Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
77 registered members (aquariuscsm, alarmguy, bcossa2001, avi1777, Back40, Astro_Guy, 8 invisible), 971 guests, and 50 spiders.
Topics286,106
Posts4,902,702
Members67,563
Most Online2,967
Mar 10th, 2019
Low profile yet strong fastener remover? #4707656
03/26/18 04:05 PM
03/26/18 04:05 PM
Indiana
dlundblad Offline OP
Indiana
Okay guys, put your thinking caps on!
Trying to get 2 17mm bolts off the S60's front control arms. I've let the bolts soak in PB Blaster and have no access to a lift or a torch. I have new bolts so no big deal if these break. It needs to have some sort of bend or flex so it can clear the sub frame's ledge and the engine, but also allow me to get some decent leverage. Lots of pulling causes the car to sway while on my stands, which is rather scary too. I am using 3 ton stands to hold the car up, but I keep the floor jacks in place as well.
I've tried:
Offset wrench with a 43oz ball pein, which allowed me to loosen the driver side.
Long handled GearWrench 120XP 3/8" ratchet with a flex head. (Too much flex at the pin; I'll break it before the bolt.)
This ratcheting device from HF: (Weaker pin than the 120XP.)
https://www.harborfreight.com/14-in-38-in-drive-long-reach-dual-flex-head-ratchet-67994.html
The area I have to work with is where the guy's index finger is. The bolts are for the front most horizontal bushing. Passenger side shown in photo.
Outer view of the bushing shown for clarity. Horizontal bushing at the right side of the photo.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707673
03/26/18 04:23 PM
03/26/18 04:23 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Don't fully understand the layout, but if you're not using a 6-point socket you are sure to round off the head. If that happens it will really complicate the whole ordeal.
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707675
03/26/18 04:28 PM
03/26/18 04:28 PM
Indiana
Indiana
Here's a view of the control arm. The 2 bolts for that horizontal bushing is what's giving me heck.
In photo 1 of my OP, the bolts are about where the guys index finger is.
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707676
03/26/18 04:31 PM
03/26/18 04:31 PM
GA
drtyler Offline
drtyler  Offline
GA
Do you have room for 1/2" drive tools here?
HF has a long flex 1/2 ratchet, the extra leverage would probably do the trick, if a 1/2 drive 17mm socket and ratchet will work. Or a long breaker bar?
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707693
03/26/18 04:56 PM
03/26/18 04:56 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You may have to jack the drive train up a little. Can you get the offset wrench on it?
Re: Low profile yet strong fastener remover? [Re: Trav] #4707717
03/26/18 05:18 PM
03/26/18 05:18 PM
Indiana
Indiana
Yes. I just need more leverage.
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707726
03/26/18 05:34 PM
03/26/18 05:34 PM
Chicago
Jooksing Offline
Jooksing  Offline
Chicago
I saw this one trick using a impact gun/chisel to dig into the head a little and drive it counterclockwise.
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707745
03/26/18 05:51 PM
03/26/18 05:51 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
have you tried a 17mm box end wrench? if it fits where you need it take a second 18-19mm box end and hook it onto the opposite-open end of the 17mm to double its length as a lever. Done this trick a hundred times on rusty car bolts.
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707786
03/26/18 06:56 PM
03/26/18 06:56 PM
Trav Offline
Trav  Offline
BF dead blow hammer!
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707789
03/26/18 07:01 PM
03/26/18 07:01 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
If it will not budge with PB it is time to step up to atf/acetone.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Low profile yet strong fastener remover? [Re: dlundblad] #4707797
03/26/18 07:21 PM
03/26/18 07:21 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
Have you tried connecting a long box-end wrench to the other end of the offset wrench to increase the length? This has saved me many times in tight angles.
https://www.youtube.com/watch?v=ja7Ax45DGT8
2015 Civic LX Coupe
Re: Low profile yet strong fastener remover? [Re: Trav] #4707885
03/26/18 08:29 PM
03/26/18 08:29 PM
Indiana
Indiana
The ball pein I used was a dead blow if that matters.
Re: Low profile yet strong fastener remover? [Re: maxdustington] #4707886
03/26/18 08:30 PM
03/26/18 08:30 PM
Indiana
Indiana
Tried it.
Re: Low profile yet strong fastener remover? [Re: NoNameJoe] #4707887
03/26/18 08:30 PM
03/26/18 08:30 PM
Indiana
Indiana
This may work if I can keep it balanced.
Re: Low profile yet strong fastener remover? [Re: Kawiguy454] #4707889
03/26/18 08:31 PM
03/26/18 08:31 PM
Indiana
Indiana
It needs to be offset. The sub frame has a ledge that I need to clear.
