Interesting video, but has some issues.
1) They use stupid statements like "the oil pump puts out over twice the pressure that you would find in the race tires" ... huh? Why not just say at what PSI the oil pump operates at.
2) When talking about the load in the rod big end bearings, why not just say 76,500 PSI instead of "5000 times more than atmospheric pressure"? I'm surprised they didn't work in a "fortnight" in there somewhere.
3) They said the oil filter is catches 95% of all particles below 10 microns. I find that on hard to believe, and think they actually meant all particles above 10 microns.
4) They said the entire oil system circulated once every 8 seconds. Earlier they said the system held 5 gallons and the oil pump was running at 12 GPM. With those parameters, 5 gallons would circulate once every 25 seconds.
