air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
40 registered members (Ag76, carlprop, clinebarger, Bailes1992, Chris142, anndel, 1 invisible), 788 guests, and 61 spiders.
Topics286,440
Posts4,908,215
Members67,622
Most Online2,967
Mar 10th, 2019
Store brand 75w90 vs name brand? #4705895
03/24/18 10:33 PM
03/24/18 10:33 PM
Cincinnati
presta24 Offline OP
presta24  Offline OP
Cincinnati
I wheel 8 or 10 times a year and change my diff oils once a year regardless of mileage. Since I change it so often is there a benefit to running a more expensive brand?
Re: Store brand 75w90 vs name brand? [Re: presta24] #4705914
03/24/18 10:51 PM
03/24/18 10:51 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
You're good to go with the store brand unless you need a limited slip additive.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Store brand 75w90 vs name brand? [Re: presta24] #4705948
03/24/18 11:35 PM
03/24/18 11:35 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Even then, the Carquest 75W-140 I picked up on sale recently at AAP states it has LS additive blended in, so it depends on which store brand oil you buy. Super Tech at Walmart has no LS additive blended in.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Store brand 75w90 vs name brand? [Re: presta24] #4706009
03/25/18 04:31 AM
03/25/18 04:31 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I used Supertech semi synthetic 75W90 well over 100K in a WRX manual transmission. The 5 speeds in the WRX's were
nick named glass transmission because they were fragile. Google "glass transmission". I never had an issue, even after I did a stage 2 tune
for mid 13 second 1/4 mile times.
Me: 13' VW GTI 3 door 6 speed manual
Re: Store brand 75w90 vs name brand? [Re: presta24] #4706017
03/25/18 05:13 AM
03/25/18 05:13 AM
OKLAHOMA
GMguy84 Online content
GMguy84  Online Content
OKLAHOMA
Just changed the DIFF fluid in my Suburban and it called 75W-90
Luckily, I scored the last case of walmart Super tech FULL SYN for $22.50 w/tax !!!! I think it was the last case of FULL SYN for that price in oklahoma cause I saw at other stores was semi-syn laugh lol
Does anyone know who makes the DIFF fluid for Wal-Mart ??
Dave
05 Silverado Z71 5.3 Mobil 1 EP 10W30/FUG XG3675
01 Suburban 5.3 Mobil 1 AP 5W30/FUG XG3675
1982 TRANS AM (KITT) Mobil S5K 10W40/M1-302A
Re: Store brand 75w90 vs name brand? [Re: presta24] #4706018
03/25/18 05:28 AM
03/25/18 05:28 AM
Texas
TriaxLubes Offline
TriaxLubes  Offline
Texas
Yes, there are significant advantages to using high performance gear oils all the time, even though you change it often. Not all gear oils offer the same level of protection, even for very short drain intervals. Just because two gear oils are both 75W90 with the same specs doesnt mean they are the same. Both being 75W90 has about as much meaning as saying two cars are red so they must be the same and will pick the cheapest one...its not true.
Additive and viscosity breakdown due to shear and load can happen very quickly. The quality of the gear oil comes down to the base oils used, VI improvers, EP additives etc. For example, you can make a cheap gear oil by using lower quality base oil and a lot of Viscosity Index Improvers (VI). Its a way to keep cost down vs using a high grade base oil with very high natural VI, like a Group III or PAO. The latter option is by far the best but tends to be more expensive. To make a great gear oil, you must keep the use of VI improvers down to a minimum, as VI improvers are prone to shear. So just because you change your gear oil often doesnt mean you get the same protection in that short time you do use it. Just like using poor quality motor oils. Short drain intervals WILL NOT save you from premature engine wear and other issues as the poor quality oil does not protect the metal like more expensive / better oils and will generate a ton of sludge in that short 3000 miles. Due to the complexity of lubricants engineering, its nearly impossible to tell how things are made. Having an oil meet certain criteria like GL-5, SN, API approval or whatever, doesnt say much about performance since these standards are not exactly top tier. They are a very low minimum requirement. Best way to evaluate it is to look for mentions of drain intervals and the number of OEM specs it meets. Drain intervals are pretty good indicator of quality.
Top tier gear oils meet or exceed EATON Roadranger or EATON E500 - these two specs are very hard (expensive) to meet. These are 750,000 miles gear oils. Its not the drain interval that matters really, what matters is the quality which goes into the product and is required to even approach that kind of performance. I think you will find only a handful of gear oils meet those specs, probably less than 1% of whats on the market.
A good rule of thumb is to always buy the best you can afford. If you are going to use a 75W90, use a full synthetic. Never a synthetic blend. There is no law that regulates what manufacturers can call a synthetic blend. It can be 1% synthetic and 99% mineral or 20% synthetic and 99% mineral. No way to tell.
Re: Store brand 75w90 vs name brand? [Re: presta24] #4706031
03/25/18 06:07 AM
03/25/18 06:07 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Changing gear oil once a year is likely overkill. As often as you do it, it wouldn't matter brand or anything else as long as it meets the specs for your vehicle.
The "thinking" man's friend.
Re: Store brand 75w90 vs name brand? [Re: presta24] #4706063
03/25/18 07:52 AM
03/25/18 07:52 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
I've used a lot of Supertech 75w90 gear oil. Its rated synthetic now as it was recently updated. As said no mention of a LS additive if you need that.
Around $5 a bottle can't be beat.
yup
Re: Store brand 75w90 vs name brand? [Re: TriaxLubes] #4706074
03/25/18 08:04 AM
03/25/18 08:04 AM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
Sounds an awful lot like an oil salesman.
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 208K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Store brand 75w90 vs name brand? [Re: Lubener] #4706088
03/25/18 08:21 AM
03/25/18 08:21 AM
Cincinnati
presta24 Offline OP
presta24  Offline OP
Cincinnati
I change it so often only due to the risk of water seeping into the cases. We do a lot of deep water crossings.
Re: Store brand 75w90 vs name brand? [Re: Lubener] #4706091
03/25/18 08:22 AM
03/25/18 08:22 AM
Cincinnati
presta24 Offline OP
presta24  Offline OP
Cincinnati
Re: Store brand 75w90 vs name brand? [Re: presta24] #4706098
03/25/18 08:24 AM
03/25/18 08:24 AM
Cincinnati
presta24 Offline OP
presta24  Offline OP
Cincinnati
Thanks for all the feed back guys. Last time I changed my front diff I must have reused the crush washer instead of replacing it and it was leaking. So when I replaced the crush washer I just refilled with super-tech syn. No LS required for the front diff or xfer case, only the rear diff.
Re: Store brand 75w90 vs name brand? [Re: presta24] #4706220
03/25/18 10:23 AM
03/25/18 10:23 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
If the cheap stuff "meets or exceeds" the specced lube grade... I read the bottles when I compare a name brand to the cheap stuff.
Thick oil is better grin2
Re: Store brand 75w90 vs name brand? [Re: presta24] #4706320
03/25/18 12:26 PM
03/25/18 12:26 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
This is what is in my 3/4 ton diffs. It's the Canadian Tire store brand. It is good enough or do I need to worry about PAO and stuff. wink
MotoMaster Synthetic Extreme Pressure Gear Oil is recommended for differentials and manual transmissions for which hypoid-type lubricants are required
Transfer cases for heavy equipment trucks, tractors, industrial gear drives, automobiles, farm machinery, etc.
Meets or exceeds API Service Classification GL-5 and MT-1 and SAE J2360; former U.S. Military Specification MIL-L-2105D and MIL-PRF-2105E performance requirements
Meets or exceeds Scania STO 1:0, Eaton Road Ranger E500 and ArvinMeritor O-76N performance requirements
Meets DANA SHAES 256, Rev. C (75W-90) and Mack GO-J Plus (75W-90) requirements
Grade: 75W90
If you want the job done right......do it yourself.
Re: Store brand 75w90 vs name brand? [Re: TriaxLubes] #4706333
03/25/18 12:42 PM
03/25/18 12:42 PM
Texas
4WD Offline
4WD  Offline
Texas
I for one have experienced gear oil break down (Shell bulk dino) ~ drained out like hydraulic oil in 30k lost the whole rear end just past warranty $1800 later I had a used rear end with 20k more than the truck had
That pumpkin was filled with Schaeffer synthetic
