4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
95 registered members (2010Civic, agpatel, 69Torino, Agnosto, 2015_PSD, 13 invisible), 1,671 guests, and 67 spiders.
Topics286,042
Posts4,901,372
Members67,551
Most Online2,967
Mar 10th, 2019
Wire brush for hub holes #4701723
03/21/18 10:20 AM
03/21/18 10:20 AM
Seattle, WA
spavel6 Offline OP
spavel6  Offline OP
Seattle, WA
I'm looking for a quality wire brush that would work to clean out the rust and corrosion on threads that lug bolts screw into. Not the bolt itself, but the hub side of things.
What do folks use?
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Wire brush for hub holes [Re: spavel6] #4701730
03/21/18 10:27 AM
03/21/18 10:27 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I use these things that my local hardware store sells. They don't last forever but seem to work for what you're describing:
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Wire brush for hub holes [Re: spavel6] #4701766
03/21/18 11:04 AM
03/21/18 11:04 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Round wire brush that fits on a cordless drill, easy, works well and fast.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Wire brush for hub holes [Re: spavel6] #4701775
03/21/18 11:11 AM
03/21/18 11:11 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
I've used a tap for ones in rough shape - then I hit the holes and bolts with a shot of pure zinc primer. Keeps them from corroding in the future and you get a nice, even feel as they screw in, so your torque setting is accurate.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Wire brush for hub holes [Re: Astro14] #4701790
03/21/18 11:20 AM
03/21/18 11:20 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
1) I use a small wire wheel on a cordless drill to clean everything I can.
The studs or the bolts' exterior threads, the hub itself, the hole in the wheel the hub goes into, the mating surfaces of the rotor and wheel.
It's amazing how much powder (corrosion) comes off.
2) What is pure zinc primer?
I was once given a spray can of zinc chromate (pale, pea green in color) to prime some aluminum.
An old airplane mechanic gave it to me.
I was told later that the stuff is no longer available.
Re: Wire brush for hub holes [Re: spavel6] #4701791
03/21/18 11:21 AM
03/21/18 11:21 AM
Seattle, WA
spavel6 Offline OP
spavel6  Offline OP
Seattle, WA
Is there a specific size you are using? I have 17mm lug studs, not sure what diameter of brush to get!
Re: Wire brush for hub holes [Re: spavel6] #4701824
03/21/18 11:42 AM
03/21/18 11:42 AM
Kira Offline
Kira  Offline
No specific size. I just set the drill down securely and use it as a "bench tool".
Cleaning any surface is just a matter of reaching it.
Buy the variety pack of wire wheels at Harbor Freight and wear eye protection as their cheap junk brushes fling wee wires all over the place.
I WISH I had cylindrical or conical brushes I could shove into the holes just to do the job completely.
Re: Wire brush for hub holes [Re: spavel6] #4701828
03/21/18 11:45 AM
03/21/18 11:45 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
You mean the heads of the bolts are 17mm, will be 12mm bolts.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Wire brush for hub holes [Re: Kira] #4701844
03/21/18 11:53 AM
03/21/18 11:53 AM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
just go to Amazon and google conical bottle brush. I just did and got over 200 hits. You can get nylon brushes but i suspect that copper/brass would remove rust alot better and not damage steel or cast iron.
Re: Wire brush for hub holes [Re: spavel6] #4701902
03/21/18 12:31 PM
03/21/18 12:31 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I was just [censored] about this lug style last weekend. hornets
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Wire brush for hub holes [Re: Kira] #4701977
03/21/18 01:42 PM
03/21/18 01:42 PM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Zinc chromate is hazmat...stay away from that stuff...
Hit up the paint aisle at your favorite hardware store - Rust-oleum makes it, for example. Sometimes called “cold galvanizing compound”.
https://www.amazon.com/RUST-OLEUM-7785-8...lvanizing+spray
32 Packard 15W40
05 MB S600 0W40 M1
Re: Wire brush for hub holes [Re: Astro14] #4702029
03/21/18 02:33 PM
03/21/18 02:33 PM
Seattle, WA
spavel6 Offline OP
spavel6  Offline OP
Seattle, WA
You just spray it into the holes and let dry? I'd be afraid it would seize even worse onto the bolts...
Re: Wire brush for hub holes [Re: Gimpy1] #4702034
03/21/18 02:38 PM
03/21/18 02:38 PM
Seattle, WA
spavel6 Offline OP
spavel6  Offline OP
Seattle, WA
Tried that. Didn't get any metal brushes, just plastic, which I assume will not be nearly as effective..
Re: Wire brush for hub holes [Re: spavel6] #4702223
03/21/18 04:58 PM
03/21/18 04:58 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
Harbor Freight sells bore brushes. Both ones use can use by hand and ones that attach to drill, even the ones you use by hand can probably fit on a drill too if you snip the end off and screw down the chuck. Kits come with different materials, brass if you don't want to take anything off except light rust or steel if you really want to go crazy.
https://www.harborfreight.com/6-piece-tube-brush-set-61923.html
https://www.harborfreight.com/engine-brush-kit-20-pc-69020.html
2015 Civic LX Coupe
Re: Wire brush for hub holes [Re: spavel6] #4702305
03/21/18 06:15 PM
03/21/18 06:15 PM
Southeastern, PA
Rick in PA Offline
Rick in PA  Offline
Southeastern, PA
Check out brushes used to clean gun bores. They are stiff wire brushes and may be available in the size you want.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
