Okay guys, put your thinking caps on!
Trying to get 2 17mm bolts off the S60's front control arms. I've let the bolts soak in PB Blaster and have no access to a lift or a torch. I have new bolts so no big deal if these break. It needs to have some sort of bend or flex so it can clear the sub frame's ledge and the engine, but also allow me to get some decent leverage. Lots of pulling causes the car to sway while on my stands, which is rather scary too. I am using 3 ton stands to hold the car up, but I keep the floor jacks in place as well.
I've tried:
Offset wrench with a 43oz ball pein, which allowed me to loosen the driver side.
Long handled GearWrench 120XP 3/8" ratchet with a flex head. (Too much flex at the pin; I'll break it before the bolt.)
This ratcheting device from HF: (Weaker pin than the 120XP.)
https://www.harborfreight.com/14-in-38-in-drive-long-reach-dual-flex-head-ratchet-67994.html
The area I have to work with is where the guy's index finger is. The bolts are for the front most horizontal bushing. Passenger side shown in photo.
Outer view of the bushing shown for clarity. Horizontal bushing at the right side of the photo.
I've tried:
