CVT Formulation for Multi-Vehicle CVT VOA
MolaKule
Staff member
Iowegia - USA
Elemental (in ppm) and Viscosity Characteristics:
Iron - 1
Boron - 350
Silicon - 6
Sodium - 4
Calcium - 570
Magnesium - 7
Phos - 758
Zinc - 5
Sulfur - 1120
Kinematic viscosity - 7.3 cSt@100C
Brookfield Visc (ASTM D2983) - 8654
PP -55F
VI - 188
FP - 410F
TAN - 2.55
Not shown of course are other oxidation inhibitors, base fluid types, Traction Coefficient modifiers, surfactants, ashless dispersants, etc.
Originally Posted By: benjamming
Which product is this? What type of CVT?
In your expert opinion, do the multi-vehicle formulations work well for CVT?
This is my formulation for a customer and is comparable to most Multi-Vehicle CVT formulae. Will cover Nissan NS-1 through NS-3 specificationa and others.
One has to check the PDS and labels to determine what vehicle fluids are covered.
So far, yes, this additive and base oil combination works well.
Not a CVT expert here have only driven one as a rental Nissan Sentra. I was under the impression that a CVT was like snowmobile belt drive and assumed it did not need fluid. It certainly does not have the friction plates in a standard or normal automatic transmission. What is the fluid needed for?
Here is a very good paper explaining the the types of CVTs:
https://www.sciencedirect.com/science/article/pii/S0094114X08001432
Originally Posted By: bulwnkl
CVTs in cars use chains, not belts.
They do come with belts. Jatco uses a specially designed metal belt. Subaru and some others use a chain.
Some CVT's are coupled to a Torque Converter (TC) and even Lock-Up TC's. So then a fluid is needed for it and to provide cooling, proper traction coefficients, and to prevent wear between the linking mechanism and the Variators.
Here is a post that may help that I made in the ATF, Differential, Trans, Brakes, P/S forum:
Quote:
Step-Shift ATF's and Friction Modification
The question of coverage has also been raised with the Dexron/Merc (Step-Shift) type fluids. If the Dex/Merc "Multi-Vehicle" ATF fluid has the proper friction modifier chemistries to support support a range of dynamic friction coefficients Mu(v), then they can provide a range of coverage and specifications.
Belt/Chain CVT's rely on another type of friction or coefficient of friction and that is called the, "Traction Coefficient."
This "Traction Coefficient" has to be within a certain range of values in order to properly transmit power and not let "slippage" occur, so special friction modifiers are part of the chemistry. The rest of the fluid contains base oils, Anti-Wear additives, and other components.
Now if the CVT fluid has the proper friction modifier chemistries to support support this range of "Traction Coefficients" then one fluid can cover Nissan NS-1 through NS-3 and other specifications.
As mentioned in other threads on ATF, whether it be for Step-Shift's or CVT's, ATF's are the most additized fluid in the automotive drivetrain because of these specialized friction modifiers.
Originally Posted By: spasm3
Lots of boron!! Is that for low temp anti-wear?
This Boron component is a Mutli-Functional Boron Epoxide.
Chain is another term for "metal belt."
Look at this again, Figures 1 and 2, there is a difference in construction and nomenclature:
So, then, we all agree that automotive CVTs use metal-on-metal parts, and that's why they use oils? I call them all chains. I'm not terribly precise in my terminology in this realm, I find.
No Problem bw.
The belt type contains those metal elements embedded within the belt, and full metal elements for the chain type.
Whether Belt or Chain type, you have two competing requirements going on inside a CVT.
You have metal-on-metal contact and the associated wear with both, but you also have the need to prevent slippage so you don't have any torque loss due to slipping.
Those competing requirements require a careful balance of various chemistries in order to accommodate these competing requirements.
OK. I service 2 Nissans. A 2016 Altima with 80K and a 2017 Sentra with 35K.
Both are Hertz vehicles.
Which fluid do you recommend?
I did 2 spill and fills on the Altima; factory fill was filthy (70K) now looks good.
Valvoline Synthetic CVT fluid.
Planning on servicing the Sentra soon.
T.I.A.
At 35k I would let the dealer do the maintenance using the correct Nissan CVT fluid (they have like 5 different flavors). It's not that there aren't better fluids out there, I just wouldn't want to jeopardize the drive-train warranty.
MolaKule, I'm just curious..
Are you able to measure for and duplicate traction coefficient modifiers?
Am I wrong in assuming that is the magic in CVT fluids?
