Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
Verizon FIOS direct connect HD local channels
by Vikas - 09/16/19 02:36 PM
Bentonite grease abrasive properties?
by berlyn - 09/16/19 02:19 PM
'13 Camry, ATF replacement
by parshisa - 09/16/19 02:02 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
72 registered members (A_Spruce, ArrestMeRedZ, aquariuscsm, Ag76, b1amgm47, 9 invisible), 1,456 guests, and 26 spiders.
Topics294,667
Posts5,064,150
Members69,303
Most Online3,532
Jul 30th, 2019
Power Washing Rims/Wheels? #4700686 03/20/18 01:21 PM
M
maverickfhs Offline OP
M
So recently acquired Acura has some crud/brake dust on wheels, not on all 4, but definitely on 2 of them.
Not going to mess with brake dust, was wondering power wash or something similar can be done?
https://www.youtube.com/watch?v=JL7FUrNxkr8
Has anyone tried it or can share some feedback? thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700700 03/20/18 01:32 PM
PimTac Offline
This stuff is considered one of the top wheel cleaners. Sonax Wheel Cleaner Full Effect.
http://store.sonaxusa.com/sonaxwheelcleanerfulleffect.aspx
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700710 03/20/18 01:36 PM
M
Motorsen Offline
M
Those wheels are polished and then protected by wax. Watch the water on the surface of the wheel. Power washing with soft pressure on a dirty rim without any protection will only remove the superficial dust and dirt. Not the stained grime. Also do NOT pressure wash your brake calipers unless you are going to take them apart for service in the very near future.
Motorsen
Re: Power Washing Rims/Wheels? [Re: PimTac] #4700766 03/20/18 02:08 PM
M
mcwilly Offline
M
I used a similar product by Sonax, may have been the older version. It still went on green then turned blood red. Interesting to watch, but I guess I was expecting a miracle. Elbow grease was still required.
2010 Subaru Sti 75,000km
2001 Toyota Echo 255,000km
Re: Power Washing Rims/Wheels? [Re: Motorsen] #4700770 03/20/18 02:10 PM
M
mcwilly Offline
M
What exactly gets affected in there? I usually give them a once over from the front.
Re: Power Washing Rims/Wheels? [Re: mcwilly] #4700793 03/20/18 02:30 PM
02SE Offline
Power washing anything with a seal, can be bad news. The high pressure water can make it's way past the seal, and contaminate whatever the seal is meant to protect. In the case of a brake caliper, the caliper piston seals keep road contaminants out, and the brake fluid in. If water is forced past those seals, the boiling point of the brake fluid will be reduced, and the piston and bore (assuming they aren't made from exotic materials, which most cars brakes aren't) will start to corrode. The contaminated brake fluid will perform poorly, and eventually the caliper will require a rebuild or replacement.
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700967 03/20/18 05:24 PM
rooflessVW Offline
What condition are your wheels in? Meguiar's Wheel Brightener is second to none but can damage any exposed aluminum. Sonax Full Effect as mentioned above works well. Iron X is another quality product.
I pressure wash my wheels every wash and they come clean with the assistance of one of the above products.
"Zed's dead baby, Zed's dead."
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700968 03/20/18 05:26 PM
M
M
Think I have Meguiar's laying around, will use it with regular water from a hose and see what happens.
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700975 03/20/18 05:33 PM
4WD Offline
Hard to remove brake dust (after car wash falls short):
1) baby oil soft rag
2) Dawn dish soap soft brush
3) car wash soap (with wax) soft brush
Re: Power Washing Rims/Wheels? [Re: PimTac] #4701048 03/20/18 06:58 PM
J
JC1 Offline
J
I purchased some of this at the Toronto Auto show recently. Works great on the steel wheels. A bit of scrubbing is needed. Can't wait to see what it does on Alloys.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4701063 03/20/18 07:08 PM
N
newbe46 Online Content
Online Content
N
Have you tried white vinegar? I used it once on a very caked up rim and it really works but I was told if done to often it will destroy the coating.
2003 E46 M3 Convertible
2004 Odyssey EX-L
2004 Impreza TS Wagon
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4701134 03/20/18 08:06 PM
E
eyeofthetiger Offline
E
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4701379 03/21/18 01:05 AM
T
ted s Offline
T
if a presure washer ruins a caliper it was already leaking brake fuild
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4701434 03/21/18 05:11 AM
F
Falcon_LS Offline
F
My favorite way to approach this is a wheel brush, an old piece of carpet cut in a square shape and Sonax wheel cleaner. I liberally spray down the wheels and wheel wells with the Sonax, and let it sit until it turns dark red. At that point, using the cut carpet, I clean the wheel wells until they are spotless and use the brush on the outer side to clean the spokes. Once it's all nice and dandy, pressure wash it off and repeat the process with Dawn dish washing soap. Has yielded pretty good results for me over the years.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: Power Washing Rims/Wheels? [Re: ted s] #4701794 03/21/18 11:22 AM
02SE Offline
Working as a Master Tech on consumer cars, I dealt with many instances of seals that had been breached by water directed at them from a pressure washer.
It is common knowledge among those that design or repair components with such seals.
