1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
32 registered members (Char Baby, Bailes1992, billt460, BobGoblin, Blkstanger, anndel, 3 invisible), 909 guests, and 32 spiders.
Topics296,903
Posts4,961,306
Members66,997
Most Online2,688
Jan 19th, 2019
Jack Points for 2016 Dodge Charger #4700347
03/20/18 04:30 AM
03/20/18 04:30 AM
Florida
SilverSnake Offline OP
Florida
After 50 years of jacking up cars and changing/rotating tires, I feel kind of stupid posting this. However, things have changed over the years and with the flimsy underside of unibody cars, one has to be very careful using a floor jack.
The owner's manual shows the jack points as the pinch welds just behind the front wheel and just in front of the rear wheels. While looking for jack pad adapters for the car, the vendors all seem to say the rear of the Charger already has jack pads. Perhaps they are the round objects just in front of the pinch weld slot in the photo but I can find nothing to confirm that. Anyone know??
Also, has anyone purchased and used pinch weld adapters for the front jack point on their cars? Most adapters are too long. The available pinch weld space in less than two inches. I custom made one out of a nylon bench block but thought there might be a better commercial option (perhaps a permanent install or magnetic). No luck so far. Any links?
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Jack Points for 2016 Dodge Charger [Re: SilverSnake] #4700357
03/20/18 04:48 AM
03/20/18 04:48 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
My car is much lower than yours and I have had many issues with jacking since I bought it. The so-called "jack points" are for DIY guys. The basic "frame" of the unibody is extremely rigid and can tolerate a jack anywhere along the side between the wheels. Those pads on the rear are excellent for jack pad placement also.
The notches at the pinch welds are for roadside tire changes. Since my car did not ship with a spare or a jack I have never used them.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Jack Points for 2016 Dodge Charger [Re: SteveSRT8] #4700368
03/20/18 05:07 AM
03/20/18 05:07 AM
Florida
Florida
So you have used the round objects just in front of the pinch weld slot in the photo to jack the rear of your car without a problem?
Re: Jack Points for 2016 Dodge Charger [Re: SilverSnake] #4700381
03/20/18 05:32 AM
03/20/18 05:32 AM
Georgia
AVB Offline
AVB  Offline
Georgia
I have seen those get bent by people running over stuff. They are only held on by a screw, just remember that when jacking. You don't want to jack it at an angle.
I lift them there everyday with a two post lift.
Re: Jack Points for 2016 Dodge Charger [Re: SilverSnake] #4700399
03/20/18 06:08 AM
03/20/18 06:08 AM
WI
HoosierJeeper Offline
WI
https://www.harborfreight.com/rubb
I use these on my '15 Cherokee along the pinchweld. For the jack, I use a block of wood on the jacking points, which looks just like the place where that rubber thing is, except I don't have the rubber thing.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Jack Points for 2016 Dodge Charger [Re: HoosierJeeper] #4700454
03/20/18 07:32 AM
03/20/18 07:32 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Originally Posted By: HoosierJeeper
bad link.
Re: Jack Points for 2016 Dodge Charger [Re: SilverSnake] #4700663
03/20/18 11:49 AM
03/20/18 11:49 AM
WI
WI
Re: Jack Points for 2016 Dodge Charger [Re: SilverSnake] #4700685
03/20/18 12:21 PM
03/20/18 12:21 PM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
yes. they also fit the lift pads on the two post lift in his garage.at my friends house perfectly
Re: Jack Points for 2016 Dodge Charger [Re: SteveSRT8] #4700738
03/20/18 12:46 PM
03/20/18 12:46 PM
Florida
Florida
That is good news. Thanks.
Re: Jack Points for 2016 Dodge Charger [Re: SilverSnake] #4700913
03/20/18 03:37 PM
03/20/18 03:37 PM
Florida
Florida
After hours of looking and talking directly with vendors it appears that the best option if you want to use the front pinch weld jack points might be the following (I ordered 2 of them and will let everyone know how they work).
https://zl1addons.com/collections/dodge-...ant=28542348481
