Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
jmd, alexislaborda, tbann, LisaMC, chops
67556 Registered Users
112 registered members (AdditiveOCD, 97prizm, aircooled, Agnosto, 69Torino, 8 invisible), 2,213 guests, and 59 spiders.
Topics286,072
Posts4,902,021
Members67,556
Most Online2,967
Mar 10th, 2019
Tape pinstripe removal gone wrong... #4706451
03/25/18 03:00 PM
03/25/18 03:00 PM
New York
NoNameJoe Offline OP
New York
Does anyone have experience with tape pinstripe removal? I did it once before on an older car and I was able to easily remove all of the pinstripe with no trouble.
I bought a car recently and noticed the pinstripe is deteriorating on the driver side toward the rear of the car. It has cracks through it and looks thin. So I used the same technique I did last time, hair dryer with a soft plastic scraper to lift the pinstripe. I started on the driver side, the side that had the deterioration toward the rear.
Starting from the front I removed the pinstripe at a good clip and it looked great underneath. As I started to remove the deteriorating pinstripe toward the rear is when things started to go terribly wrong. Every time I would lift the pinstripe, I would see some black under the pinstripe. The car's color is Modern Steel Metallic which is a metallic gray.
This black under the pinstripe is my big issue, I have no idea what it is. As the deterioration increases toward the rear of the car, the amount of black being exposed increases as I remove the pinstripe.
1. Looking at the light the black appears raised but I can't tell if it's just the line the pinstripe makes in the clear coat. It looks like some kind of adhesive but it's as shiny as the clear coat is, no color transfer occurs and acetone does nothing to it. Acetone dissolved the other adhesive toward the front with no problem so I don't see why it wouldn't work here unless this was some extremely hardened adhesive.
2. I tried some SwirlX to see if it was above the paint or something, no color transfer, no difference.
3. Clay bar does nothing as well.
4. I can just barely grab it with my fingernail, slides past it.
5. This car is a 2015, the pinstripes haven't even been on there that long. I've removed pinstripes of this same type from older cars with no issues.
At this point I'm a little upset. If I can't fix this I'll either have to paint over it or get another pinstripe and put pinstripes back on.
I don't see how the tape pinstripe could have damaged the actual paint under the clear without damaging the clear itself since the clear is still there and shiny. I don't even know what this black stuff is. Should I be using something other than acetone?
Here are some pictures of what I'm dealing with. I hope this shows that the black stuff is as shiny as the clear coat and almost uninterrupted when looking at both the black stuff and clear coat. It appears the black stuff is only under the white parts of the pinstripe, because where the pinstripes have cracks, the black stuff also has cracks.
2015 Civic LX Coupe
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706490
03/25/18 03:35 PM
03/25/18 03:35 PM
Cleveland, OH
silveravant Offline
silveravant  Offline
Cleveland, OH
I sorry I can't offer any help, but I would never use acetone on the paint of any car.
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706492
03/25/18 03:38 PM
03/25/18 03:38 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Try the "Pin Stripe" remover at the auto stores. It's probably acetone, or toluene or some combination but hey, they say it removes pin stripes.
If you want the job done right......do it yourself.
Re: Tape pinstripe removal gone wrong... [Re: silveravant] #4706497
03/25/18 03:40 PM
03/25/18 03:40 PM
New York
New York
I want to re-iterate that this was like this before I used the acetone. I only use the acetone to remove the sticky adhesive faster, rubbing alcohol works just as well.
Just peeling the pinstripe off produces the result shown above, before I even touch it with acetone or alcohol.
2015 Civic LX Coupe
Re: Tape pinstripe removal gone wrong... [Re: silveravant] #4706498
03/25/18 03:40 PM
03/25/18 03:40 PM
Iowa
Nyquist Offline
Nyquist  Offline
Iowa
It almost looks like hardened adhesive. Perhaps a body shop would have some ideas on how to remove it.
2015 Chevy Traverse 3.6L (LLT) Mobil 1 5w30 w/ Fram Ultra
2018 Chevy Cruze 1.4L (LE2) Mobil 1 5w30 w/ ACDelco
Re: Tape pinstripe removal gone wrong... [Re: Snagglefoot] #4706502
03/25/18 03:45 PM
03/25/18 03:45 PM
New York
New York
The closest thing I could find is 3M adhesive remover. Should I try that?
I wonder if I should try a rubber eraser wheel.
2015 Civic LX Coupe
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706509
03/25/18 03:56 PM
03/25/18 03:56 PM
wi
dave123 Offline
dave123  Offline
wi
Toluene would be first start really should mot use acetone as some one that uses thousands of gallons of it you donít wonít to start it maybe MEK
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706514
03/25/18 04:01 PM
03/25/18 04:01 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
goo gone? its citrus based iirc so no paint damage.
maybe try wd-40.. wont damage paint
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706519
03/25/18 04:05 PM
03/25/18 04:05 PM
New York
New York
Ordered an eraser wheel. I think it needs some mechanical action, I need something to grip the black stuff and if it is above surface, pull it off. Lord help me if this goes wrong rofl.
I will post an update when I use it, even if it's a fail of epic proportions.
2015 Civic LX Coupe
Re: Tape pinstripe removal gone wrong... [Re: Snagglefoot] #4706526
03/25/18 04:14 PM
03/25/18 04:14 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Stop with the solvents, soon you will find one that works perfectly and the paint will be gone or softened.
The 3M stuff is okay but use a wheel to remove stripes and adhesive. When you use these keep it moving and don't let it sit in one spot and heat the paint.
You can get these at any autobody supply store, once its all gone a light buff will make it flawless.
https://www.amazon.com/3M-Stripe-Wheel-D...YYQQ5RMHGAAFDGC
Edit: I see you already ordered one before I posted this.
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706527
03/25/18 04:15 PM
03/25/18 04:15 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I would still try some goo gone.. I've taken off gorilla tape residue that was years old in seconds..
I would apply with a microfiber rag let it soak in for 30seconds or so then see what happens with a little rubbing action.. possibly switching to a soapy rag.
Re: Tape pinstripe removal gone wrong... [Re: Rand] #4706550
03/25/18 04:37 PM
03/25/18 04:37 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
+1
Kerosene is the natural adhesive solvent for many adhesives. WD-40 is a good substitute. Goo-Gone is good.
No Acetone - it'll kill the paint. Over time it will start to fade/haze where ever you used it ...
3M makes a decal remover disc that will help. Be gentle ...
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706589
03/25/18 05:07 PM
03/25/18 05:07 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I removed an old 1969 Dodge SuperBee bumble bee stripe from the rear (6" wide) just using baby oil + rubbing alcohol, and a hair dryer. Once done, you could barely tell it was there. A body shop finished by buffing it out for me....looked perfect. It took me several hours, and it came off in varying sizes and chunks. A lot is dependent on how long it has been on the car, if it's baked on hard, etc.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706635
03/25/18 05:53 PM
03/25/18 05:53 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Yeah, the stripe wheel. I used the similar 3m eraser wheel because i didn't know they had a stripe wheel. That also worked.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Tape pinstripe removal gone wrong... [Re: NoNameJoe] #4706818
03/25/18 08:14 PM
03/25/18 08:14 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It needs to spin very fast, several 1000 rpm's
a regular drill isn't fast enough
