Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (c502cid, alcyon, anndel, Bailes1992, Chris B., 4 invisible), 543 guests, and 56 spiders.
Topics286,442
Posts4,908,257
Members67,622
Most Online2,967
Mar 10th, 2019
Properly ventilating a Pole Barn #4701929
03/21/18 12:54 PM
03/21/18 12:54 PM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
Greetings!
I am looking to properly ventilate a large uninsulated 60x80 pole barn with a gravel floor that suffers from moisture issues due to the gravel floor, so it's not ideal for auto parking and storage. It's located in the midwest, so lots of temperature swings in the transitional months which covers everything inside with dew.
It has a suspended steel ceiling about 25 ft high that is open to the attic above around the parimiter via a ~12 inch gap, and a central 6x6 access hatch that is currently closed. The attic has the typical ridge vent and lower vents under the two overhangs of the roof. No other vents or fans are present unless I open a vehicle access door or turn a floor fan on.
How would you make due with the moisture coming out of the earth. (yes I would love to slab it eventually with vapor barrier) but until that time, what can I do?
I have ideas, but thought I would ask the community to make sure I head in the right direction.
Thanks!
SOHC
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Properly ventilating a Pole Barn [Re: SOHCman] #4701935
03/21/18 12:58 PM
03/21/18 12:58 PM
America
Alfred_B Offline
Alfred_B  Offline
America
drainage would be where I would look.
Re: Properly ventilating a Pole Barn [Re: SOHCman] #4701954
03/21/18 01:14 PM
03/21/18 01:14 PM
Monroe,CT
Bambam Offline
Bambam  Offline
Monroe,CT
I park outside on a dirt/gravel driveway, I put old conveyor belting down and park over that. It isn't the greatest, but keeps the moisture form the ground from bombarding the ungercarriage.
07 DMAX CC 4x4 ~ Synthetics in the driveline, Delo XLE 15w40 in the sump.
Dirt Bikes and a Harley for the summer!
Ski-Doo for the winter.
Re: Properly ventilating a Pole Barn [Re: Alfred_B] #4701968
03/21/18 01:32 PM
03/21/18 01:32 PM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
I have the front two corners drained into buried 6'' corregated tube at least 150 foot away and downhill. the back two drains are only drained about 20 ft away, but its still down hill as this is on the highest point on the property and has negative grade around it.
Re: Properly ventilating a Pole Barn [Re: Bambam] #4701969
03/21/18 01:34 PM
03/21/18 01:34 PM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
I could park on rubber matts or the like, but the cloud of humidity would still be all around. Would it still make a difference?
Re: Properly ventilating a Pole Barn [Re: SOHCman] #4701990
03/21/18 01:52 PM
03/21/18 01:52 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I have a coverall and have the same issue. My plan is to put HD vapor barrier under washed stone, basically preparing for a slab. I think this will help a bit but anytime you've got big temp swings with an unsealed building you will get condensation.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Properly ventilating a Pole Barn [Re: IndyIan] #4702000
03/21/18 02:02 PM
03/21/18 02:02 PM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
Would it be able to resist puncture when parking heavy vehicles on it?
I was hoping that something like a big wall mounted air mover exhaust fan mounted on one end pulling air from the opposite side would help reduce humidity buildup during the dew point swings. I was thinking both the fan and intake vent would be mounted just under the suspended ceiling to not interfere with the ridge/soffit vent system in the attic.
Re: Properly ventilating a Pole Barn [Re: SOHCman] #4702016
03/21/18 02:23 PM
03/21/18 02:23 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I ran into a black plastic material that I used for the floor of a fabric tent type of shed. After about 5 years the tent disintegrated but I left the fabric on the ground. Another 5 years later, exposed to the weather that stuff looks new. I'll get the name of it. I noticed it had yellow stripes on it but can't recall the brand name. You could lay that down and then put 6 inches of gravel on top.
If you want the job done right......do it yourself.
Re: Properly ventilating a Pole Barn [Re: SOHCman] #4702032
03/21/18 02:33 PM
03/21/18 02:33 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
I would install one of these turbines. Make sure it is not near a passive vent, otherwise it will pull air from that and render is useless. Cover some of the lower vents at the ridge of the roof and make vent holes near the floor and on the ceiling.
This should force air circulation throughout the whole garage.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Properly ventilating a Pole Barn [Re: KrisZ] #4702038
03/21/18 02:44 PM
03/21/18 02:44 PM
MICHIGAN USA
LEADED Offline
LEADED  Offline
MICHIGAN USA
For a barn that side he need about 4 units , might need above floor inlet air ducts to keep air moving .Provided its not heated all the time . Thats what my Son in law did work like a charm .
Re: Properly ventilating a Pole Barn [Re: Snagglefoot] #4702915
03/22/18 09:42 AM
03/22/18 09:42 AM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
Cool, sounds like durable stuff!
Re: Properly ventilating a Pole Barn [Re: KrisZ] #4702924
03/22/18 09:45 AM
03/22/18 09:45 AM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
Interesting, I think I would have to get rid of my ridge vent and other things like Leaded mentioned to make something like this work. I really like that they wouldn't burn electricity though.
Could these be used horizontally out the side of the building below the drop cieling, or would they need to be on an "L" pipe through the wall and pointed up?
Re: Properly ventilating a Pole Barn [Re: LEADED] #4702933
03/22/18 09:48 AM
03/22/18 09:48 AM
USA
SOHCman Offline OP
SOHCman  Offline OP
USA
Speaking of heating, I have heard that "heating" my barn can keep condensation at bay. At least keeping it above the outside temp with a wood burner or something.
Anyone have experience with heating an uninsulated pole barn?
Re: Properly ventilating a Pole Barn [Re: SOHCman] #4702939
03/22/18 09:50 AM
03/22/18 09:50 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I had a ridge vent installed when I had a new rof put in a few years ago. I took out three turbines. After three years I took the ridge vent off and put back three more turbines. Ridge venting is over rated. With the ridge venting the resin was driven out of 60 year old wood rafters and beaded up.
When using the turbines be sure to get ALL Aluminum and no steel. They spin much easier.
Lomanco makes them. www.lomanco.com
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Properly ventilating a Pole Barn [Re: SOHCman] #4703028
03/22/18 10:55 AM
03/22/18 10:55 AM
KrisZ Offline
KrisZ  Offline
You probably could, but their operation would be limited to the direction of the wind, as they would be shielded on one side by the building. Having them on top of the roof makes them operate with any wind direction, even if it's a slight breeze.
Since your attic is already vented, maybe running a metal duct straight down from the turbine to the ceiling would be a good idea and should not be that difficult to install.
Just throwing it out there as I never had or seen such a setup yet.
