2019 Subaru Crosstrek FB20D - Oil choices
by cluster5. 03/26/19 09:31 PM
.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
79 registered members (advocate, alcyon, bbhero, 4WD, 555, 2015_PSD, 9 invisible), 1,699 guests, and 108 spiders.
Topics286,477
Posts4,909,138
Members67,635
Most Online2,967
Mar 10th, 2019
Generator Maintenance #4700105
03/19/18 07:38 PM
03/19/18 07:38 PM
FL USA
doolah02 Offline OP
doolah02  Offline OP
FL USA
I was wondering how often should I exercise my generators. How long
should I let them run?
Re: Generator Maintenance [Re: doolah02] #4700109
03/19/18 07:40 PM
03/19/18 07:40 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
any hints on what type or size? 50KW diesel, 2KW hamster driven?
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Generator Maintenance [Re: doolah02] #4700125
03/19/18 07:52 PM
03/19/18 07:52 PM
N.C.
gman2304 Online content
gman2304  Online Content
N.C.
I have a 7,500 watt Troybilt with a 10 HP Briggs. I exercise it with a load for about an hour every 4 months or so. Ive had it for about 10 years and never had a problem. YMMV.
Re: Generator Maintenance [Re: doolah02] #4700131
03/19/18 07:57 PM
03/19/18 07:57 PM
New England
gathermewool Offline
New England
I run my 2kW WEN generator every few months:
1. Idle 5 min to warm up
2. Add half load for 5 min
3. Full load for 10 min
4. 5 min cool-down
5. Off
I haven't had any issues, but my genny is still pretty much a baby, since I haven't had to use it very often, luckily.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Generator Maintenance [Re: doolah02] #4700137
03/19/18 08:02 PM
03/19/18 08:02 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I would load test every 6 months. Both legs of 220v. I would run the generator dry on blue Stabil and E0 gas.
If your really serious about having a reliable generator then it would be a propane generator, not gasoline.
2015 Ford F250 w/Powerstroke
Re: Generator Maintenance [Re: doolah02] #4700141
03/19/18 08:04 PM
03/19/18 08:04 PM
Texas
Bud Offline
Bud  Offline
Texas
I run mine for 30 minutes monthly, with a load.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: Generator Maintenance [Re: doolah02] #4700208
03/19/18 09:11 PM
03/19/18 09:11 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Every 6 months for 20 mins
Start, warm up, load to about 2/3 or 3/4 of running capacity (not MAX load)
Run at no load 2-3 mins
shut off fuel...... run until carb is dry.
Re: Generator Maintenance [Re: doolah02] #4700353
03/20/18 05:46 AM
03/20/18 05:46 AM
Monroe,CT
Bambam Offline
Bambam  Offline
Monroe,CT
One hour load test every other month.
07 DMAX CC 4x4 ~ Synthetics in the driveline, Delo XLE 15w40 in the sump.
Dirt Bikes and a Harley for the summer!
Ski-Doo for the winter.
Re: Generator Maintenance [Re: Linctex] #4700441
03/20/18 08:12 AM
03/20/18 08:12 AM
Canada
boraticus Offline
boraticus  Offline
Canada
As above is likely sufficient.
I leave my Yamaha EF2000is for six months of the year for winter storage. I fill the tank, shut the air intake off, shut the fuel off and let it run until it stops to drain the carb. In the spring, I open the air to the fuel tank, turn on the fuel, give it a couple pulls and away she goes.
Re: Generator Maintenance [Re: Bambam] #4700446
03/20/18 08:20 AM
03/20/18 08:20 AM
FL USA
doolah02 Offline OP
doolah02  Offline OP
FL USA
I have a 20 year old 10 hp Briggs 5000 watt and a 10 year old Powermate 10 hp Subaru 5000 watt.
I usually run them once a month for 20 or 30 minutes.
Re: Generator Maintenance [Re: doolah02] #4701043
03/20/18 06:51 PM
03/20/18 06:51 PM
Wisconsin
Mr_Joe Offline
Mr_Joe  Offline
Wisconsin
Id want non ethanol fuel in the gassers, maybe add some stable at times too.
Re: Generator Maintenance [Re: doolah02] #4701598
03/21/18 08:45 AM
03/21/18 08:45 AM
Pennsylvania
Astro_Guy Offline
Astro_Guy  Offline
Pennsylvania
I start mine up every month or so and let it run without load for maybe 15 minutes before shutting the fuel valve and running the carburetor dry. If it doesn't get a real workout after 4-6 months, then I hook it up to the the transfer switch and run it under load for at least thirty minutes. That hasn't been a problem this winter, having used it continuously for more than four hours once this month already.
'01 Volvo V70XC, 236k, 10W-30 M1 High Mileage
'16 Accord, 28k, 0W-20 M1 EP
Re: Generator Maintenance [Re: doolah02] #4702069
03/21/18 03:06 PM
03/21/18 03:06 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
I purchased a new Briggs & Stratton 5500 watt Storm Responder generator in 2012, it was manufactured in 2010. About every 3 months I run it for approx 1 hour with a total 3000 watt load balanced between the 2 circuits. It runs great and produces the power needed with no issues. I installed a transfer switch and when using that I have no problem with using our tv or computers.
Whimsey
Re: Generator Maintenance [Re: Whimsey] #4702071
03/21/18 03:07 PM
03/21/18 03:07 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Whimsey
About how much did that run you if you don't mind me asking kind sir gentlemen?
Re: Generator Maintenance [Re: doolah02] #4702434
03/21/18 08:05 PM
03/21/18 08:05 PM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
I have a Generac 20KW fully automatic whole house generator. It starts and runs itself once per week for 12 minutes. That is the factory default time interval and duration and I did not change it. Gets all service as specified in the manual. Must be the correct formula because it has performed flawlessly for almost 10 years. Came in particularly handy during Irma. Power was out at our house for about 45 seconds (that's the time set to auto start). It was kind of nice being the only house in the vicinity with A/C, lights, hot water, hot food, and cold beer.
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
