 06:10 AM
Florida
Artem Offline
Artem  Offline
Florida
Kinda hard to judge these hybrids since a good chunk of the miles are electric. Still awesome to see. Thanks.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 2013 Ford C-Max Energi M1EP 18,904 Miles on oil. [Re: IveBeenRued] #4710507
03/29/18 11:49 AM
03/29/18 11:49 AM
CA
CharlieBauer Offline
CA
Looks like you changed it at a good time.
EP 0w20 is a good choice. Don't think I'd like to run a semi syn.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: 2013 Ford C-Max Energi M1EP 18,904 Miles on oil. [Re: IveBeenRued] #4710594
03/29/18 01:39 PM
03/29/18 01:39 PM
Texas
4WD Offline
4WD  Offline
Texas
What is the OLM doing? … no way my (Non Energi) Fusion Hybrid lets me go any longer than my ICE cars …
Always figured Ford’s algorithm took tough duty starts into account …
Re: 2013 Ford C-Max Energi M1EP 18,904 Miles on oil. [Re: Artem] #4710620
03/29/18 02:24 PM
03/29/18 02:24 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Good point. Do you have a way to calculate/deduct miles running electric?
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: 2013 Ford C-Max Energi M1EP 18,904 Miles on oil. [Re: IveBeenRued] #4710951
03/29/18 09:23 PM
03/29/18 09:23 PM
USA
Unearthed Offline
Unearthed  Offline
USA
Is this the 2.0L hybrid? Ford specs 0w-20 synthetic blend for this engine at 20K for the plug ins and 10k for the hybrids. Everything I've seen shows these being really easy on oil. Crazy to me because of the stopping and starting. I have 4k on my new hybrid.
2015 Civic Si
2014 VW Sportwagen
2003 Suzuki vz800
Re: 2013 Ford C-Max Energi M1EP 18,904 Miles on oil. [Re: IveBeenRued] #4711124
03/30/18 04:52 AM
03/30/18 04:52 AM
Virginia, USA
Virginia, USA
4WD, the OLM on this car is not the best because it just give you a warning when you have about 500 miles remaining on the interval and then when an oil change is required. I prefer Ford's previous iteration which gave a percentage of oil life remaining. To test how long of an interval the computer was calculating I reset the OLM at the beginning of this interval and then DIDN'T reset it after I changed the oil (because it was an early change). In the end, the OLM started indicating to change my oil "soon" at 23,462 miles which puts the overall calculated interval at just shy of 24K miles. Based on this UOA, I am not sure if I'd push for a 24K OCI and I will likely NOT be relying on the OLM for my oil change intervals.
Leakyseals, Yes I do have a way to deduct the number of electric miles but unfortunately because my gauge-cluster failed during this OCI and when the dealer replaced it, my trip odometers were reset and I lost my data. Additionally, something failed within the 12V charging system which caused my battery to fail at during this interval which caused me to lose my trip odometers again, but at least I got a fresh battery out of it. (For those keeping track, that means that during an <19K interval, this vehicle had a bad fuel injector, bad 12V charging system, bad battery, and bad gauge cluster. This is all without me mentioning the brake/suspension/window/door components that also had to be replaced during this interval...this will be my last Ford.)
Unearthed, Yes, this is a 2.0L Plug-in Hybrid which is spec'd for a 20K OCI on syn blend. I have enough M1EP to keep this thing going for another 100K miles with 20K intervals so I am probably just going to stick to that.
