4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
95 registered members (2010Civic, agpatel, 69Torino, Agnosto, 2015_PSD, 13 invisible), 1,671 guests, and 67 spiders.
Topics286,042
Posts4,901,372
Members67,551
Most Online2,967
Mar 10th, 2019
Few oil ? #4703705
03/22/18 09:25 PM
03/22/18 09:25 PM
MA.
Camprunner Offline OP
MA.
Just a few questions ..... Does excessive idling cause oil to get diluted with fuel? And second why do some direct injected engines have a tendency to dilute the oil with fuel? What about a DI motor makes it prone to fuel dilution?
Re: Few oil ? [Re: Camprunner] #4703714
03/22/18 09:39 PM
03/22/18 09:39 PM
The land of USA-made Subies!
SubieRubyRoo Offline
1. Yes, in almost all cases. Insufficient oil temps prevent the fuel from evaporating and getting sucked out through PCV. 2. Injection pressures can cause fuel to leak past the combustion rings and contaminate the oil.
Interestingly, even on high diluters like the Ford EcoBoost engines, there have not been the catastrophic results predicted by people who are shouting from the rooftops about fuel dilution. It appears if you go by the OLM or sensible OCIs, fuel dilution is not the death sentence that old logic would have you believe.
Re: Few oil ? [Re: Camprunner] #4704071
03/23/18 09:54 AM
03/23/18 09:54 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Fuel dilution is just an active form of "Solvent Refining" like good old Grp I oils. If there is not much to create new oils from the initial fill (?), there should not be to much issue other than grade/viscosity loss due to thinning ... And we all know that 0W-20's work for many engines, so starting with a 40 should give you a lot of headroom laugh
