New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
111 registered members (4WD, 28oz, Anduril, advocate, 2002 Maxima SE, 9 invisible), 2,188 guests, and 32 spiders.
Topics296,645
Posts4,956,535
Members66,950
Most Online2,577
Jan 14th, 2019
Electrician's advice? I need help! #4704672
03/23/18 07:40 PM
03/23/18 07:40 PM
MN
14Accent Offline OP
14Accent  Offline OP
MN
So, as some of you may know I recently bought a 2013 Chevrolet Volt. I'm loving it so far! As of now, I've exclusively used the 120v charger that comes with the car, which is limited to a max of 12A charge rate.
In doing research about adding a 240v circuit to my garage, I realized that it (appears) to already be set up for 240, although there are no 240v outlets installed. Here's the setup:
The house is OLD, 1905. However, all of the wiring has been redone. The garage is about 5 years old, and has a master disconnect switch mounted where I assume the power comes in from the house. The wires are buried. I have yet to remove the drywall surrounding the disconnect, however the garage is fed by a 2-pole 20A breaker in the main panel. The wires running to the garage are I believe either 10/3 or 12/3, there's a red wire connected to one half of the breaker, black to the other, white to neutral and ground to, well obviously.
Question is, before I go tearing out drywall, how might this be wired in the garage, seeing is everything in/on/around it is nothing but 120v. Did they run wire, possibly expecting to add 240 in the future, and just leave the red wire capped in the wall? If this turns out to be the case, is it as simple as adding a 6-20 240v outlet post-disconnect with the appropriate wiring and receptacle? I can handle simple wiring, not shocking myself is easy, I just don't want to budget for a $200 charger if I'm chasing a futile project.
Thanks everyone!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Electrician's advice? I need help! [Re: 14Accent] #4704685
03/23/18 07:49 PM
03/23/18 07:49 PM
NY
Kage860 Offline
Kage860  Offline
NY
I imagine you’re not supposed to just tap off an existing 240 line for a car charger, the right way to do it is to put a new 240v breaker in the main electrical panel and run a new line to the charger.
2007 Jeep Liberty PP 0w-20 / Carquest Blue, 6k oci
2015 Nissan Rogue PP 0w-20 / Pronto, 5k oci
Re: Electrician's advice? I need help! [Re: Kage860] #4704687
03/23/18 07:51 PM
03/23/18 07:51 PM
MN
14Accent Offline OP
14Accent  Offline OP
MN
Not for one of the larger units, no. Those draw up to 40A and require a dedicated circuit with a breaker. I plan on using a 240v 16A charge cord, the maximum charge rate the car draws is 15A. A 20A circuit should be plenty for the car, the motion light outside, and the garage door opener I would think. But again, I'm no electrician. I know just enough to get me zapped.
Re: Electrician's advice? I need help! [Re: 14Accent] #4704696
03/23/18 08:05 PM
03/23/18 08:05 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
unfortunately my eyes kinda glazed over in paragraph 2, but Yes, your Volt will take a level 2 (220v)charger.
My brother bought a 2014 Volt last summer, and he has recently done this project, including modifying a charger.(possibly a Leaf charger?) He can now get a full Charge overnight,vs 14 or so hrs.
I Know he has Bought/Sold a few EV Chargers on Ebay the last few months...
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
Re: Electrician's advice? I need help! [Re: 14Accent] #4704714
03/23/18 08:25 PM
03/23/18 08:25 PM
NY
Kage860 Offline
Kage860  Offline
NY
20 amps is not much. You’re not on the right track.
Re: Electrician's advice? I need help! [Re: 14Accent] #4704729
03/23/18 08:38 PM
03/23/18 08:38 PM
PimTac Offline
PimTac  Offline
Sounds like you need a electrician friend just to check it out for you.
Years ago I had a garage built and asked for a 240 circuit. They installed the breaker panel and ran a short wire down into a junction box and it was covered. That way it would be easy to wire up whatever I wanted.
Cannot see signatures any longer so it doesn’t matter.
Re: Electrician's advice? I need help! [Re: 14Accent] #4704736
03/23/18 08:59 PM
03/23/18 08:59 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I spent a lot of time looking into this since we bought a Leaf last year.
It sounds like you're doing well with what you've said.
Home AC power is usually 240VAC, with the neutral line in the middle. So if you measured red to neutral, you'd get 120. Black to neutral, you get 120 again. Measure black to red and you should get 240.
You should be able to wire in a 240 outlet, but you probably should be careful to use a proper amperage outlet (20a). You'll need to match your charging cable (EVSE) to your new outlet. I don't think that it would strictly be to code to add an outlet like that that isn't a dedicated run.
One other option, which has it's own risks, is to find the two outlets in the garage that are on opposite legs (red and black), then make your own dongle that joins them back together for your new EVSE.
The thing is, odds are likely that your entire garage is fed by that same feed, so you may pop breakers if you, say, opened the garage door while the car was charging.
I do think that it's worth doing though and that you're on the right track. I have read, at least with the Leaf, that charging at 240v is much more efficient than at 120v, even at the same wattage (there's more loss converting 120VAC to the ~400vdc of the battery than from 240VAC).
I purchased one of the Chinese EVSEs that will do up to 240v, 32a. It is adjustable down to 6A, and with a bunch of RV dongles, I can charge many more places.
Good luck!
Re: Electrician's advice? I need help! [Re: 14Accent] #4704755
03/23/18 09:31 PM
03/23/18 09:31 PM
Hollister, CA
Sunnyinhollister Online content
Sunnyinhollister  Online Content
Hollister, CA
I'm pretty sure the Volt is only capable of charging at 3.3kW so you do not need a 40A service.
Here's one - and its made in America:
https://store.clippercreek.com/index.php...3832.1521862162
2017 Ram 1500 Regular Cab 4x2 5.7L 8spd
2017 Chevy Bolt
2013 Honda CR-V AWD EX-L W/Nav
Re: Electrician's advice? I need help! [Re: 14Accent] #4704764
03/23/18 09:54 PM
03/23/18 09:54 PM
KS
DerbyDave Offline
DerbyDave  Offline
KS
When I had my LEAF I had a 50 amp sub panel installed in my garage that was fed by 3 Conductor #6 wire. In the sub panel I had a 40 amp breaker for my charger. The car could pull 6.6 kW while charging using the Level 2 charger I had. I am pretty confident in my wiring skills, (I wired my entire basement) but for this project even I consulted an electrician. Screw up and you could start a house fire!
1997 Ford Taurus
2005 Buick Terraza
2007 Honda Ridgeline
2003 Suzuki GZ250
1986 Suzuki Cavalcade
1986 Suzuki Intruder
Re: Electrician's advice? I need help! [Re: DerbyDave] #4704775
03/23/18 10:21 PM
03/23/18 10:21 PM
MN
14Accent Offline OP
14Accent  Offline OP
MN
That makes sense. If I was pulling that kind of current, I would too. This is a fairly standard 20A circuit, the Volt only pulls 3.3kw as stated. So around 15A. I'm quite sure the existing wiring can handle it. The car is the only thing in the garage that's drawing any significant power. I've been charging at 12A through the 120v charger that comes with the car and all is well. At 240v, max charge rate of 3.3kw equals 13.75A.
Re: Electrician's advice? I need help! [Re: 14Accent] #4704874
03/24/18 04:22 AM
03/24/18 04:22 AM
South Central PA
Delta Online happy
Delta  Online Happy
South Central PA
Sounds like they used a shared neutral for the power in your garage. More than likely one hot to run the lights, and the other to the receptacles. Do not tap into this, you will need to run a new line for your charger.
'17 VW GTI 2.0T - 6MT - 12K - PPE 5w40
'15 Camry SE - 2.5 - 21K - PP 0w20
'99 S10 - 2.2 5MT - 157K - PP 10w30
Re: Electrician's advice? I need help! [Re: 14Accent] #4704902
03/24/18 05:51 AM
03/24/18 05:51 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yup, what he said ^ ...
You need to upgrade what is there now. Best to have it sorted by an electrician, or a buddy who knows what he's doing ...
The existing circuit can handle casual loads, lights, GDoor opener, etc. But should not be pressed into service for a dedicated draw like car charging.
Need to know how how big conduit is between house and garage. May pull out existing wire and pull in larger, sub-panel, in-garage breakers, etc.
Re: Electrician's advice? I need help! [Re: 14Accent] #4704937
03/24/18 06:40 AM
03/24/18 06:40 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
They ran two 120v circuits using a common neutral which is fine as each 120v circuit is on a different leg of the 240v.
2015 Ford F250 w/Powerstroke
Re: Electrician's advice? I need help! [Re: 14Accent] #4704980
03/24/18 07:15 AM
03/24/18 07:15 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
If it's running off a double 20A breaker (tied together in your panel), and you're running a 16A rated charger, you could run it-but NOTHING else in your garage at the same time! You would be better off running a dedicated circuit, or a bigger cable (like 50 amps/6 gauge or bigger) so that you could run other stuff at the same time. Good news is-a battery charger is a resistive load, you're not starting motors or anything, so you're not going to have big inrush current problems.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Electrician's advice? I need help! [Re: Donald] #4704987
03/24/18 07:22 AM
03/24/18 07:22 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
I shamefully admit I have done this when I needed 240v (temporarily) to run a 240v welder.
It worked just fine.
