Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
97 registered members (andyd, alphadog, 53' Stude, 2015_PSD, 240_Ed, AdditiveOCD, 11 invisible), 1,887 guests, and 25 spiders.
Topics287,853
Posts4,935,592
Members67,865
Most Online2,967
Mar 10th, 2019
finally giving Motul 300V a try #4700332
03/20/18 03:36 AM
03/20/18 03:36 AM
Wiltshire, UK
bonjo Offline OP
bonjo  Offline OP
Wiltshire, UK
I tend to change my oil at 4000 miles interval (although honda recommends 8000) because of the low mileage I do.
I have alsway used a real full synthetic in my engines (not synth blend, technology...) and 10/50 grade (although honda recommends 10/30!).
So after my favorite brand & viscocity was discotinued, I switched to silkolene pro4+. I could not notice any difference to gearchange, nor fuel consumption until a year and 2000 miles later when I noticed the oil pressure light would stay on a split of a second longer on first cold start of the day.
At the last change I decided to change grade to 10/40 and switch to motule 300V. Here are my initial observation after 500 miles:
[/i] no change in fuel consumption
the oil pressure light now goes off almost immediately (even at close to freezing temperatures)
the engine cooling is not as good as 10/50: running temperature is the same but the thinner oil is very quick to heat up when moving slowly or stationary[i]
So I don't think the engine cooling is as good as 10/50 and I'll switch back to this grade at the next oil change although not to pro4+
Re: finally giving Motul 300V a try [Re: bonjo] #4700415
03/20/18 07:42 AM
03/20/18 07:42 AM
Slovenia EU
Kamele0N Online sick
Kamele0N  Online Sick
Slovenia EU
Now "thin oil" folks will be crazy smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: finally giving Motul 300V a try [Re: bonjo] #4700458
03/20/18 08:40 AM
03/20/18 08:40 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Most folks notice better cooling with thinner oil; 40 is not a thin oil by any means.
Which motorcar car and engine are you discussing?
1.5 Litre? Honda Jazz?
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: finally giving Motul 300V a try [Re: bonjo] #4700618
03/20/18 12:01 PM
03/20/18 12:01 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Also, you do realize that the oil is not heating up, it is carrying away the heat that is generated in the engine and therefore shows the oil is actually performing as designed. Unless the oil gets so hot that it cokes up or evaporates, it's doing what it should. Do you think Honda would recommend (and require) a 30 weight if it wasn't capable of protecting the engine?
Re: finally giving Motul 300V a try [Re: SubieRubyRoo] #4700688
03/20/18 01:23 PM
03/20/18 01:23 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
No, the majority of the heat the oil is because of internal friction in the oil. In other words it is self-generated and gets worse as the viscosity increases.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 410K
2000 Toyota ECHO, 280K
Re: finally giving Motul 300V a try [Re: kschachn] #4701869
03/21/18 12:08 PM
03/21/18 12:08 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
X2
One can notice this with air cooled OPE and an infrared gun.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: finally giving Motul 300V a try [Re: bonjo] #4712030
03/31/18 04:18 AM
03/31/18 04:18 AM
Wiltshire, UK
bonjo Offline OP
bonjo  Offline OP
Wiltshire, UK
This is related to motul motorcycle oil. the bike in question is cbr1000rr8 (runs between 76&82 centigrade in normal riding, winter~ summer)which gets up to 90~100 deg in slow traffoc.
by thinner I describe lower viscocity with high temp of 40 being less than that a 50.
This is my experience and I know it is not in line with what I was expecting! But my temperature guage doesn't lie frown
