Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
111 registered members (AITG, A310, addyguy, 69GTX, 2009Edge, 10 invisible), 2,132 guests, and 51 spiders.
Topics296,735
Posts4,957,919
Members66,960
Most Online2,577
Jan 14th, 2019
2002 Civic LX - noise from intake resonator #4707578
03/26/18 01:35 PM
03/26/18 01:35 PM
SF Bay Area
y_p_w Offline OP
y_p_w  Offline OP
SF Bay Area
Any idea why this would happen? I heard a whine but I thought maybe transmission. But I popped the hood and the noise was clearly coming from the box that this guy took out:
Re: 2002 Civic LX - noise from intake resonator [Re: y_p_w] #4707584
03/26/18 01:45 PM
03/26/18 01:45 PM
New England
Virtus_Probi Offline
New England
Maybe it's cracked or connections to it are loose??
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: 2002 Civic LX - noise from intake resonator [Re: y_p_w] #4707655
03/26/18 03:03 PM
03/26/18 03:03 PM
South Carolina
eyeofthetiger Offline
South Carolina
Because race car?
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: 2002 Civic LX - noise from intake resonator [Re: y_p_w] #4707756
03/26/18 05:07 PM
03/26/18 05:07 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
The transmission is directly under that thing. Did you remove the resonator? Did the noise go away?
I removed my resonator once then accidentally dropped it and broke off one of the mounts, leaving a hole that I can fit a few fingers in, but it doesn't really sound any different.
Maybe you have a leaf or some other trash in there.
Re: 2002 Civic LX - noise from intake resonator [Re: y_p_w] #4707954
03/26/18 08:50 PM
03/26/18 08:50 PM
South Carolina
South Carolina
Just take the resonator all the way off and inspect it. It could contain the carcass of some rodent that picked the wrong place to build a nest. Drive the car without the box and see how it sounds.
Re: 2002 Civic LX - noise from intake resonator [Re: eyeofthetiger] #4708054
03/26/18 11:28 PM
03/26/18 11:28 PM
SF Bay Area
y_p_w Offline OP
y_p_w  Offline OP
SF Bay Area
I should probably do that first. It sounds kind of gross if there used to be something alive in there.
My wife thinks that the engine is dying, but just at idle I could hear the noise coming straight from the resonator. I still don't know exactly what it does. I know that it's the air intake, but I've had other cars where the resonator (which I still don't quite understand) was built into the air filter box/case.
OK I looked up what it does. I don't know much about pressure wave harmonics, but apparently it's needed for performance reasons.
Re: 2002 Civic LX - noise from intake resonator [Re: y_p_w] #4708364
03/27/18 09:45 AM
03/27/18 09:45 AM
SF Bay Area
y_p_w Offline OP
y_p_w  Offline OP
SF Bay Area
Iím not near home right now and my wife calls me and tells me that itís not working. The car is safely on the side of the road now.
I guess whatever was loose in there plugged it up and itís not taking in air.
Re: 2002 Civic LX - noise from intake resonator [Re: y_p_w] #4977574
01/12/19 11:40 PM
01/12/19 11:40 PM
SF Bay Area
y_p_w Offline OP
y_p_w  Offline OP
SF Bay Area
Follow up. Turns out it was the transmission. I was able to drive it home the next day. Later when I tried to drive it just a little bit it would move a bit and then refuse to move. So it just sat there until I could figure out a better plan.
I brought it to a mechanic I know to have an evaluation. When I checked with my code reader there was no active trouble code about a month ago. It's also been sitting on my driveway for months with maybe one attempt to charge the battery (used an extension cord) but it was pretty dead. Once I connected the charger the alarm goes off, and the remote seems to have a dead battery too. So I'm off to an auto parts store to buy an overpriced A27 so the neighbors don't complain, and I wasn't sure if I could even start it without turning off the alarm. So maybe 45 minutes of charging at 12 A and I can easily start it.
But I basically had to limp that thing about 3 miles. I could get it to move, but eventually it would stop moving and the service engine light went on. The engine seemed fine, but it just won't move. I'd let it cool for a couple of minutes, and I could limp it maybe 3 more blocks at a time.
I get it to him, he notices it barely moves, and he gets his code reader (a really nice one better than mine that only gives code number). It said something about "improper gear ratio". He says "You need a transmission". Asked him what he suggested, and it was to get a rebuilt or used transmission in there. Recommended rebuilt though for a longer warranty and I suppose because they're actually inspected and have worn parts replaced. A local engine/transmission specialist had a rebuilt for $1050+tax, and the mechanic charged about $500 for labor. Other than this and some cosmetic damage the car runs fine. So we've got the car back.
