Opinions on the best hidden dash cam?
by FordBroncoVWJeta. 04/18/19 03:28 PM
Maxlife Synthetic or PPHM 10w30
by 53' Stude. 04/18/19 03:27 PM
PYB 10w30 question
by 1978elcamino. 04/18/19 03:16 PM
Misbehaving Mechanic Caught On Dash Cam
by BlueOvalFitter. 04/18/19 02:38 PM
What oil for my newly acquired Samurai
by ad244. 04/18/19 02:37 PM
Check your Oil (SMA YouTube Video)
by javacontour. 04/18/19 02:37 PM
Wearing Hiking Shoes Full-Time
by oilpsi2high. 04/18/19 01:56 PM
Apply brakes, steering wheel shakes
by grampi. 04/18/19 01:35 PM
F150 Exhaust whistle
by Redright9. 04/18/19 01:20 PM
Boy, what a marketing win!
by SubieRubyRoo. 04/18/19 12:06 PM
auto shipping question for a friend
by earlyre. 04/18/19 11:02 AM
O Reilly motor oil
by porvdub. 04/18/19 10:59 AM
GM & JEEP O/S OIL FILTERS
by adrenalin89. 04/18/19 10:56 AM
Accord AC Issue
by maverickfhs. 04/18/19 10:54 AM
Transatlantic Communication Lines and the story
by StevieC. 04/18/19 10:41 AM
Crazy Neighbor....part deux
by Schmoe. 04/18/19 10:15 AM
Troubles with Mint Mobile formerly Miny Sim
by daves66nova. 04/18/19 09:40 AM
Kenzitoz, White12Boss302, terryj, Hadryk, djcavein
67844 Registered Users
120 registered members (addyguy, 53' Stude, 1978elcamino, ad244, 55hambone, 2010Civic, 7 invisible), 2,179 guests, and 24 spiders.
Topics287,703
Posts4,932,625
Members67,844
Most Online2,967
Mar 10th, 2019
White pasty substance on dipstick #4703199
03/22/18 01:13 PM
03/22/18 01:13 PM
North dakota
Weezybabydoll Offline OP
North dakota
I have a 95 Escort 1.9L that I use for work. I notice when I check the oil I always have this pasty substance on the dip stick along with under my oil cap. I run 5w20 full synthetic high milage Valvoline oil. For the last 6 months the temperature has been mostly below freezing. My coolant seems to always be full as I've never had to add any and my oil level remains the same at all times. Wondering if it's just from the cold or possibly another problem. The car runs smooth doesn't knock or make any weird noises.
2015 F350 Powerstroke
2014 Explorer Sport
2003 5.9 Cummins
95 Escort Shaggin Wagon daily driver
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703204
03/22/18 01:16 PM
03/22/18 01:16 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
What's your driving regimen? Lots of short trips that never let the engine fully warm up?
Have you checked to see of the PCV system is working and pulling a slight vacuum in the crankcase?
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703206
03/22/18 01:16 PM
03/22/18 01:16 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
How's the heat? I had this on the MGM in my sig, thermostat was opening too soon. A new 195F SuperStat fixed it right up.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703212
03/22/18 01:22 PM
03/22/18 01:22 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Oil isn't getting hot enough in the cold weather to burn off crankcase moisture from combustion blow-by.
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703217
03/22/18 01:27 PM
03/22/18 01:27 PM
North dakota
North dakota
Heat always good in the engine. It's a 13 mile drive with most of the miles being 65mph highway with some gravel. The thermostat is always fully warmed up after 4 miles or so.
2014 Explorer Sport
2003 5.9 Cummins
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703232
03/22/18 01:40 PM
03/22/18 01:40 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Then I'd inspect the PCV system and maybe replace the PCV valve (usually cheap and easy). I assume the milky substance isn't the oil itself, but just accumulating in the "out of the way" spots in the crankcase?
Re: White pasty substance on dipstick [Re: Alex_V] #4703260
03/22/18 02:07 PM
03/22/18 02:07 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Yep, the areas that the condensation collects on are the cooler running parts of the engine ... ie, under the oil filler cap on the valve cover. In really cold weather, it might take more than a 13 mile drive to burn off collected condensation.
+1 on checking to make sure the PCV valve and hoses are in good shape.
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703278
03/22/18 02:24 PM
03/22/18 02:24 PM
Texas
2009Edge Offline
2009Edge  Offline
Texas
Take it on a 150 mile drive and then look at the dipstick and under the oil cap.
Re: White pasty substance on dipstick [Re: 2009Edge] #4703281
03/22/18 02:27 PM
03/22/18 02:27 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Or a one hour/50 miles drive might do it as well. Save time and fuel. Thank you.
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703288
03/22/18 02:32 PM
03/22/18 02:32 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
Though you mentioned the coolant is warmed up after 4 miles, I've seen data where the oil is only fully warm after 9 miles.
Re: White pasty substance on dipstick [Re: Kestas] #4703290
03/22/18 02:34 PM
03/22/18 02:34 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
The gauge on the dash is pretty meaningless. I bet it takes a lot longer than 4 miles to actually be up to temp. My car in cold weather (that has a REAL oil temp gauge) can take HOURS to get up to full operating temp at highway speeds.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703375
03/22/18 03:49 PM
03/22/18 03:49 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
A 1.9 Escort that I look after kinda does that too
As long as your not gaining/losing oil or coolant, you'll be fine
It's those valve seats you should worry about
www.feoa.net can help you with all your Escort/Tracer needs
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: White pasty substance on dipstick [Re: 2009Edge] #4703376
03/22/18 03:49 PM
03/22/18 03:49 PM
workbench CZ-USA KS KC
Marco620 Online happy
Marco620  Online Happy
I like the 150 mile idea better. 4K RPM and 80MPH FTW drive Besides this is Bitog,we like driving our cars. No ecomodder's on here, I hope confused
15' Civic 1.8 i-vtec 229,500 mi Redline oil & M1 3:1/BP transmax cvt fluid & Archoil9100
Say no to drugs, union made cars and amsoil.
Son of a Navy Corpsman. Support vets!
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703389
03/22/18 03:58 PM
03/22/18 03:58 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I wouldn't willy-nilly go for a 150 mile ride just to bake the oil. The money wasted on gas would be better spent on an early oil change.
Re: White pasty substance on dipstick [Re: Weezybabydoll] #4703411
03/22/18 04:15 PM
03/22/18 04:15 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Sure, the coolant gets up to temp, but I'd guarantee your oil does not get hot enough in 4 miles to cook off the entrained water. My wife's Odyssey did the same thing, and even a half-hour drive wasn't enough to take care of it. You need a long, 50-60 mile trip that will let the oil get as warm as it can in regular use to cook off the condensate. I short-changed the oil because it had nearly filled the area underneath the fill cap.
