Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
121 registered members (209paulc, 2015_PSD, 40w8, 4WD, 2009Edge, 11 invisible), 1,575 guests, and 36 spiders.
Topics296,753
Posts4,958,245
Members66,964
Most Online2,577
Jan 14th, 2019
2014 F150 ecoboost issue with instant MPG gauge #4705377
03/24/18 01:56 PM
03/24/18 01:56 PM
Washington State (East)
Blaze Offline OP
Blaze  Offline OP
My wife's ecoboost fuel gauge jumps or builds up to 99.9 mpg and sticks there. Other bizarre readings too. Any idea how I can fix this? Its the instant MPG fuel reading with the bar graph. The trip meter fuel gauge area seems fine. thanks.
Re: 2014 F150 ecoboost issue with instant MPG gauge [Re: Blaze] #4705492
03/24/18 03:20 PM
03/24/18 03:20 PM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
The 99.9mpg reading can happen with the throttle closed and the truck coasting. Fuel injectors shut off in those conditions and you will see instant readings as infinite fuel economy. Over 35mph, fully warm and foot off the gas will make it happen.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: 2014 F150 ecoboost issue with instant MPG gauge [Re: Blaze] #4705579
03/24/18 04:31 PM
03/24/18 04:31 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I remember the Chrysler MPG gauges, they would do the same thing coasting down a long interstate downhill with the throttle closed. I actually wish all cars & trucks came with an accurate instantaneous MPG gauge, it would make it easier to get max MPGs in all situations-A/C on or off, towing (does lugging in that higher gear help), etc.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2014 F150 ecoboost issue with instant MPG gauge [Re: tcp71] #4705608
03/24/18 05:03 PM
03/24/18 05:03 PM
Blaze Offline OP
Blaze  Offline OP
Its doing it going uphill under acceleration. Same place, same hill it was 14-15 mpg before. This is the first time I have seen this 99.9 reading anywhere. The gauge where the trip meter is seems normal. Its only the gauge with the instant MPG with the funky green bar graph.
Re: 2014 F150 ecoboost issue with instant MPG gauge [Re: Blaze] #4705617
03/24/18 05:08 PM
03/24/18 05:08 PM
Texas
2009Edge Online content
2009Edge  Online Content
Texas
The Scan Gage I have in my 2017 Edge Titanium does the same thing.
It goes to 999.9 when my foot is OFF the gas. My right foot is connected to my fuel economy.
The factory fuel economy gage pegs at 40 mpg.
Re: 2014 F150 ecoboost issue with instant MPG gauge [Re: Blaze] #4705653
03/24/18 05:38 PM
03/24/18 05:38 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
This sounds like it could to be a bugger to track down, electrical wiring/ground fault a bad gauge or a sensor (depending on what its using for calculations). Start by checking the dealer for any TSB or similar issues that have come in.
If the fuel gauge is unaffected I usually reset the system and let stuff like this go until a hard fault develops, sometimes chasing after something like this is more trouble than its worth.
Re: 2014 F150 ecoboost issue with instant MPG gauge [Re: Trav] #4705917
03/24/18 09:54 PM
03/24/18 09:54 PM
Blaze Offline OP
Blaze  Offline OP
For now I'm going to bag it. Just keep it turned off. The trip odometer and fuel mileage gauge is fine. Its only when I click on the bar graph gauge that goes hay wire. I know zero about these electronics and this was our first truck with this. When we first purchased it my first thought was how long all these computers/electronics were going to last. So much can go wrong...and it did.
Re: 2014 F150 ecoboost issue with instant MPG gauge [Re: Blaze] #4707420
03/26/18 10:17 AM
03/26/18 10:17 AM
Southeast
meep Offline
meep  Offline
Southeast
That's odd because it's the same software which gives you both readings, trip display and mpg display. Have you looked for any codes for clues? Take a look at "forscan" software.
2018 F150
2015 crv (wifey!)
