White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
29 registered members (billt460, claluja, c502cid, carlprop, Black_Thunder, Blkstanger, 3 invisible), 851 guests, and 33 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
Draining water heater - tips? #4702114
03/21/18 02:38 PM
03/21/18 02:38 PM
El Oeste
HawkeyeScott Offline OP
El Oeste
Had a new water heater installed last March. Ready to do the first drain on it. Any tips for doing so?
We have very hard water here. The house we bought had an old water heater when we first moved to this region a few years back. It was clanking so I never drained it. Now, with the new one, I will as a means of getting the minerals out.
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702125
03/21/18 02:47 PM
03/21/18 02:47 PM
SE Ohio
MuzzleFlash40 Offline
SE Ohio
I had to change the lower heating element in mine when we moved in, I hooked the garden hose to it and drained it out in the ditch. Took about 15 minutes.
18 Sonata SEL 2.4-12k
Syntec 5w30 & OEM
16 Santa Fe Sport AWD 2.4-67k
PP 5w30 & OEM
09 Silverado LT 4x4 4.8-104k
ST HM 5w30 & Fram
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702126
03/21/18 02:48 PM
03/21/18 02:48 PM
VA
Gebo Offline
Gebo  Offline
VA
Garden hose to the outside.
'98 LEX LS400 280K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702158
03/21/18 03:04 PM
03/21/18 03:04 PM
NJ
JLawrence08648 Offline
NJ
I like to drain it and then leaving the flush valve open, turn the inlet valve on and course hoping to dislodge any particles on the bottom, then close the flush valve, open the inlet for a minute then turn it off and open the flush, then fill.
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702161
03/21/18 03:05 PM
03/21/18 03:05 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
When my 12 year old heater took a dump, I opened the spigot and nothing came out. I then blew some compressed air into the inlet, and it forced the sediment through the drain and starting draining.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702167
03/21/18 03:10 PM
03/21/18 03:10 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
I would also remove the cathode and put some pipe dope on it. Also inspect it to see him much it was eaten away during that year. This way it will be much easier to change and you will have a feeling how long it will last.
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
Re: Draining water heater - tips? [Re: KrisZ] #4702185
03/21/18 03:29 PM
03/21/18 03:29 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
I think you were referring to the anode rod. They're usually good for at least 3-4 years as most water heaters have a 6 year warranty. But it's a good idea to loosen it as a few wouldn't budge even with an 18 inch breaker bar. Had to add a 4 foot pipe to it in order to get them loosened.
Re: Draining water heater - tips? [Re: Wolf359] #4702193
03/21/18 03:34 PM
03/21/18 03:34 PM
KrisZ Offline
KrisZ  Offline
Yes anode, brain [censored] on my part. Thanks for catching that.
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702205
03/21/18 03:43 PM
03/21/18 03:43 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
I replaced the cheap plastic drain valve on my water heater with a pipe nipple and brass ball valve. A ball valve is less likely to clog with sediment because it has a large diameter, straight through opening. I hook a garden hose to the valve, run the garden hose outside, and open the valve for a minute. Then I am done till next year.
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702295
03/21/18 05:08 PM
03/21/18 05:08 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
You call it an anode? ...when I used to service boilers we called them cathodic protectors. Basically a zinc bar that sacrifices itself instead of the metal boiler being attacked. Check it and replace as needed it will help esp with the hard water.
Re: Draining water heater - tips? [Re: Kawiguy454] #4702315
03/21/18 05:25 PM
03/21/18 05:25 PM
KrisZ Offline
KrisZ  Offline
At least residential water heater literature refers to that rod and anode rod. From the chemical reaction POV, it may as well be a cathode, IDK, I used to remember that stuff.
In any case it's irrelevant, as long as you remember to check it periodically and change it when it's almost gone.
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702327
03/21/18 05:32 PM
03/21/18 05:32 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Scott, be careful in doing so. The plastic drain valves on residential water heaters are a cheap needle valve. They are pretty much intended as a one time only drain of the unit. The tiny orifice in them isn't big enough to pass much of anything and can jamb up with debris.
On my current 40g tall natural gas unit, the one time I used it, I couldn't get it to seat, then the body of the valve started leaking. When I tried to replace it, it broke apart, leaving the threaded part stuck in the tank. I had to saw at it with a hacksaw blade to get the stuck section out. I then replaced it with a brass hose bib looking deal, but like said above, I wish I had just used a short 3/4" pipe nipple and a 3/4" ball valve. This way you have a true ~3/4" opening that will REALLY get things moving and flush the tank.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Draining water heater - tips? [Re: Kawiguy454] #4702368
03/21/18 06:16 PM
03/21/18 06:16 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
That's what they call them in the stores:
https://www.comfortgurus.com/water-heater-parts/7434-rhe-sp11526c-4-pk.html
Re: Draining water heater - tips? [Re: Gebo] #4702465
03/21/18 07:33 PM
03/21/18 07:33 PM
Fly-over country
zuluplus30 Offline
zuluplus30  Offline
Fly-over country
This. Once a year. My 6 year warranty Bradford White unit is going on year #13.
Re: Draining water heater - tips? [Re: HawkeyeScott] #4702482
03/21/18 07:50 PM
03/21/18 07:50 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
You're not supposed to drain it without turning the flame off first, correct? ???
