Originally Posted By: maverickfhs
Originally Posted By: rsylvstr
Use berrymans B12 instead.
Double dose.
I am NOT an expert and just asking for clarity, I have seen on many moto forums they say that B12 can damage rubber components, like fuel line and all if it stayed for long?
Does it have any reality in it?
I have heard similar, but I don't know the basis/experience upon which the claims were made.
I do know this, however, a while back, I ran a high dose of B12 in my Fusion.. Tank was down to about 2 gallons, and I was driving home from work. Put about 1/2 a can of B12 in with it (roughly 7-8 oz, or approximately 4x the normal dose. Went through about 1.5 gallons of the 2 gal in there driving home from work. When I finally stopped at the gas station, I had about 9 miles left to empty (approximately). Filled the tank, bringing the remaining B12 dose down to well below recommended limits.
That was about 20,000 miles ago, and I have noticed an overall (albeit somewhat small) increase in the MPG I get in the car since. No ill effects otherwise.
One can of B12 is 15 oz, and they recommend using a full can for 15-21 gallons, and that if your tank has under 15 gallon capacity, dose at 1oz per gallon. If you do plan to run a higher dose in your bike, I suggest you insure you have a long enough drive ahead of you to burn through MOST of it, and then refill the tank to bring the dose down. If you stay under the 1oz/1gal ratio, you should be fine leaving it in.
