4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
86 registered members (4WD, 2010Civic, Agnosto, AlaskaMike, AdditiveOCD, agpatel, 9 invisible), 1,503 guests, and 69 spiders.
Topics286,042
Posts4,901,383
Members67,551
Most Online2,967
Mar 10th, 2019
Power Washing Rims/Wheels? #4700686
03/20/18 01:21 PM
03/20/18 01:21 PM
MURICA
maverickfhs Offline OP
MURICA
So recently acquired Acura has some crud/brake dust on wheels, not on all 4, but definitely on 2 of them.
Not going to mess with brake dust, was wondering power wash or something similar can be done?
https://www.youtube.com/watch?v=JL7FUrNxkr8
Has anyone tried it or can share some feedback? thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700700
03/20/18 01:32 PM
03/20/18 01:32 PM
PimTac Offline
PimTac  Offline
This stuff is considered one of the top wheel cleaners. Sonax Wheel Cleaner Full Effect.
http://store.sonaxusa.com/sonaxwheelcleanerfulleffect.aspx
Cannot see signatures any longer so it doesn’t matter.
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700710
03/20/18 01:36 PM
03/20/18 01:36 PM
Denmark
Motorsen Offline
Motorsen  Offline
Denmark
Those wheels are polished and then protected by wax. Watch the water on the surface of the wheel. Power washing with soft pressure on a dirty rim without any protection will only remove the superficial dust and dirt. Not the stained grime. Also do NOT pressure wash your brake calipers unless you are going to take them apart for service in the very near future.
Motorsen
Re: Power Washing Rims/Wheels? [Re: PimTac] #4700766
03/20/18 02:08 PM
03/20/18 02:08 PM
Canada
mcwilly Offline
mcwilly  Offline
Canada
I used a similar product by Sonax, may have been the older version. It still went on green then turned blood red. Interesting to watch, but I guess I was expecting a miracle. Elbow grease was still required.
2010 Subaru Sti 74,000km
2001 Toyota Echo 245,000km
Re: Power Washing Rims/Wheels? [Re: Motorsen] #4700770
03/20/18 02:10 PM
03/20/18 02:10 PM
Canada
mcwilly Offline
mcwilly  Offline
Canada
What exactly gets affected in there? I usually give them a once over from the front.
Re: Power Washing Rims/Wheels? [Re: mcwilly] #4700793
03/20/18 02:30 PM
03/20/18 02:30 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Power washing anything with a seal, can be bad news. The high pressure water can make it's way past the seal, and contaminate whatever the seal is meant to protect. In the case of a brake caliper, the caliper piston seals keep road contaminants out, and the brake fluid in. If water is forced past those seals, the boiling point of the brake fluid will be reduced, and the piston and bore (assuming they aren't made from exotic materials, which most cars brakes aren't) will start to corrode. The contaminated brake fluid will perform poorly, and eventually the caliper will require a rebuild or replacement.
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700967
03/20/18 05:24 PM
03/20/18 05:24 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
What condition are your wheels in? Meguiar's Wheel Brightener is second to none but can damage any exposed aluminum. Sonax Full Effect as mentioned above works well. Iron X is another quality product.
I pressure wash my wheels every wash and they come clean with the assistance of one of the above products.
"Zed's dead baby, Zed's dead."
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700968
03/20/18 05:26 PM
03/20/18 05:26 PM
MURICA
MURICA
Think I have Meguiar's laying around, will use it with regular water from a hose and see what happens.
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4700975
03/20/18 05:33 PM
03/20/18 05:33 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Hard to remove brake dust (after car wash falls short):
1) baby oil soft rag
2) Dawn dish soap soft brush
3) car wash soap (with wax) soft brush
Re: Power Washing Rims/Wheels? [Re: PimTac] #4701048
03/20/18 06:58 PM
03/20/18 06:58 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I purchased some of this at the Toronto Auto show recently. Works great on the steel wheels. A bit of scrubbing is needed. Can't wait to see what it does on Alloys.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4701063
03/20/18 07:08 PM
03/20/18 07:08 PM
Ontario, Canada
newbe46 Offline
newbe46  Offline
Ontario, Canada
Have you tried white vinegar? I used it once on a very caked up rim and it really works but I was told if done to often it will destroy the coating.
2003 E46 M3 Convertible
2004 Odyssey EX-L
2004 Impreza TS Wagon
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4701134
03/20/18 08:06 PM
03/20/18 08:06 PM
South Carolina
eyeofthetiger Offline
South Carolina
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4701379
03/21/18 01:05 AM
03/21/18 01:05 AM
Albany NY
ted s Offline
ted s  Offline
Albany NY
if a presure washer ruins a caliper it was already leaking brake fuild
Re: Power Washing Rims/Wheels? [Re: maverickfhs] #4701434
03/21/18 05:11 AM
03/21/18 05:11 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
My favorite way to approach this is a wheel brush, an old piece of carpet cut in a square shape and Sonax wheel cleaner. I liberally spray down the wheels and wheel wells with the Sonax, and let it sit until it turns dark red. At that point, using the cut carpet, I clean the wheel wells until they are spotless and use the brush on the outer side to clean the spokes. Once it's all nice and dandy, pressure wash it off and repeat the process with Dawn dish washing soap. Has yielded pretty good results for me over the years.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: Power Washing Rims/Wheels? [Re: ted s] #4701794
03/21/18 11:22 AM
03/21/18 11:22 AM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Working as a Master Tech on consumer cars, I dealt with many instances of seals that had been breached by water directed at them from a pressure washer.
It is common knowledge among those that design or repair components with such seals.
