Kendall GT-1 5W-30 FS D1G2 NOACK?
I don't think Phillips/Kendall publishes NOACK percentages but they typically test relatively high from what I've seen...so I'd guess it's probably at the higher end of the Dexos approval NOACK level, which I believe is still limited to 13 on the high end.
PQIA had a test from 2013 that had this weight of GT-1 at a 10.7 NOACK that you've probably seen but I would doubt that's still applicable. They had a 5w-20 synthetic blend version of this oil that was tested at a NOACK of 15.1 in 2014.
OK, THANKS!
With those NOACKs, I guess I will stick to either the Amsoil Sig Series, or try the relatively low NOACK Ravenol Racing REP 5W-30 for the summer OCI, while waiting on
Blauparts to get it together, and bring in the excellent spec, geared towards NO LSPI/deposits, VERY low NOACK, DXG 5W-30.
