White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
31 registered members (billt460, claluja, c502cid, Cornershop, carlprop, 4 invisible), 840 guests, and 30 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
HF gen set dropped exh valve #4706590
03/25/18 04:07 PM
03/25/18 04:07 PM
Indiana
nascarnation Offline OP
Indiana
My neighbor gave me a non-running HF 4000W gen set (212 cc Chinese motor).
After cleaning the carb without success, I put on a new 11 dollar (!) carb and it ran fine. Pulled two 1500 watt heaters as a test load with no problem.
For about 15 minutes .... and then it dropped an exh valve.
Surprisingly the cylinder bore is undamaged, and shows basically no wear from use, and the piston is fine also. The cylinder head took all the damage from the valve crash.
Help me choose one of 3 options:
1) Buy a new 99 dollar HF engine and swap the side housing and crankshaft from my existing engine (the 99 dollar engines have a straight output shaft on the crank, the gen set ones have a tapered shaft).
2) Buy a new head and valves (45 bucks or so?), install on my engine.
3) Give it away to somebody else.
Re: HF gen set dropped exh valve [Re: nascarnation] #4706593
03/25/18 04:11 PM
03/25/18 04:11 PM
New England
gathermewool Offline
New England
Sounds like you have the skill to refurb this thing.
I'd buy a new head, if you feel comfortable with the swap. As you said, the piston/bore look fine. If it wasn't drinking oil in the short time you used it, I'd be comfortable with just a head.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: HF gen set dropped exh valve [Re: nascarnation] #4706595
03/25/18 04:11 PM
03/25/18 04:11 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Set it out with the trash and don't worry about it. Put a note on it describing the problem.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: HF gen set dropped exh valve [Re: skyactiv] #4706602
03/25/18 04:20 PM
03/25/18 04:20 PM
New England
New England
I never took you for a quitter! boxing Coffee2
Re: HF gen set dropped exh valve [Re: nascarnation] #4706603
03/25/18 04:20 PM
03/25/18 04:20 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Maybe find one that has other problems. Like one that runs but wont make power
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: HF gen set dropped exh valve [Re: Chris142] #4706606
03/25/18 04:25 PM
03/25/18 04:25 PM
New England
New England
That sounds worse.
If the genny on this thing works (seems like it took 3kW easily, from the OP), and the engine looks to be in good shape, then replacing the head seems like a logical choice.
Re: HF gen set dropped exh valve [Re: nascarnation] #4706615
03/25/18 04:34 PM
03/25/18 04:34 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
What are you going to do with the generator? Will you use it as an emergency generator or do you already have one of those? Don't spend money on it if it's just going to collect dust after you repair it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: HF gen set dropped exh valve [Re: Leo99] #4706619
03/25/18 04:40 PM
03/25/18 04:40 PM
New England
New England
Good point!
Re: HF gen set dropped exh valve [Re: nascarnation] #4706620
03/25/18 04:42 PM
03/25/18 04:42 PM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I think buying a different head, if it's easily attainable, is the best option.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: HF gen set dropped exh valve [Re: nascarnation] #4706691
03/25/18 05:41 PM
03/25/18 05:41 PM
USA
NHGUY Offline
NHGUY  Offline
USA
I'd go Briggs and not look back.
Re: HF gen set dropped exh valve [Re: NHGUY] #4706776
03/25/18 06:44 PM
03/25/18 06:44 PM
Indiana
Indiana
Well I have 3 go karts (for 5 grandchildren LOL) all with HF 212 motors. So I've kind of standardized on 99 dollar power...although I'd guess the reliability in the karts is mostly due to an easy duty cycle. I really wish the gen set used the "normal" version crankshaft, then they'd all be interchangeable.
Re: HF gen set dropped exh valve [Re: nascarnation] #4706793
03/25/18 06:57 PM
03/25/18 06:57 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Most generators have a tapered shaft. Its a PIA to get apart.
2015 Ford F250 w/Powerstroke
Re: HF gen set dropped exh valve [Re: nascarnation] #4706807
03/25/18 07:09 PM
03/25/18 07:09 PM
Florida
chainblu Offline
chainblu  Offline
Florida
I'd say option number 2. Assuming the parts are obtainable, $45 (or so) isn't bad for an otherwise free genny, even a Chinese one.
Re: HF gen set dropped exh valve [Re: Chris142] #4706827
03/25/18 07:24 PM
03/25/18 07:24 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes - - - buy it cheap and rob the parts you need.
Sell the rest on craigslist
Just change the head.
The engines are on craigslist all the time CHEAP!!! I see them for sale (RUNNING!!) for $35-40
Re: HF gen set dropped exh valve [Re: nascarnation] #4706829
03/25/18 07:26 PM
03/25/18 07:26 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
4) Buy a new 99 dollar HF engine and swap the head
then sell the rest of the engine (minus the head) on ebay or craigslist
