New Struts and Springs
by Mathew_Boss. 04/21/19 05:36 PM
Float chargers?
by buck91. 04/21/19 05:32 PM
Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
109 registered members (alphadog, AdditiveOCD, 2015_PSD, 53' Stude, 2009Edge, 14 invisible), 1,911 guests, and 29 spiders.
Topics287,855
Posts4,935,626
Members67,865
Most Online2,967
Mar 10th, 2019
Versatrak rear diff groan? #4701120
03/20/18 07:58 PM
03/20/18 07:58 PM
New Brunswick
55Test Offline OP
55Test  Offline OP
New Brunswick
So yeah, haven't posted here in a long while. My dad just got himself a 2006 Equinox (only 117kms/72700 miles) with Versatrak AWD which works a treat but makes a slightly uncomfortable groaning sound when activated such as when in deep snow. At no other time does the AWD system exhibit any noise. I assume this noise is similar to the noise you might hear when a limited slip diff has worn out fluid. Would that be the case even with only 727000 miles?
The total sum of everything I have learned from this website: ...Oil in engine, good!
Re: Versatrak rear diff groan? [Re: 55Test] #4701138
03/20/18 08:10 PM
03/20/18 08:10 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I don't have an Equionox but I can share my experiences with GM AWD. The front diff can "growl" on the highway as it starts to wear out. One time I used a universal ATF in the transfer case and it made a strange slipping sensation around corners. I put in the correct fluid and the problem went away. I also have to change the chain at some point. Its loose, i can hear it. Jumps when i pull hard. The only problem I had in the rear was a faulty u-joint, it would clunk through the gears.
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 109k Unk
Re: Versatrak rear diff groan? [Re: 55Test] #4701380
03/21/18 01:17 AM
03/21/18 01:17 AM
Staten Island, NY
michaelluscher Online content
michaelluscher  Online Content
Staten Island, NY
Perhaps a drain and fill of Versatrak + fluid is in order
I know Honda diffs can get noisy if they're due for fresh fluid
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Versatrak rear diff groan? [Re: 55Test] #4701414
03/21/18 03:37 AM
03/21/18 03:37 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
FWIW different car but my 2016 Challenger had a groan when going around sharp turns, so I drained and refilled the rear with 4 OZ. Lubegard additive and Synthetic 75W-90 oil. Groan went away. That being said, I agree with the others who say the fluid is worn out and/or needs the additive.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Versatrak rear diff groan? [Re: michaelluscher] #4701443
03/21/18 05:24 AM
03/21/18 05:24 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
+1 Owners manual calls for Versatrak in diffs and transfer case. Time for a change.
If you want the job done right......do it yourself.
