How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
111 registered members (Aichiguy, alcyon, AdditiveOCD, 53' Stude, 2010Civic, 14 invisible), 2,165 guests, and 64 spiders.
Topics286,352
Posts4,906,940
Members67,608
Most Online2,967
Mar 10th, 2019
Acura TSX Splash Guard Removal #4707408
03/26/18 11:10 AM
03/26/18 11:10 AM
MURICA
maverickfhs Offline OP
MURICA
Alright, maybe a strange question but for ATF D&F, I removed splash guard and can see a few pushpins missing, which I can use zip ties and what not.
My question is, for easier oil and ATF changes what if I keep it removed? Would it impact anything like more rust, debris or any deterioration related to no splash guard underneath?
Any advice or thoughts? If any negative impact, I'll just put it back on thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707426
03/26/18 11:20 AM
03/26/18 11:20 AM
SW Ontario Canada
KGMtech Online happy
KGMtech  Online Happy
SW Ontario Canada
These are not something you want to leave off. The water, grit, snow, leaves, road rodents will foul up the area if the covers are left off.
The pushpins to secure it are pretty cheap, go to your dealer or a good bodyshop and they'll set you up with the correct pieces.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707439
03/26/18 11:28 AM
03/26/18 11:28 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I agree. Keep it installed, and with the correct hardware.
"Zed's dead baby, Zed's dead."
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707440
03/26/18 11:28 AM
03/26/18 11:28 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Double post. Sorry
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707445
03/26/18 11:37 AM
03/26/18 11:37 AM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Not critical to anything, but it does keep the underside a bit cleaner and probably improves areodynamics. If it's in good shape, put it on.
The one in my Mazda 3 held up for about 9 years, although I had to repair it once. But once it broke beyond repair, I just tossed it out and never replaced it.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707447
03/26/18 11:38 AM
03/26/18 11:38 AM
MURICA
MURICA
Yeah, mine is structurally good and nothing is missing.
So I'll be definitely going to put it back on.
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707459
03/26/18 11:56 AM
03/26/18 11:56 AM
USA
thrace Offline
thrace  Offline
USA
Better with cover.
1. Find part numbers of clips.
Check sites for Acura parts to get part numbers. There might be several different clips with different part numbers. For example:
https://www.oemacuraparts.com/auto-parts/2013/acura/tsx-sedan/tsx-trim/5-speed-automatic-engine
https://www.oemacuraparts.com/auto-parts...nt-fenders-scat
Found these part numbers for 2013 TSX sedan
For example, if PartNo: 74110-TL2-A00 COVER ASSY., ENGINE (LOWER) is the splash guard you are finding, some parts that hold it on are:
16 90143-TL0-000 Bolt, Cover (Lower)
$3.45 $2.42
17 90673-TL0-000 Nut, Clip (6MM)
$3.73 $2.61
21 91505-S9A-003 Clip A, Bumper
$3.03 $2.12
One plastic clip for 2013 Tsx is 91505-S9A-003
2. Search Ebay for clips using Acura part number.
Get enough clips for several oil changes for relatively cheap on ebay. Clips to not always break when removed but some often do.
https://www.ebay.com/sch/i.html?_from=R4...03&_sacat=0
Some are U.S.A. sellers so maybe a week or less to get them. Don't even need to leave home to get them.
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707463
03/26/18 12:01 PM
03/26/18 12:01 PM
MURICA
MURICA
^thanks Thrace but mine is 06. All bolts are good, only plastic pushpins or rivets are the ones which are missing and need to be replaced.
I might just order it from eBay and for now zip tie abd later replace it.
They are expensive at the dealer, but really cheap on eBay thumbsup
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707476
03/26/18 12:18 PM
03/26/18 12:18 PM
KrisZ Offline
KrisZ  Offline
Nothing wrong with using zipties. Only the OCD types, which are many on here, will see it as improper.
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707483
03/26/18 12:30 PM
03/26/18 12:30 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I replace the push rivets periodically. Have also replaced the nylon nuts for the bolts. Purchase from Clips & Fasteners.
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707501
03/26/18 01:01 PM
03/26/18 01:01 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
Itís almost like you have to tear up those plastic pushpins to get them off. Thereís an aftermarket company that makes a stainless steel undercarriage splash guard for the Z32 300ZXís. I wonder if thereís one available for TSX/Accord?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707545
03/26/18 02:04 PM
03/26/18 02:04 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
The undercarriage splash guard for mine (also '06 TSX) has been sitting on a shelf in my garage for the last ~8 years and 150k+ miles. No issues.
Re: Acura TSX Splash Guard Removal [Re: cpayne5] #4707553
03/26/18 02:12 PM
03/26/18 02:12 PM
MURICA
MURICA
Curious, does it make changing engine oil, filter and ATF easier?
Since, what I can see, it needs to be removed for it?
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707618
03/26/18 03:19 PM
03/26/18 03:19 PM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
Those things are a pain in the you know what. Almost makes me hate to change the oil. I have a 2014 ford fusion, and I have to remove (if I remember correctly) 12 screws to get it off. Although I only change oil twice a year, In my opinion it makes it double the work, and my ooold bones don't like it as much as they did 50 years ago. I think once the warranty is out I will leave it off.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Acura TSX Splash Guard Removal [Re: maverickfhs] #4707621
03/26/18 03:21 PM
03/26/18 03:21 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
On my 2010 TSX, it is held on with about 7 or 8 bolts. I use an electric 1/4 inch impact driver to zip them off, and then zip them back on. Super easy to do with the right tools. If you are missing some push pins, Iíd spend the $10 to replace them.
Impact driver
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
