Another McLane vote. Got one (after being burned by a previous B&S with fuel diaphragm that kept self-distructing) with a newer style B&S carb. It's very reliable, though it was the last model year I expected CA to allow side-head-valve engines.
From another place on the 'net (circa 2008):
I grew up in Los Angeles, and KOL was from South Gate, Tru-Cut (Starlite) was El Monte, Trimmer in Gardena, McLane in Paramount, and Power Trim in Compton. KOL was always the cheapest and frankly that showed in their construction. Weakest links were die cast aluminum in the cutter head and in the bracket which held the sliding arm. When either of these broke, you took the engine off and junked the rest. Everyone else used cast iron or steel construction. They also self threading fasteners were everyone else used nut & bolt construction. When a fastener stripped, you either tried to replace with nut and bolt, or tapped oversize if possible.
Generally I would consider KOL comparable to cheaper edgers like the Trim-Rite, MTD, and Sears offerings. It'll get the job done, but respect it's limitations.
For home use, McLane is usually the best value proposition. The 101 and 801 models are recommended. Snapper, Tru-Cut, Deere and others have made competent machines. McLane also private labelled for dozens of people over the years (Deere comes to mind). Prices should start in the low $300's and go up.
At the top of the market, Power Trim and Little Wonder stand out. However, you're now starting at $500 or so and can run up to $800 for one with a commercial GX Honda engine. Great machines, but overkill if you're a homeowner.
