Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
112 registered members (aircooled, Andy636, anndel, addyguy, 28oz, AandPDan, 10 invisible), 2,210 guests, and 52 spiders.
Topics296,731
Posts4,957,846
Members66,960
Most Online2,577
Jan 14th, 2019
2007 Corolla; low idle and overheat condition #4704782
03/23/18 10:32 PM
03/23/18 10:32 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Hey all, my car had some issues today..so wife was in car (car idling) while i was in store and she tells me she shut off car because it was idling funny. (Low idle) almost like it was going to stall. I restarted and sure enough low idle like it was going to stall out. After a few minutes it seemed normal so I drove off again. At drive thru to get my kid food and I noticed temp gauge was higher than normal. Checked under hood and only thing I noticed was coolant overflow was higher than usual...usually its halfway between low and full and it was showing just about at full line. No apparent leaks or anything and no codes thrown (no check engine light) as didnt have my scanner to check for codes. Had it towed to mechanics. Tried to read up a bit wondering what it could be (was thinking head gasket) so checked oil and it looked fine on dipstick, not muddy or abnormal. From what Ive researched Im thinking coolant temp sensor maybe but im not certain. Just curious if anyone has experienced this or if anyone has any ideas on what it could be. Mechanic is only in on Monday so im just curious what it might be. 155k miles. 1zzfe engine. Thoughts appreciated smile
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 2007 Corolla; low idle and overheat condition [Re: Rolla07] #4704793
03/23/18 10:51 PM
03/23/18 10:51 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
When was the coolant/water pump/thermostat/radiator cap last replaced?
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 2007 Corolla; low idle and overheat condition [Re: Nick1994] #4704807
03/23/18 11:04 PM
03/23/18 11:04 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
To be honest, i am running a bit late on doing a coolant flush. Was last done in 2012...water pump - never replaced (never showed signs of a leak)- to this day still no leak. Thermostat- still original, rad cap- still original. Would one of these impact the idle also?
PP 0w20 & ST 4967
Re: 2007 Corolla; low idle and overheat condition [Re: Rolla07] #4704822
03/23/18 11:47 PM
03/23/18 11:47 PM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
If it's a failing water pump, like a deteriorated impeller, reving the engine above idle for few minutes should bring the temp. down.
How is heat when that happens? Any fluctuations in the vent temp?
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
Re: 2007 Corolla; low idle and overheat condition [Re: KrisZ] #4704824
03/23/18 11:52 PM
03/23/18 11:52 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
To be honest i drove it for literally 1 minute to the drive thru..idling was normal at drive thru (strangely) but temp was going up quickly. No signs of overheating when car displayed low idle issues earlier.
PP 0w20 & ST 4967
Re: 2007 Corolla; low idle and overheat condition [Re: Rolla07] #4704840
03/24/18 12:55 AM
03/24/18 12:55 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
A water pump that has lost its fins to corrosion won't pump much water. A lazy thermostat can open late and make it run warmer. And a bad radiator cap won't hold pressure and can make it overheat.
Overheating can make the idle weird.
Sounds to me the entire cooling system needs a refresh just to start with.
Re: 2007 Corolla; low idle and overheat condition [Re: Rolla07] #4704895
03/24/18 05:28 AM
03/24/18 05:28 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Are the electric fans coming on?
Re: 2007 Corolla; low idle and overheat condition [Re: Trav] #4704898
03/24/18 05:36 AM
03/24/18 05:36 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
thumbsup
2004 Corolla 128202
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2007 Corolla; low idle and overheat condition [Re: Trav] #4704959
03/24/18 06:57 AM
03/24/18 06:57 AM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Not sure, but would that cause the low idle too?
PP 0w20 & ST 4967
Re: 2007 Corolla; low idle and overheat condition [Re: Rolla07] #4704963
03/24/18 07:01 AM
03/24/18 07:01 AM
Trav Offline
Trav  Offline
Sure it would, an engine overheating will get tighter. Check the fans, I think you will find they are not coming on.
Re: 2007 Corolla; low idle and overheat condition [Re: Rolla07] #4704999
03/24/18 07:31 AM
03/24/18 07:31 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
All good advise!
It seem as though some maintenance is in order with a good flush through the heater core and possible a new T-Stat and/or water pump and even belt operation...and check the fan operation.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 2007 Corolla; low idle and overheat condition [Re: Trav] #4705000
03/24/18 07:31 AM
03/24/18 07:31 AM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Thank you sir smile
PP 0w20 & ST 4967
Re: 2007 Corolla; low idle and overheat condition [Re: Rolla07] #4705013
03/24/18 07:45 AM
03/24/18 07:45 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Usually when the water goes bad on these engines it starts weeping coolant. I had mine replaced under warranty at the 60k mark. Just made it. I noticed the over flow tank was losing coolant, going from the full line to the min line in a few months.
Most recommend a simple drain and fill for the coolant on Toyotas fyi. A new radiator cap would be a cheap fix. Plus check the fans as mentioned. But would hold off on a new water pump for now. Next on list would be a new oem t-stat.
Re: 2007 Corolla; low idle and overheat condition [Re: Rolla07] #4705072
03/24/18 08:50 AM
03/24/18 08:50 AM
midwest
JamesBond Offline
JamesBond  Offline
midwest
A bad battery or alternator cn cause running and gauge weirdness.
Re: 2007 Corolla; low idle and overheat condition [Re: JamesBond] #4705078
03/24/18 08:55 AM
03/24/18 08:55 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
^ True, esp about the battery. Sometimes they even test ok but after replacement the issues disappear.
