Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
113 registered members (Andy636, anndel, addyguy, aquariuscsm, 28oz, AandPDan, 10 invisible), 2,211 guests, and 54 spiders.
Topics296,731
Posts4,957,846
Members66,960
Most Online2,577
Jan 14th, 2019
Water pump OE or ? #4701180
03/20/18 07:41 PM
03/20/18 07:41 PM
IL
Ndx Offline OP
Ndx  Offline OP
IL
Hi Guys,
I need to replace thermostat on my Cayenne.
Thermostat I'm going with original one from Dealer.
Water pump choices
Dealer
Laso
Geba
Beck Arnley
Thx
Re: Water pump OE or ? [Re: Ndx] #4701183
03/20/18 07:44 PM
03/20/18 07:44 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
Beck Arnley or OE.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Water pump OE or ? [Re: Ndx] #4701188
03/20/18 07:46 PM
03/20/18 07:46 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Any part where there is even a minimum degree of difficulty changing it I find OE to be the best. I've been burnt once or twice over the years with aftermarket water pumps, thermostats, and sensors, I'd rather pay a bit more and get OE.
God Bless Our Troops
Re: Water pump OE or ? [Re: Ndx] #4701189
03/20/18 07:48 PM
03/20/18 07:48 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Geba. Should have a metal impeller.
"Zed's dead baby, Zed's dead."
Re: Water pump OE or ? [Re: Ndx] #4701196
03/20/18 07:53 PM
03/20/18 07:53 PM
South Carolina
eyeofthetiger Offline
South Carolina
Is Geba OEM?
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Water pump OE or ? [Re: Ndx] #4701210
03/20/18 08:05 PM
03/20/18 08:05 PM
IL
Ndx Offline OP
Ndx  Offline OP
IL
I don't think that GEBA is OEM .... or not sure....
I think company called GFM is couldn't find anything about them.
They all have metal impellers.
Re: Water pump OE or ? [Re: Ndx] #4701246
03/20/18 08:36 PM
03/20/18 08:36 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
OEM for waterpumps. They are a pain. 1 bad one and you lost all your savings.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: Water pump OE or ? [Re: Ndx] #4701342
03/20/18 10:43 PM
03/20/18 10:43 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
Unless the OEM pump has a plastic impeller like VW Jetta used to have.
1997 Maxima 192k, QSGB 5w30+QSUD 5w30 (2:1), PL14477
2004 Corolla 195k, VWB 5w20 + SSS 10w40, MGL4967
Re: Water pump OE or ? [Re: Ndx] #4701346
03/20/18 10:48 PM
03/20/18 10:48 PM
WI.
dblshock Offline
dblshock  Offline
WI.
VW for sure check ebay.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Water pump OE or ? [Re: Ndx] #4701425
03/21/18 03:12 AM
03/21/18 03:12 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Check FCP Euro before the dealer.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Water pump OE or ? [Re: Ndx] #4701505
03/21/18 06:15 AM
03/21/18 06:15 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
As others have posted, check the online parts houses for OE, if its PITA to change go with OE only.
Re: Water pump OE or ? [Re: Ndx] #4702186
03/21/18 03:29 PM
03/21/18 03:29 PM
sw ohio
willbur Offline
willbur  Offline
sw ohio
All Porsches that I am aware of use water pumps with composite impellers, which are known to disintegrate. Porsche engine modifiers/rebuilders recommend water pump replacement with OE (composite impellers) every 3 years, irrespective of mileage. OE water pumps are $300 (and up) and replacement every 3 years is crazy, IMO.I only put about 5K/year on it.
I use a Geba water pump with a cast iron impeller for my Porsche. Paid $65 for it last month. The OE pump was fine, but stories of early failure got me worried..
The prime reason for using an OE water pump with composite impeller is that should the impeller fall apart, or the bearing fail, the resulting shrapnel will not damage the block (only choke it with debris). A metal impeller would toast a $20k engine if its supporting bearing failed. One would have to be totally clueless or deaf to not notice a noisy bearing long before it failed and let the metal impeller contact the block.
Re: Water pump OE or ? [Re: Ndx] #4702417
03/21/18 06:51 PM
03/21/18 06:51 PM
Winnipeg MB CA
Number_35 Offline
Number_35  Offline
Winnipeg MB CA
My experience with an aftermarket water pump:
https://www.bobistheoilguy.com/forums/ub...ang#Post4697586
