Pro line #PPL-10241, 7,900 MILES CUT OPEN
In the shop
So, a longtime friend stopped in with his new to him 09' Ford Focus 4dr sedan. 39,996 on car and its very clean. Judging by Pep Boys sticker it was due for a oil change. Put a Tough Guard 3614 i had and Magnatec 5w30 in and on.
I cut pleats from center tube and no dirt or grit in them
Please ignore second pic; its a auto extra i cut before cutting this filter. Pics of that.comin' right up
Originally Posted By: bullwinkle
That looks surprisingly GOOD for a jobber Purolator! If they all looked that good, Puros wouldn't be a problem.
I know right
. I was surprised myself
Great point and post Bullwinkle.
Very good son. Hope you had a good day today wild man. Always very good to see you on here.
Thanks Bradley:)
Quote:
....Please ignore second pic; its a auto extra i cut before cutting this filter......
Didn't see this addendum until after I looked at the pics several times, threw me off. Thought briefly perhaps PB had changed PL makers. Endcap with ridges a Wix design. However, everything else is M&H Puro. Made April 2017.
Looks like it held up and got the job done at 7.9k miles, on a jobber/value tier filter. Again, obviously not a bitog OF sub forum reader. Either that or a thrill seeker pushing limits of M&H Puro made jobber.
No indentions/cuts on the adbv either, which based on similar base plate/adbv design anecdotes is a positive.
Thanks for c&p.
What I'm learning from your autopsy's is what matters most is the oil selection, you can use pretty much any oil filter..
Yeah, we shall see what a Tough Guard 4386 looks like after 3 4k ocis very soon.
Im using a wix next with some EDGE 10W40HM/0W40 EDGE blend
That's it-use thin oil (5W30 or better), avoid short trips/get it hot, don't flog it when it's stone cold (keep delta P low). Probably explains why I've never torn one-or maybe I'm just lucky.
I think that was the filter that went on my 02 Camry.
What's even better is good oil and a good filter. Why use good oil with a bottom tier filter, or a good filter with bottom tier oil? There's a lot of oils and filters I wouldn't use for various reasons.
