1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
36 registered members (citationxeleven, billt460, Cornershop, c502cid, Ag76, 5 invisible), 950 guests, and 26 spiders.
Topics296,903
Posts4,961,303
Members66,997
Most Online2,688
Jan 19th, 2019
random overheat #4701511
03/21/18 06:26 AM
03/21/18 06:26 AM
San Diego, CA
joaks Offline OP
joaks  Offline OP
San Diego, CA
Hey guys, I need some feedback- the shop where I took my car is stumped.
Short version:
My 97 subaru 2.2 will overheat randomly when I come to a stop, but will return to normal once I get up to speed. The heater does not work at this time but will work otherwise. Everything else works.
Long version:
About a month ago I got a bubble in my radiator (overflow tank got too low). I refilled and burped. Worked fine but notice I had small leak in radiator. Got the radiator fixed.
Now the car will overheat but seems to happen only when I get off of the highway on my way to work in the morning (after about 20 min of driving). I brought the car to the shop. The car does not overheat in the hands of the guys at the shop, although I brought it in hot yesterday. They have checked:
Compression
Thermostat
fluid levels
Fans turning on
Heater core (based on something I found on another forum).
Water pump
Everything is fine. They do find if they let it run with the radiator cap open that occasionally bubbles will show up. Sometimes fairly big, sometimes tiny.
Current guess is hairline crack in head or head gasket but the issue there is that the bubbles are not consistent (I guess they are supposed to be consistent with head/head gasket issues) and the car passes all other tests.
I've had the car at the shop three times to try to figure this out and everyone is really stumped.
2011 Subaru Legacy
Re: random overheat [Re: joaks] #4701513
03/21/18 06:30 AM
03/21/18 06:30 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Do a pressure test on the cooling system.
CX5 Touring 2.5L :-)
Re: random overheat [Re: joaks] #4701518
03/21/18 06:32 AM
03/21/18 06:32 AM
out there
spasm3 Offline
spasm3  Offline
out there
Water pump vanes eroded?
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: random overheat [Re: joaks] #4701521
03/21/18 06:33 AM
03/21/18 06:33 AM
USA
mk378 Offline
mk378  Offline
USA
Heater does not work at idle means that there is a bubble in the engine. When you rev up the water pump is turning fast enough to slosh the coolant around. The bottom line is lack of coolant where it needs to be. Either there is a leak to the outside or a leaking head gasket.
A block tester can be used to see if the bubbles contain CO2. That means they came from the combustion chamber and you have a leak in the engine. The only symptom of small combustion chamber leaks is displacement of coolant and eventual overheating. There will not be noticeable loss of compression or steam from the exhaust. Subaru heads crack easily when run overheated.
Re: random overheat [Re: joaks] #4701529
03/21/18 06:39 AM
03/21/18 06:39 AM
New England
Virtus_Probi Offline
New England
Maybe the fans are intermittent or not spinning fast enough?
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: random overheat [Re: joaks] #4701531
03/21/18 06:41 AM
03/21/18 06:41 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
You can pick up a kit to test for the presence of combustion gas in the radiator to help diagnose a cracked head.
If you want the job done right......do it yourself.
Re: random overheat [Re: joaks] #4701535
03/21/18 06:43 AM
03/21/18 06:43 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Do they have a smog machine to test for hc in the coolant or at least the chemicle test?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: random overheat [Re: joaks] #4701536
03/21/18 06:43 AM
03/21/18 06:43 AM
San Diego, CA
joaks Offline OP
joaks  Offline OP
San Diego, CA
Thanks for the replies so far!
The fans work fine (tested different ways by different people)
Water pump is supposedly good.
As I look more online it looks like a really small head gasket leak. It passes the coolant system pressure check and compression test but somehow air is getting into the coolant system.
2011 Subaru Legacy
Re: random overheat [Re: joaks] #4701537
03/21/18 06:43 AM
03/21/18 06:43 AM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
Burp the system with a spill free funnel, then take it from there
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: random overheat [Re: joaks] #4701538
03/21/18 06:46 AM
03/21/18 06:46 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Its either air bound or probably has a bad head gasket. A exhaust sniffer will detect combustion gasses in the coolant or have them do a leak down test with the radiator cap off.
You say they fixed the radiator, did they nip off any tubes?
Re: random overheat [Re: joaks] #4701542
03/21/18 06:49 AM
03/21/18 06:49 AM
pennsylvania, usa
dlayman Offline
dlayman  Offline
pennsylvania, usa
My 03 Civic displayed exactly the same symptoms (other than the no heat at idle), and passed all the tests, including the test on the coolant. Head gasket. You could drive it around town all day with no problem, but take it on the highway and when you exited, the coolant temp would take off.
Re: random overheat [Re: mk378] #4701558
03/21/18 07:04 AM
03/21/18 07:04 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
As above, except you MIGHT not actually have an integrity problem. I got these symptoms after replacing the coolant and as of now it SEEMS to have been down to trapped air, despite running the engine with a large funnel in the radiator filler port several times.
Coolant was blowing out of the overflow tank in operation, which I thought was either combustion gases or steam from overheating.
Since testing for combustiontion gases may not be available here, my punk technology diagnostic trick attempt was to put a coolant-filled inverted plastic bag in the overflow tank, theory being steam wont show bubbles.
No bubbles, but also no more coolant loss, so it could just be that most of the trapped air is gone.
You might promote burping by applying negative pressure to the system.
Re: random overheat [Re: joaks] #4701590
03/21/18 07:33 AM
03/21/18 07:33 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
If the shop has a vacuum filler for cooling systems, try that, or, if you don't want to pay that labor, like someone above said, try the spill free funnel. Fill it, run the car and try to run in until the thermostat opens with the funnel attached. Then, let the car sit for several hours and as it cools the vacuum will pull coolant into the air bubble prone areas of the cooling system and the bubbles will escape. Do this with the heater on.
Re: random overheat [Re: joaks] #4701602
03/21/18 07:49 AM
03/21/18 07:49 AM
South Carolina
pcoxe Offline
pcoxe  Offline
South Carolina
I once had an intermittent fan motor that caused the problem you describe. Probably was a worn commutator brush sticking. It tested good too until I caught it in the act while parked.
Re: random overheat [Re: mk378] #4701688
03/21/18 08:53 AM
03/21/18 08:53 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Would heat not work with an eroded WP impeller too?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
