Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
36 registered members (claluja, CR94, carlprop, c502cid, bbhero, Brad_C, 3 invisible), 808 guests, and 58 spiders.
Topics286,170
Posts4,903,526
Members67,572
Most Online2,967
Mar 10th, 2019
Low oil pressure code when following the olm #4700142
03/19/18 08:04 PM
03/19/18 08:04 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
On my wife 13 dart her oil life monitors seems to go about 7,000-7,500. We have been running synpower 5w40 if we follow the olm it will throw a code for low oil pressure. I saved the code I thought on Alfa obd but now I can’t retrieve it. But it was a multi air vva code and the most common cause was low or dirty oil. The oil wasn’t ever low and we just were following the olm. My 2.4 has never done this but her 1.4 does. When the oil is changed it’s fine so the logical thing would be change it sooner. But is there a different oil that would hold up better? Or another reason it would do this? Any thoughts is appreciated.
2014 dodge dart GT
1995 Dodge ram 1500
Re: Low oil pressure code when following the olm [Re: ram_man] #4700147
03/19/18 08:06 PM
03/19/18 08:06 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Could simply be a failing sensor. You should have seen the oil pressure gauge on my Mustang when the sender started going bad, LOL! It was hilarious.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: Low oil pressure code when following the olm [Re: ram_man] #4700163
03/19/18 08:23 PM
03/19/18 08:23 PM
MN
oil_film_movies Offline
MN
Sounds a little like the codes thrown for Dodge Chrysler Hemi engines when viscosity gets too low (fuel dilution would do that). P1521 on those Hemi's.
Her Dart's code could be P106B-00-CYLINDER 4 OIL SUPPLY SOLENOID VALVE SWITCH ON TIME OUT OF RANGE, which might be low viscosity at the end of the oil change interval.
Possible causes:
•LOW ENGINE OIL
•INCORRECT OIL FILTER THAT DOES NOT MEET OEM SPECIFICATIONS
•OIL DIRTY OR DETERIORATED (Lack of scheduled oil changes)
•CORRECT VISCOSITY AND WEIGHT
•ENGINE OIL CONTAMINATED (i.e., coolant and/or fuel)
Re: Low oil pressure code when following the olm [Re: ram_man] #4700171
03/19/18 08:32 PM
03/19/18 08:32 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Plugged screen below the oil sensor on GM V-8’s.
If you want the job done right......do it yourself.
Re: Low oil pressure code when following the olm [Re: ram_man] #4700172
03/19/18 08:32 PM
03/19/18 08:32 PM
MN
MN
That said, it could be anything, not just low viscosity. The on-board computer monitors hydraulic pressure in the Multi-Air fluid paths, and when the solenoids activate, pressure must rise fast enough. If not, as in when the hydraulic oil circuit has junk in it, you can get the code thrown.
Re: Low oil pressure code when following the olm [Re: ram_man] #4700234
03/19/18 09:48 PM
03/19/18 09:48 PM
Iowa
Iowegian Offline
Iowegian  Offline
Iowa
You might check for any software updates for the olm.
Personally, i don't bother with the olm.
It is most likely the viscosity. (Oil thinned out) possible due to fuel leakage. But most likely the 1.4 turbo is just hard on oil and you will need to change oil at 5,000 miles instead.
Get a UOA next oil change to find out.
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: Low oil pressure code when following the olm [Re: oil_film_movies] #4700268
03/19/18 10:36 PM
03/19/18 10:36 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Think the ECU is detecting a multiair reaction time (plotted against a known or measured temp/viscosity curve) and is noticing that it's changed past a threshold during the course of this OCI, due to a possible change in oil viscosity? This is to assume that the ECU relearns a viscosity curve (perhaps based on temp/reaction time) after each OLM reset. As advised, a UOA may shed some light
There's no replacement...'scosity for natural viscosity
Re: Low oil pressure code when following the olm [Re: PeterPolyol] #4700517
03/20/18 09:56 AM
03/20/18 09:56 AM
MN
MN
No relearning happens necessarily. It might. All they need is a fixed threshold, like "Trip the fault code if the pressure sensor sees less than 14 psi at 300 milliseconds after the solenoid pops open." Fiat-Chrysler engineers might know that indicates something is wrong.
Re: Low oil pressure code when following the olm [Re: ram_man] #4700598
03/20/18 11:34 AM
03/20/18 11:34 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Low oil pressure code when following the olm [Re: ram_man] #4700611
03/20/18 11:47 AM
03/20/18 11:47 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Pages 124-128 all faulty codes...
Re: Low oil pressure code when following the olm [Re: Kamele0N] #4700617
03/20/18 12:00 PM
03/20/18 12:00 PM
MN
MN
Originally Posted By: Kamele0N
Wrong engine. This discussion is about the Multiair variant. Pressure sensor in the valve actuation unit is the one discussed here, not a generic oil pressure sensor on the filter-pump path.
Re: Low oil pressure code when following the olm [Re: ram_man] #4700619
03/20/18 12:03 PM
03/20/18 12:03 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Aha ok... Try to edit that link by hand to ...manuals\
Maybe there be more manuals smile
Re: Low oil pressure code when following the olm [Re: ram_man] #4700651
03/20/18 12:30 PM
03/20/18 12:30 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Maybe give the Castrol 0W40 a try?
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
