Hello,
I have a 2007 Dodge Ram 1500 4x4 with the 4.7. When it is cold outside the truck can be slow to switch into and out of 4wd, but the big problem now is when I turn the switch from 4wd to 2wd, the 4wd light goes off pretty quick, but the truck will travel 1/2 mile or less and truck will thud real hard. It sounds and feels like the front driveshaft just broke. It's harder the faster you are going. It's hard enough where it's going to break something if it hasn't already. I'm thinking it's the 4wd actuator in the axle or transfer case electric motor in the side of the transfer case, but I really don't know.
Thanks
Thanks
