New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
112 registered members (4WD, aircooled, 28oz, advocate, 2002 Maxima SE, 9 invisible), 2,199 guests, and 33 spiders.
Topics296,645
Posts4,956,535
Members66,950
Most Online2,577
Jan 14th, 2019
3 Way Switch Wiring Help #4704086
03/23/18 09:03 AM
03/23/18 09:03 AM
Jupiter, FL
thescreensavers Offline OP
Jupiter, FL
Setup: Two Switches for one light, one downstairs and one upstairs in a stairwell.
Old Switch Wiring (black is in common of switch)( same type of switch upstairs)
https://i.stack.imgur.com/Dn9uW.jpg
New Switch: Lutron Maestro Motion Sensor]switch, 2-Amp, Single-Pole, White https://homedepot.app.link/MNlN0tjnwL
Wiring:
Manual Diagram: https://i.imgur.com/ztMmcYW.png
https://i.stack.imgur.com/VJwdG.jpg
So here is the interesting part
With upstairs switch down, black wire from wall to green of new switch causes the new switch to click/switch but no lights
If the switch upstairs is up then the earth grounding wire (to the new switches green wire) works(light turns on) (when upstairs switch is down it doesn't light up)
If I tie the earth ground and black wires together and use the switch up top, it trips the circuit breaker.
Any ideas?
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704088
03/23/18 09:06 AM
03/23/18 09:06 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Look up a wiring schematic, figure out which wires are which . The new switch seem like the wrong switch
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704107
03/23/18 09:31 AM
03/23/18 09:31 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If you replace a 3 way switch with a single pole switch , then it does not go smooth . Why would you expect it to .
Wyr
God bless
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704127
03/23/18 09:49 AM
03/23/18 09:49 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I think you need this one: MS-OPS5MH-WH
https://www.homedepot.com/p/Lutron-Maest...MH-WH/203202146
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704131
03/23/18 09:53 AM
03/23/18 09:53 AM
Ohio
Dave Sherman Offline
Ohio
You have the wrong switch. Right in the description, it's "for lights controlled from one location", so it's not a 3-way. Ground wires ONLY go to grounds, tying them to live wires is what tripped your breaker. Sounds like perhaps you should hire an electrician who knows what he's doing.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: 3 Way Switch Wiring Help [Re: Dave Sherman] #4704137
03/23/18 09:57 AM
03/23/18 09:57 AM
Jupiter, FL
Jupiter, FL
Thanks, I just came to that same conclusion
Thanks, I will get the correct switch.
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704143
03/23/18 10:08 AM
03/23/18 10:08 AM
Florida
FSully1 Offline
FSully1  Offline
Florida
You can NOT use 2 of these motion sensors on a 3-way switch. You can use 1 motion sensor switch and 1 standard 3-way mechanical and that would work. You can call Lutron, they can help you achieve what you want but it going to be additional cost to your project.
Re: 3 Way Switch Wiring Help [Re: Dave Sherman] #4704145
03/23/18 10:09 AM
03/23/18 10:09 AM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
Some people like myself learn by experience. Can't be an expert by only reading, so if you don't try how will you learn?
Think twice, speak once.
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704150
03/23/18 10:19 AM
03/23/18 10:19 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Yous pays yous money & yous makes yous choices .
I could bend your ear about safety and protecting you home / investment .
But , in stead , best of luck .
Wyr
God bless
PS I have over 35 years in the trade .
Wyr
God bless
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704255
03/23/18 12:29 PM
03/23/18 12:29 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
A three-way SW has four terminals:
1. Line (black)
2. Neutral (white)
3. Traveler (red)
4. Ground (bare copper)
The light is wired in the traveler leg, between the two SW.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704322
03/23/18 01:51 PM
03/23/18 01:51 PM
USA
mk378 Offline
mk378  Offline
USA
Never ever interconnect the bare / green ground wire system with any other wires. Ground wires are only to be connected to each other and to designated ground points on the devices and fixtures.
This is something that should not be learned by experience.
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704358
03/23/18 02:39 PM
03/23/18 02:39 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
When I was faced with this task, I gathered all the information I could, such as the wiring diagram of how it's supposed to work. I used my multimeter to find where there is continuity and the hot wire, and got familiar with the light fixture, wiring, and switches. Once it made sense in my mind and in the sketches, I hooked everything up properly. It worked the first time.
I'm also proud that I was able to wire a dimmer switch into a 4-way setup, and have it work the first time without fireworks.
Re: 3 Way Switch Wiring Help [Re: thescreensavers] #4704486
03/23/18 05:06 PM
03/23/18 05:06 PM
TX
KJSmith Offline
KJSmith  Offline
TX
Originally Posted By: thescreensavers
Any ideas?
What are you trying to accomplish exactly?
Contrary to what most have said, you can wire it to work.
But maybe not how you intend.
Re: 3 Way Switch Wiring Help [Re: sleddriver] #4704494
03/23/18 05:11 PM
03/23/18 05:11 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
1. Line (black)
2. Neutral (white)
3. Traveler (red)
You sir are wrong as to wiring on a 3-way switch . There are 3 screw terminals , plus yoy may or may not have a green terminals or green ground wire . Two of the screw terminals will be same color , say brass . One is a different color , say silver / shiny " white " or even DARK .
The green or bare wire is earth ground .
In practice , you can not depend on the other colors being a specific designation . If a white is connected to the switch , it most assuredly NOT a NEUTRIAL !
What ever color the 2 wires are , that go to the 2 same colored screws , they are travelers . If that 3-way is feed hot at that switch , the wire connected to the different colored screw , is the hot . Otherwise , that wire is the switch leg .
A " standard mechanical " 3-way switch does not use a neutral , even though a neutral may be present in the switch box . Some dimmers or motion switches may use a neutral to make the electronics work .
If mercury switches are still made , the switch must be vertical for things to work correctly . If it is not , say hanging by the wires , things do not work correctly .
Wyr
God bless
Re: 3 Way Switch Wiring Help [Re: mk378] #4704496
03/23/18 05:13 PM
03/23/18 05:13 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
But often is ! :-(
Wyr
God bless
