Originally Posted By: 69Torino
I just got back from Stinger training a couple months ago. This engine will be hard on oil.
Did they go over anything about the engine's design with respect to what oil viscosity they recommended ... ie, like bearing clearances, oil temperature, oil coolers used, etc?
Sorry so long to respond...
Oil temp is high. Mainly due to the compact nature of the engine compartment. The oil cap says 5w-30 on the GT and 0w-30 on the 2.0T, nobody really knows why. It was mutually agreed in training among Techs and instructors that Xw-40 should be used if a GT is driven any harder than to your Church functions. They do in fact use an oil cooler but it's cooled by engine coolant, not air. So the oil cooler can only do so much. And no, we are not privy to bearing clearances, they are proprietary apparently. I would think they would be similar or identical to all the Lambda V-6's, and are selective rod bearings which are only serviceable in the reman program. We do not build short blocks in a Kia house. So no reason for a tech to sweat the bearing clearances. For this I am thankful, they don't pay well even to assemble a long block.
FWIW: If it where mine (yellow Kia GT2 AWD), I'd put the same fantastic Castrol 0W-40 oil and Fram XG series filter that I run in my turbo/tuned Optima SX. I'd also keep that oil/filter changed every 5K miles and run it on Top Tier 93 octane gas.
