So I did a quick search and didn't see anything.
Does anyone have some tips on changing vertical oil filters without a mess? I've never had an issue with horizontally mounted filters but the vertical ones seem to drain all over me while I'm trying to remove them from the engine.
Also, any home made tricks on catching oil out of a plug inserted horizontally? Did the oil in my GMC Sierra last night and used our new lift for the first time. Had the catch pan in place but the oil came out so strong that it hit the passenger side ramp. I Was thinking about cutting the bottom off a 5 quart jug and using it as a catch funnel next time. Any other options?
