Misbehaving Mechanic Caught On Dash Cam
by BlueOvalFitter. 04/18/19 02:38 PM
What oil for my newly acquired Samurai
by ad244. 04/18/19 02:37 PM
Check your Oil (SMA YouTube Video)
by javacontour. 04/18/19 02:37 PM
Wearing Hiking Shoes Full-Time
by oilpsi2high. 04/18/19 01:56 PM
Apply brakes, steering wheel shakes
by grampi. 04/18/19 01:35 PM
F150 Exhaust whistle
by Redright9. 04/18/19 01:20 PM
Boy, what a marketing win!
by SubieRubyRoo. 04/18/19 12:06 PM
auto shipping question for a friend
by earlyre. 04/18/19 11:02 AM
O Reilly motor oil
by porvdub. 04/18/19 10:59 AM
GM & JEEP O/S OIL FILTERS
by adrenalin89. 04/18/19 10:56 AM
Accord AC Issue
by maverickfhs. 04/18/19 10:54 AM
Transatlantic Communication Lines and the story
by StevieC. 04/18/19 10:41 AM
Crazy Neighbor....part deux
by Schmoe. 04/18/19 10:15 AM
Troubles with Mint Mobile formerly Miny Sim
by daves66nova. 04/18/19 09:40 AM
Marine Engine Oil
by Brian553. 04/18/19 09:35 AM
Steering gear rattle video
by LeakySeals. 04/18/19 08:52 AM
Ran out of 50:1 fuel mix
by StillLearning. 04/18/19 08:42 AM
Kenzitoz, White12Boss302, terryj, Hadryk, djcavein
67844 Registered Users
124 registered members (55hambone, 1978elcamino, aquariuscsm, addyguy, ad244, 11 invisible), 2,163 guests, and 30 spiders.
Topics287,700
Posts4,932,598
Members67,844
Most Online2,967
Mar 10th, 2019
91 dodge Dakota 3.9 overcharging #4707564
03/26/18 02:25 PM
03/26/18 02:25 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
Hey everyone. A fellow co worker of my wifeís has a Dakota that has an overcharge condition. They want me to take a look at it . So Iím shopping for info before I dig into it. I havenít worked on an old Dakota in quite a long time. I do believe a shop put a new alternator on it. I just wanted to clarify isnít the voltage regulator built in to the ecm on them? If so wouldnít it be very likely that would be the issue? What else to look for and check? I appreciate all the advice and input.
2014 dodge dart GT
1995 Dodge ram 1500
Re: 91 dodge Dakota 3.9 overcharging [Re: ram_man] #4707651
03/26/18 04:00 PM
03/26/18 04:00 PM
USA
NHGUY Offline
NHGUY  Offline
USA
Built into the computer.
Re: 91 dodge Dakota 3.9 overcharging [Re: ram_man] #4707679
03/26/18 04:33 PM
03/26/18 04:33 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
There is a way to add an external regular.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 91 dodge Dakota 3.9 overcharging [Re: ram_man] #4707705
03/26/18 05:08 PM
03/26/18 05:08 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
It's in the ECM. But do a proper diagnosis. On mine when it was overcharging the problem was still with the alternator.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: 91 dodge Dakota 3.9 overcharging [Re: Chris142] #4707724
03/26/18 05:33 PM
03/26/18 05:33 PM
ME
eljefino Offline
eljefino  Offline
ME
This. They're $10 on ebay.
Also check the battery temp sensor under the tray, grounds, and there's an easily corroded main power line junction right under the fusebox on the drivers side fender.
Re: 91 dodge Dakota 3.9 overcharging [Re: ram_man] #4707730
03/26/18 05:37 PM
03/26/18 05:37 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
The guy said it had one on the fire wall. I assume that would be the one they added ?
If so how does that effect the pcm?
2014 dodge dart GT
1995 Dodge ram 1500
Re: 91 dodge Dakota 3.9 overcharging [Re: ram_man] #4707747
03/26/18 05:55 PM
03/26/18 05:55 PM
Chris142 Offline
Chris142  Offline
Oh then its not controlled by the ecm.
Re: 91 dodge Dakota 3.9 overcharging [Re: ram_man] #4707767
03/26/18 06:33 PM
03/26/18 06:33 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
Ok so that should be simple enough to figure out. I wonder if he has it grounded well.
Also he said he had the transmission rebuilt 3 days ago and itís slipping. The shop said it could be the check ball in the transmission line starving it for fluid. I suppose that could happen any thoughts on that? Is that transmission at all computer controlled? I ask because high voltage could play apart in causing issues if it is. Although I thought those had a 42rh correct?
My initial thought was take the transmission back to the guy that did the work. He said when it was slipping climbing a hill he shut it off and then re fired it and it then went ok and quit slipping.
2014 dodge dart GT
1995 Dodge ram 1500
