64849 Members
68 Forums
282363 Topics
#4709409 - 03/28/18 10:09 AM
racing oil for a bigger flat tappet
Loc: Canada
[ color:#33CC00]Hey guys thanks for letting me on here..I have been doing some research etc (please excuse my ignorance if not enough research was done) and I am just wondering about your thoughts as the Rotella T4 for a race oil? or perhaps pour in a additive to make the T4 better? Could this happen?
[color:#009900]Trucks that might see 3000RPMs max.....all you Rotella fan boys out there running it in a race motor....put a motor on a Dyno.....run it at 7500RPMs and drain the oil right away and tell me how many air bubbles you see in it compared to a real race oil....
You might get away with Rotella at the drag strip but, if you put it in a motor and go do some track days lapping sessions with it, your results will probably be different that the guys at the Drag Strip.
I am thinking of getting the Amsoil stuff but bucks are down.. I am in Canada and I assume the T4 has a good ZDDP level. http://www.canadiantire.ca/en/pdp/rotell...87930p.html#srp I am a drag race guy so the car would mostly be 6-10 second bursts (and burnout time) and idling etc to warm it up...it isn't a ultra fast car.. this is the car/YouTube channel https://www.youtube.com/watch?v=xd51XLUxZeQ[/color][/color]
Edited by BudgetRacer (03/28/18 10:11 AM)
#4709434 - 03/28/18 10:33 AM
Re: racing oil for a bigger flat tappet
[Re: BudgetRacer]
Loc: Balearic Islands , Spain
I would suggest Valvoline VR1 20W-50, many hot BBC's all over the world running it, however if the engine doesn't properly warm up i wouldn't be able to say if it's ideal for you. It's a Group II Dino with 1300ppm of Zddp and mets API SM and ACEA A3/B4, as far as Dino 20W-50s go it's probably the best one out there. That being said i have never heard of anybody having engine issues with Rotella! Then you have the Amsoil Z-ROd series which is a safe bet, i believe they have a 15W-50 or 20W-50, ofcourse full synthetic.
1975 Ford Capri II Ghia 3000 V6 1988 Ford Escort 1.6 Xr3i Convertible Finnish expat living in Spain My clothes smell like 15W-40 HDEO and 20W-50.
#4709452 - 03/28/18 10:47 AM
[Re: BudgetRacer]
Loc: SF BAY AREA, CA
Valvoline VR1 (conventional) or Royal Purple HPS (synthetic)
Edited by dogememe (03/28/18 10:48 AM)
2007 Crown Vic 4.6 ~122K: Daily Driver 2010 Escape 2.5 ~66K: Rented on Turo 1997 Suburban 5.7 ~213K: Storage Unit
7K Mile OCIs with Valvoline Advanced Synthetic/SynPower 5W-30
#4709596 - 03/28/18 12:58 PM
[Re: BudgetRacer]
I would give VR1 a try then.
#4709838 - 03/28/18 05:13 PM
[Re: BudgetRacer]
Loc: Regina, Saskatchewan, Canada
If you want the VR-1, I'm loathe to say it, but Walmart Canada does have VR-1 in 20w-50 at a very attractive price, all the time. Well, heck froze over, here I am shilling a 20w-50 for Walmart.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356 1984 F-150 4.9L - Quaker State GB 10w-30, Wix 51515
#4709850 - 03/28/18 05:22 PM
[Re: FordCapriDriver]
Loc: wv
Rotella t4 has no issues in ATV/UTV use with a wet clutch and racing conditions of 4 stroke motorcyles. Also Harleys and just about any engine that you can have fun with.
What makes your engine different?
#4709851 - 03/28/18 05:22 PM
[Re: BudgetRacer]
Loc: Alberta
This fellow was thinking about throwing in some M1 VTwin. Could chuck it in with the T4. Do don't have cat's right? T4 is not SN rated.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4708333/Re:_Mix_1_Quart_of_M1_VTwin_20#Post4708333
#4709852 - 03/28/18 05:23 PM
[Re: BudgetRacer]
Loc: Texas/International
Heard something similar wrt outboards but folks here defend HDEO as the only cure all oil …
2017 Tahoe 5.3L 4WD 2014 Fusion Hybrid 2013 Cruze RS 1.4T 2010 Canyon 5.3L 4WD
#4709911 - 03/28/18 06:28 PM
[Re: BudgetRacer]
Loc: Waco, TX
I ran Shell Rotella T-4 .. 15W-40 in my turbo drag car, it always held up great!
"The evidence demands a verdict". (Re:VOA)"it's nearly impossible to actually know the particular additives that are in there at what concentrations."
#4709945 - 03/28/18 07:01 PM
[Re: BudgetRacer]
Loc: Kalifornia Kollective
OK, this is always a conundrum. The HDEO's have the right ZDDP chemistry for your cams and lifters. The issues are related to metallurgy, hardness, and surface prep (lifter radii and curvature). If all that is OK, the oil is good enough - as long as it does not foam excessively... If there is a foaming issue, you will have to step up to Redline or some other high anti-foam oil ...
Real race motors that have to do laps have either a large sump and very effective windage tray, or are dry sump. Either will give the oil time to "settle" before returning to duty through the pump.
Adding an oversized filter will help as it also gives some additional dwell time to settle the oil. You can have bubbles outside the media, but what usually goes through the media is liquid.
So you need to describe your motor a bit more thoroughly before we can help too much ...
RPM envelope? What are the rod and main clearances? What size is the sump? How effective is your windage tray (screen, louvers, etc.) Do you tow to the track, or drive it in? Do you you have an oil cooler? How is it plumbed? Remote oil filter?
So on a drag car one of the issues is oil temp ... Usually the oil is to cold at the start and over temp at the end of the run (maybe). So monitoring sump temps is always a good idea. I like to see 150*F oil temp rolling into the water box and <300*F at the big end.
The bearing clearances determine the oil grade required. No point in running cool to cold 50 grade and trying to keep the oil pump drive happy unless you are running aluminum rods (50 is pretty much mandatory for Al rods) ...
So there is a lot of thinking we need to do. But we need to start out with the build info ...
#4709974 - 03/28/18 07:40 PM
[Re: BudgetRacer]
Loc: US-WA
[i]Trucks that might see 3000RPMs max.....all you Rotella fan boys out there running it in a race motor....put a motor on a Dyno.....run it at 7500RPMs and drain the oil right away and tell me how many air bubbles you see in it compared to a...
Who is this oblivious person? Face palm statement of the day. Fearing bubbles sounds like a demon from a kiddie cartoon, that is also afraid of glitter and kittens. Pickup tube is well below the surface of the oil. If foaming occurs, the oil will reflect light much more and will look creamy brown (or whatever the color, green, purple etc). Not a fanboy, but here is a match to the claim. At 4-15 k rpm, plus gears of a tranny the oil gets thrown around a bit more than a dino run. This is done for hours on end. Any foam (bubbles) present in the sump would have been visible on gas stops. Nope. Thanks for a laugh though.
95 Cherokee 190K DELO 10W30,XG8 07 IS250 96K FB ?w??,FULL 04 YZF-R1 18K DELO 15w40,XG7317 99 HD XL1200S 18K 76 20w50,1515 14 RX450h 30k PP 0w20,NAPAG
#4710023 - 03/28/18 08:26 PM
[Re: BudgetRacer]
Loc: Canada
Hey guys, great to hear the knowledge! I will try to answer the questions RPM envelope? around 1000-6500 rpm What are the rod and main clearances? mains 1-4=.0025 3=.003 Rods .0025 What size is the sump?it is a wet system? with around a 7 quart with a high pressure pump. It does have a trap door in the pan but no wind age tray. I use a Baldwin oil filter around 1 quart How effective is your windage tray (screen, louvers, etc.) I think it is OK I wanted to install a a windage tray that I had but it didn't fit the oil pan. The trap door does help control the oil. When I used the "molases" Pennzoil GT stuff The valvespring pressure is Seat Pressure: 135 lbs @1.875 Open Pressure: 395 lbs @1.225 Do you tow to the track, or drive it in? Do you you have an oil cooler? How is it plumbed? Remote oil filter? I tow it to the track (old style flat towing lol) no oil coolers etc.. Yes I was wondering about the foaming issues as well (it was a old post from Yellow Bullet from someone else), I think that is generally is assembly issue like the pickup distance not being proper..you would really have to buzz that thing to cause the oil to foam..like Pro stock rpm.. The Amsoil is interesting..my engine is just a basic bracket BBC so I wonder if the suggestions above would work just as well.. https://www.youtube.com/watch?v=GTOiW9A0Pvs I also found a can of EOS from around 2008 is this the good stuff?
#4710292 - 03/29/18 08:33 AM
[Re: BudgetRacer]
Loc: Alberta
By the way, I noticed you’re from Canada. T4 is on sale at Canadian tire until April 5.
