Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
28 registered members (Atesz792, bmod305, Brad_C, Chesterr, carlprop, alcyon, 2 invisible), 684 guests, and 63 spiders.
Topics286,442
Posts4,908,225
Members67,622
Most Online2,967
Mar 10th, 2019
Pennzoil High Mileage Platinum 0w20 @ 63k Miles? #4700227
03/19/18 09:39 PM
03/19/18 09:39 PM
Missouri
David2431 Offline OP
Missouri
Am purchasing a used 2014 Rav4 from my daughter who bought it new.
I've always done the oil changes using Mobil 1 0w20 AFE and Toyota filters.
I can buy Pennzoil Platinum 0w20 in jugs from Walmart on clearance for $13.00.
Rebate knocks the cost down to $3.00. WOW!
Question is, how does it compare to the Mobil 1 and is it ok to use at "only" 63,000 and can I switch back to something else when the six jugs run out???
Re: Pennzoil High Mileage Platinum 0w20 @ 63k Miles? [Re: David2431] #4700231
03/19/18 09:40 PM
03/19/18 09:40 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
It's better wink
Re: Pennzoil High Mileage Platinum 0w20 @ 63k Miles? [Re: David2431] #4700233
03/19/18 09:41 PM
03/19/18 09:41 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
Yes you can switch back and forth between high mileage and regular. Pennzoil Platinum is every bit as good as Mobil One.
don't use.
Re: Pennzoil High Mileage Platinum 0w20 @ 63k Miles? [Re: David2431] #4700267
03/19/18 10:35 PM
03/19/18 10:35 PM
Texas
4WD Offline
4WD  Offline
Texas
You can switch back and forth from a half dozen of these found several brands on sale in the last few months
Re: Pennzoil High Mileage Platinum 0w20 @ 63k Miles? [Re: David2431] #4700298
03/19/18 11:27 PM
03/19/18 11:27 PM
workbench CZ-USA KS KC
Marco620 Offline
Marco620  Offline
If you run out of 0w20 PPHM I am only a state away lol. Its good oil. Its better than M1HM as it appears once you start using M1HM they kinda dont want you swapping off of it. Guess they got some good swell agents but just like the lil blue pill, doesnt do so well coming down. Kinda wish QSUD made a 0w20 HM formula. All in all, brand name synthetic from Pennzoil, Castrol, or M1 are all great.
15' Civic 1.8 i-vtec 222,222+ mi Redline oil/cvt fluid & Archoil9100
Just say no to drugs, union made cars and amsoil.
Son of a Navy Corpsman. Support vets!
Re: Pennzoil High Mileage Platinum 0w20 @ 63k Miles? [Re: David2431] #4700519
03/20/18 09:57 AM
03/20/18 09:57 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I only use HM oil to solve an issue with leaks or valve seal oil consumption. I believe there is truth to that Stuart Goss video etched in my brain. Its not worth the 3 dollars to age the valve seals. Puff them up so they wear prematurely. My opinion.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Pennzoil High Mileage Platinum 0w20 @ 63k Miles? [Re: David2431] #4700622
03/20/18 12:04 PM
03/20/18 12:04 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
There has been chatter on the board that since the HM oils have more of the "good stuff" to help out engines with high miles, there is no real reason you couldn't start using it after draining the factory fill. Plus, since you're talking Pennzoil, looking at their HMs you can see their version is counter to tribal knowledge- the HM versions are actually a hair thinner than the normal ones.
