1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
47 registered members (anndel, billpace1956, carloz, Brad_C, Ammofirst, BikeWhisperer, 4 invisible), 1,094 guests, and 30 spiders.
Topics296,903
Posts4,961,300
Members66,997
Most Online2,688
Jan 19th, 2019
2017 Ford Escape 2.0L ATF change interval? #4703335
03/22/18 02:16 PM
03/22/18 02:16 PM
McGregor TX
mrdctaylor Offline OP
McGregor TX
My son JUST got a 2017 Escape. As in today. It has 20-something thousand miles on it now. It has the 2.0L Ecoboost. I haven't seen any documentation yet, which is why I came here. It looks like the drain/fill procedure on this should be pretty straight forward. Do they all have the fill port up top? I haven't actually laid eyes on his car yet. I just want to know what I've got in store for myself. It looks like if you're careful and measure what comes out when everything is cold, you should be able to do this at home pretty easily, right? All the videos I've seen on Youtube were on older models, so I don't know what may have changed.
So what are the common thoughts on how often to do a drain/fill? He wants to keep this car a long time. Should we d/f the ATF every 30k? 50k?
Thanks in advance!
02 Tacoma 3.4L, 222K, Magnatec 10W30
12 Highlander 3.5L, 101K, Napa Syn 0W20
17 Escape 2.0L, 37K, Hav ProDS 5W30
02 Trailblazer 4.2L, 182K, Edge HM 10W40
Re: 2017 Ford Escape 2.0L ATF change interval? [Re: mrdctaylor] #4703359
03/22/18 02:36 PM
03/22/18 02:36 PM
McGregor TX
McGregor TX
And I guess it is worth asking this too:
I believe it has just a fill hold and not a dipstick. Has anyone used a fluid extractor with this transmission? I'm sure I could get some (possibly most) of the fluid out that way like I do with my other vehicles, but having a dipstick I *know* I can get the extractor tube down to the bottom. I'm not sure about this transmission without a dipstick.
Re: 2017 Ford Escape 2.0L ATF change interval? [Re: mrdctaylor] #4703361
03/22/18 02:37 PM
03/22/18 02:37 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
https://www.google.com/search?client=fir...1.0.fS_yBX1v1lE
Check this out my amigo. First link has a PDF directly from FoMOCo
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: 2017 Ford Escape 2.0L ATF change interval? [Re: mrdctaylor] #4703369
03/22/18 02:45 PM
03/22/18 02:45 PM
McGregor TX
McGregor TX
Hmmmm. I wonder if the google search came back different for me. The first link WAS a PDF, but it just had some general specs about the car. Maybe I'm missing something, but this was the first link:
https://media.ford.com/content/dam/fordm...-tech-specs.pdf
Re: 2017 Ford Escape 2.0L ATF change interval? [Re: mrdctaylor] #4703394
03/22/18 03:00 PM
03/22/18 03:00 PM
New York
pbm Offline
pbm  Offline
New York
See my post earlier today in this thread:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4702840/Re:_15_escape_tranny_mtc_quest#Post4702840
The fluid gets dark quickly so I'd change the FF asap and then every 30K or so...it's easy to do.
'Journalism is Dead'
Re: 2017 Ford Escape 2.0L ATF change interval? [Re: mrdctaylor] #4703408
03/22/18 03:14 PM
03/22/18 03:14 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
In my 2017 Fusion which had 26K when purchased, I did a D_F at 30K with MC Mercon LV, as M1 ATF does not have the LV spes. I plan to D_F every 30K. To drain, just remove the pipe plug in bottom of the trans. I got about 3.5 qts out. To fill, remove the fill plug on top(easy to find) and put a trans funnel and fill to the exact amount you drained from trans. There's no dip stick.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 2017 Ford Escape 2.0L ATF change interval? [Re: tig1] #4703936
03/23/18 06:33 AM
03/23/18 06:33 AM
McGregor TX
McGregor TX
That sounds like a good plan. I've always done 30K d/f on my other vehicles. Even without a dipstick, this should be pretty easy if i carefully measure what comes out.
I'm curious: has anyone used a fluid extractor to suck fluid out of the fill hole on these transmissions? I've done it on transmissions with dipsticks and can always get just as much out as draining from the drain hole...and it is less messy.
Re: 2017 Ford Escape 2.0L ATF change interval? [Re: mrdctaylor] #4704136
03/23/18 09:57 AM
03/23/18 09:57 AM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
We have a 2017 Explorer with the same transmission, the 6F35. It's super easy to do a drain and fill. I do ours the next morning after driving it onto ramps the night before. That way with it being "cold" I don't have to be concerned with the thermal expansion of hot ATF and trying to replace it with "cold" ATF. This way the ATF's are the same temperature. I drain the fluid into a measured bucket and refill with the same amount. I get about ~43% of the total ATF out doing a drain and fill, about 3.8-4.0 quarts in my case. It's not messy doing it this way as you don't have a pan to drop and spill all over. It's just a drain plug.
Whimsey
