Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
57 registered members (anndel, AttackingMid, bbhero, Bryanccfshr, AdRock, 9 invisible), 1,000 guests, and 39 spiders.
Topics297,006
Posts4,963,343
Members67,013
Most Online2,821
Jan 21st, 2019
2005 Ford Ranger, 4cyl 2wd auto tune up questions #4708078
03/27/18 12:30 AM
03/27/18 12:30 AM
iowa
sh40674 Offline OP
sh40674  Offline OP
iowa
hello all! My step dad is looking at buying the truck in the title, 88k miles. He's just looking for something with a box to drive to work and run to home depot with besides his car (he has an old ford pickup that's pretty much done for, wants something a little newer and better on gas). The truck looks brand new. we're going to check it over tomorrow. sounds like he's pretty set on it. i told him with the mileage it more than likely has the original plugs and such, so he wanted to get everything straight if he gets it.
I don't know much about these 4 cyl fords.. what should we look for in a quick tune up for that mileage? we're just thinking plugs, wires, oil change, belt if needed, pcv, etc. I told him it might be a good idea to at least drop the trans pan and do a filter change. How are the trannys in these? I was thinking dropping the pan, doing the filter and adding the new fluid, then later this summer do a pan drain and fill again to get a little more fresh fluid in there. Will this suffice with these or do they benefit much better with a flush? what trans fluid do they take and what is recommended brand wise?
any other quirks we should know about these trucks?
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708086
03/27/18 12:48 AM
03/27/18 12:48 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
A non diesel Ranger would be pretty quirky here.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708112
03/27/18 03:00 AM
03/27/18 03:00 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I think you have a good plan. I would never do an ATF flush, do a second pan drop later on. You want Mercon 5 fluid. It's a licensed product, so any brand will do. I go for STech and do not waste my money on fancy stuff.Maybe in addition, I might flush the old brake fluid out and coolant flush if needed. I wouldn't worry about power steering flush if things are quiet. They are nice trucks and will serve him well.
The "thinking" man's friend.
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708115
03/27/18 03:48 AM
03/27/18 03:48 AM
Seattle WA
Scout1 Offline
Scout1  Offline
Seattle WA
You have a timing belt on that engine so you should probably replace that if it hasn't already been done. And change the antifreeze or like me, you'll get a heater core leak and then need to change that!
Scout1
Truth will always bear up against falsehood, as oil does above water
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: Scout1] #4708175
03/27/18 05:51 AM
03/27/18 05:51 AM
Jacksonville, FL
R_W_M Offline
R_W_M  Offline
Jacksonville, FL
The 2.3L Duratech in your 2005 has a timing chain, not belt. Solid, reliable truck. Mine has had no significant problems in nearly 130K miles; just normal maintenance.
2005 Ford Five Hundred 87 K Mi.
2005 Ford Ranger 128 K mi.
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708192
03/27/18 06:24 AM
03/27/18 06:24 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Look at the frame for rot, in the salt belt broken spring perches in the rear and frames are super common on these. Once it starts on these it spreads quicker than a house on fire.
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708216
03/27/18 07:03 AM
03/27/18 07:03 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Go on rockauto.com and buy a Dorman transmission pan that has a drain plug to make future fluid changes easier.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX - totaled
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708340
03/27/18 09:14 AM
03/27/18 09:14 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
Watchout for the ATF, change it on time. That is what killed my friend's--not changing it.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708347
03/27/18 09:20 AM
03/27/18 09:20 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
There are Ranger forums. I visit the Ranger Station. Lotsa tech info and the regulars are pretty savvy
http://therangerstation.com/forums/index.php
Thick oil is better grin2
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708390
03/27/18 10:14 AM
03/27/18 10:14 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Not a fan of Rangers, we have one at work and despite the also-lousy Frontier and Versa we have, everybody hates the Ranger, even one of our other employees who actually has an older Ranger as a personal vehicle. Pretty much everything on that truck sucks and the four-cylinder engine is even more pathetic than the one in my Escape. Transmission has already been rebuilt once at it's only got about 90k miles - and I was shocked to hear that because it shifts awfully so I assumed the trans was on its way out - nope, that's just the way it drives.
2010 Ford Escape 2.5 ~92K Miles: RP 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL in EVERYTHING!
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: Trav] #4708407
03/27/18 10:24 AM
03/27/18 10:24 AM
Virginia
glock19 Offline
glock19  Offline
Virginia
This, definitely. A buddy of mine had a 1995 Ranger that the rear spring mounts busted off.
2017 GMC Sierra SLT Z71 Crew Cab - His
2016 Toyota Highlander Limited - Hers
2002 Honda Odyssey EX - Beater
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708696
03/27/18 04:28 PM
03/27/18 04:28 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Maintenance is simple on these. Plugs/wires, fuel filter, and all fluids would be a good plan.
Coolant: G05
Transmission fluid: Mercon V
Power steering fluid: Mercon V
Rear axle: 80W90
Brake fluid: DOT3
Nothing out of the ordinary or hard to get. G05 isn't everywhere, but NAPA has it. You can also use John Deere Cool-Gard II coolant without flushing the G05, and I'm sure there is plenty of that in Iowa.
The transmissions in these can last a very long time with half decent maintenance. I believe in completely changing the fluid every 30K or so via a machine, but pan drops are fine if you keep up with them. I like exranger06's suggestion of getting the Dorman pan with a drain plug, that will save a ton of time and mess with future changes. My 2002 Ranger has 212,000 miles on its original 5R44E. It has never been out of the truck, and never been opened except to change the filter once at 148K miles. It has not been babied either aside from good maintenance...tens of thousands of miles of towing and plenty of 5000 RPM shifts. Still shifts great. The last fluid change was on a Wynns machine with Wynns universal synthetic fluid at 195K miles.
Up North the main thing to look out for is rust, especially on the rear half of the frame, but that's a suggestion I'd give for EVERY 13 year old truck in your area.
Overall, they are very solid trucks that don't need much to last a long time.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 224K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 200K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 246K miles
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708752
03/27/18 05:07 PM
03/27/18 05:07 PM
iowa
sh40674 Offline OP
sh40674  Offline OP
iowa
Thanks everyone! He had a shoulder injury this morning so hopefully it's there on Thursday or Friday to check it out.
The only pans I'm finding are for 4wd.. will these fit a 2wd?
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708761
03/27/18 05:15 PM
03/27/18 05:15 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Yes, but you need to use the 4WD filter too.
Re: 2005 Ford Ranger, 4cyl 2wd auto tune up questions [Re: sh40674] #4708781
03/27/18 05:39 PM
03/27/18 05:39 PM
iowa
sh40674 Offline OP
sh40674  Offline OP
iowa
Guessing that is for a depth thing?
