2019 Subaru Crosstrek FB20D - Oil choices
by cluster5. 03/26/19 09:31 PM
.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
69 registered members (bdcardinal, 87sammy, Bill_W, advocate, Bryanccfshr, 7 invisible), 1,556 guests, and 105 spiders.
Topics286,477
Posts4,909,148
Members67,635
Most Online2,967
Mar 10th, 2019
2011 Malibu Tie Rod Torque? #4706383
03/25/18 01:22 PM
03/25/18 01:22 PM
MI
doitmyself Offline OP
MI
Anyone know the torque spec. for a 2011 Chevy Malibu outer tie rod castle nut??
Thanks!
Re: 2011 Malibu Tie Rod Torque? [Re: doitmyself] #4706411
03/25/18 02:02 PM
03/25/18 02:02 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Snug
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 2011 Malibu Tie Rod Torque? [Re: doitmyself] #4706441
03/25/18 02:41 PM
03/25/18 02:41 PM
CA
The Critic Offline
The Critic  Offline
CA
A little tighter than your typical asian-vehicle oil drain plug.
But it is somewhat pointless because the person who does your alignment will be loosening that nut again.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: 2011 Malibu Tie Rod Torque? [Re: The Critic] #4706452
03/25/18 03:00 PM
03/25/18 03:00 PM
MIchigan
Warstud Online content
Warstud  Online Content
MIchigan
Castle Nut Torque.
Re: 2011 Malibu Tie Rod Torque? [Re: doitmyself] #4706472
03/25/18 03:24 PM
03/25/18 03:24 PM
MI
MI
I don't see the spec in The Critic's list. Warstud is correct, I am looking for the nut that pulls the tapered tie rod shaft into the knuckle hole (aluminum).
I loosened the original tie rod nut, and with a torque wrench it returned to the same spot at about 40 ft. lb.
My elbow torque meter is not too accurate, LOL.
Re: 2011 Malibu Tie Rod Torque? [Re: doitmyself] #4706532
03/25/18 04:21 PM
03/25/18 04:21 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Tight is the correct torque, with a castle nut you have to tighten it to the next opening the cotter pin will go through never loosen so an exact torque is may not be possible unless you are luck and it happens to land on the correct spot.
They don't need to be ball busting tight just tight enough you can tighten it a little more to get the pin in.
Re: 2011 Malibu Tie Rod Torque? [Re: doitmyself] #4707371
03/26/18 10:26 AM
03/26/18 10:26 AM
CA
The Critic Offline
The Critic  Offline
CA
Sorry. For some reason I read jamb nut.
Re: 2011 Malibu Tie Rod Torque? [Re: The Critic] #4707690
03/26/18 04:50 PM
03/26/18 04:50 PM
Trav Offline
Trav  Offline
And when the pin doesn't line up? I think he is replacing an elliptical offset nut which was OE with a aftermarket that uses a castle nut, if that's the case the spec no longer applies.
Still, he could go 30ftlb and then the next slot to line up and be close enough.
