Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
95 registered members (ABerns, 2015_PSD, ArrestMeRedZ, 2009Edge, ammolab, 14 invisible), 2,089 guests, and 32 spiders.
Topics287,750
Posts4,933,819
Members67,850
Most Online2,967
Mar 10th, 2019
Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary #4708995
03/27/18 09:39 PM
03/27/18 09:39 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
Purchased this RX-8 with a dead engine. After rebuilding it at home, this is my break-in run to help flush out the block.
Car is daily driven 45 miles round trip, mostly highway, so I rack up the miles quick, changing the oil practically every 2 weeks or so. LOL
The capacity is 7 quarts but only 4 drain out during an oil change due to the engine having TWO (2) oil coolers, which hold a bunch of oil along with the oil lines, etc. I do a quick drain n fill, leaving the oil filter on to continue doing it's job. Takes me 5 mins. No big deal.
Not sure how long to run it... these engines are hard on oil and I beat the snot out of it daily. I just want it to last, since these fail due to Lubrication related wear on the Apex Seals. Any recommendations? Haha.
Previous 600 mile runs were on Valvoline 10w40 conventional from Autozone clearance.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709020
03/27/18 09:54 PM
03/27/18 09:54 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have always read to never use synthetics in Mazda rotary engines
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709021
03/27/18 09:56 PM
03/27/18 09:56 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709023
03/27/18 09:57 PM
03/27/18 09:57 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Do you run two stroke oil to help lube the combustion chamber? If I had a rotary, that would be something I'd do. With this much oil being left behind, filtration would be also a concern. Also, I'd go through Polaris for analysis to keep tabs on oxidation and things.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 108K oils, wix
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Linctex] #4709027
03/27/18 10:00 PM
03/27/18 10:00 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Funny, there is a mention of residue. A pure(er) base vs VII loaded one would be cleaner burning, wouldn't it?
The fear of synthetics never made sense to me, this is also widely feared by many motorcycle peeps, " your clutch will [insert assumption]".
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709040
03/27/18 10:11 PM
03/27/18 10:11 PM
Winnipeg MB CA
Number_35 Offline
Number_35  Offline
Winnipeg MB CA
Gorgeous car! I've heard that rotaries have greatly improved rotor apex seal life if 2-stroke oil is added to the fuel. I'm not sure what the recommended ratio would be, but I'm sure there's lots of good advice out there.
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709048
03/27/18 10:28 PM
03/27/18 10:28 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Many rotary guys add 2 stroke oil to the fuel to lube the apex seals.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Number_35] #4709056
03/27/18 10:42 PM
03/27/18 10:42 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
I actually use a Rotary specific Pre-Mix Lube added at the recommended 0.5oz per gallon of fuel to help with Apex Seal Lubrication.
I dump 7.5oz with every 13 gallon fill up.
Would love do to a standalone lube injection but those things are expensive. I figured with frequent oil changes + Pre-Lube, the engine should last a good while for me to enjoy my investment / time.
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Dyusik] #4709058
03/27/18 10:45 PM
03/27/18 10:45 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
See previous reply about using Rotary specific Pre-Lube that I add to the fuel @ 0.5oz per gallon.
You know, I thought about adding an Amsoil bypass filtration kit, to make sure the oil is super clean and free of particles... haven't pulled the trigger on it yet.
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709065
03/27/18 10:51 PM
03/27/18 10:51 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Greg24, do you see how shiny that Mazda is?
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Linctex] #4709067
03/27/18 10:51 PM
03/27/18 10:51 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
Not sure what the big deal would be. There are several guys on the RX-8 forum using Mobil 1 0w40 for a long time. They haven't posted anything negative yet.
As long as it burns clean, I don't think it matters.
I can understand if using a high end synthetic which was designed to resist break down in the Rotary engine that this could cause build up, etc to occur due to the oil not wanting to burn cleanly.
I'm sticking to conventional for now but some Rotary engine builders suggest a synthetic blend. Take the route down the middle they say. haha.
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709069
03/27/18 10:54 PM
03/27/18 10:54 PM
AZ
Killer223 Offline
Killer223  Offline
AZ
i miss my 06 Shinka, i sold mine with just over 180K on it, ran awesome and lived on supertech 10/40 and TCW3 oil in the fuel. was an amazing car.
08 6.7 cummins G56
04 5.9 cummins
95 12V NV4500.
11 ranger 4.0
18 crf450RX
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709070
03/27/18 10:57 PM
03/27/18 10:57 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Curious, what sort of oil temps does this thing see during spirited driving? With how often you change the oil, nothing wrong with conventional (other than perhaps deposits depending on heat), but I think a lot of the theories about not running synthetic in rotaries has been disproven these days. I used to be into rotaries, and the few guys I still follow on Instagram with built turbo rotaries all run synthetic. Maybe the Renesis is different?
Nice car.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: 1JZ_E46] #4709078
03/27/18 11:19 PM
03/27/18 11:19 PM
Florida
Artem Offline OP
Artem  Offline OP
Florida
Nice car.
Sizzling oil temps, probably, hence the need for two oil coolers. I haven't installed an oil temp gauge yet. I just closely monitor coolant temps via a Scan Gauge II mounted on the dash.
I'm all pro for synthetic, if I can find one that burns clean. It would obviously offer better protection, so it's a no brainer. Cost would be the only downside for me. The current 10w40 conventional I picked up on clearance costs $2 a quart. It would be hard for me to dump synthetic every few thousand miles @ $8-9 a quart.
Re: Pennzoil 10w40 - 1,200mi - 04 Mazda RX-8 Rotary [Re: Artem] #4709090
03/27/18 11:42 PM
03/27/18 11:42 PM
workbench CZ-USA KS KC
Marco620 Offline
Marco620  Offline
Run a rotery spec oil
15' Civic 1.8 i-vtec 229,500 mi Redline oil & M1 3:1/BP transmax cvt fluid & Archoil9100
Say no to drugs, union made cars and amsoil.
Son of a Navy Corpsman. Support vets!
