6.0L powerstroke towing with 10w30
by mattd. 05/24/19 11:12 AM
Equinox 2.4L Oil change & questions.
by GaryPoe. 05/24/19 11:06 AM
Need a high zinc oil
by tutermoe. 05/24/19 10:50 AM
Help idtentify oil filter please
by 1978elcamino. 05/24/19 09:51 AM
Raptor liner/1995 Tahoe/Before & After
by Vladiator. 05/24/19 09:30 AM
Our Camry is back!
by tomcat27. 05/24/19 09:12 AM
Mobile dog grooming business ?
by Mr Nice. 05/24/19 08:00 AM
Tire balancer question
by supton. 05/24/19 07:56 AM
Ready for the Indy 500?
by shanneba. 05/24/19 05:31 AM
SKF grease with graphite
by PreludeDenarius. 05/24/19 03:42 AM
Quaker State Ultimate Durability 5W-30: $17.97 at WM
by The Critic. 05/24/19 01:31 AM
AT-205 Re-Seal for 1968 VW Bus?
by ZraHamilton. 05/24/19 01:22 AM
Can 5W-30 be Thicker than 10W-30?
by John344. 05/23/19 10:33 PM
Fastenal new policy-unhappy
by rekit. 05/23/19 10:23 PM
0w30 Showdown of European Oils
by Marco620. 05/23/19 10:12 PM
amazon basics 5-40 not as good
by benjy. 05/23/19 09:28 PM
Tina70, tongboy1, PersonaPriusDad, MetricMike, Harps
68195 Registered Users
118 registered members (928, 53' Stude, AZjeff, 1978elcamino, Alfred_B, 1WildPig, 9 invisible), 2,099 guests, and 22 spiders.
Topics289,336
Posts4,967,345
Members68,195
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
VW 2.5L and 502 Approved Oils #4699714
03/19/18 01:01 PM
03/19/18 01:01 PM
Olathe, KS
CARJ Offline OP
CARJ  Offline OP
Olathe, KS
Before getting married and buying my first German car, I had never heard of buying specific oil (other than weight) for a car. Can you all explain to me why a certain 5w-30 is approved and some aren't? This is a non turbo, inline 5 car, out of warranty. What is different about the oil? What is the harm in running a non 502 approved oil?
2004 Toyota 4Runner | 187k | M1 0w-30, YZZD3
2012 VW Passat | 90k | Liqui-Moly 5w-40, Hengst
1997 Honda Civic HX | 220k | M1 0w-30, PH3593a
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699723
03/19/18 01:18 PM
03/19/18 01:18 PM
GA
drtyler Offline
drtyler  Offline
GA
Increased wear and deposits.
VW 502 oils are readily available - Mobil 1 0W40 and Castrol Edge 0W40 or 5W40 are at Wal-Mart for good prices.
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699724
03/19/18 01:19 PM
03/19/18 01:19 PM
Colorado Springs
edyvw Online content
edyvw  Online Content
Colorado Springs
If you search on Google that you will get thousands of results.
In short: Euro specific oils have higher HTHS, stay in grade requirements, lower oxidation and NOACK. Generally they are more stringent and usually developed from better base oils.
IMO best Euro specific oil for Euro gassers that is readily available? Castrol 0W40 available in Wal mart.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699727
03/19/18 01:22 PM
03/19/18 01:22 PM
Olathe, KS
CARJ Offline OP
CARJ  Offline OP
Olathe, KS
But why? Most here would say Mobil 1 EP 5w-30 is a good oil. Not 502 approved. What makes it fine for a Toyota engine but not okay for a VW engine? How would it cause more wear and deposits?
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699737
03/19/18 01:29 PM
03/19/18 01:29 PM
Colorado Springs
Colorado Springs
But research! Numerous topics on this. Literally thousands!
It is manufacturer requirement. EP is simply not stringent as let's say Mobil1 0W40. Manufacturer sets requirements based on their demands (which on Euro cars usually is connected to high strains and speeds). When VW develops engines it does not develop with Kansas in mind but with Auto Bahn in mind, and those are different requirements.
By the way, Toyota also recommends heavier oils for Europe, mostly ACEA A3/B3 B4 for gassers and ACEA C3 for diesels.
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699743
03/19/18 01:34 PM
03/19/18 01:34 PM
GA
drtyler Offline
drtyler  Offline
GA
The 502 spec is built around ACEA A3 specs plus VW's own specs and wear tests, and requires the traits mentioned by edyvw above.
The M1 EP 5W30 doesn't meet all of those standards. It was not tested or approved by VW. If you want to run it in your car and tell us the results, go for it.
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699747
03/19/18 01:38 PM
03/19/18 01:38 PM
New Mexico
Saul Offline
Saul  Offline
New Mexico
It seems like you want someone tell you using a non 502 oil is all fine and dandy. Why is this so important? It has already been said you can find the 502 stuff at walmart right next to the other stuff....
Also, Pennzoil 0w-40 euro is on clearance at walmart for $10 and is 502 approved...
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699748
03/19/18 01:40 PM
03/19/18 01:40 PM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
I believe that VAG was experiencing engine sludge problems when they extended oil change intervals. Their response was:
1. VW 502 spec
2. Increased capacity oil filters, which also increase engine oil capacity
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699751
03/19/18 01:42 PM
03/19/18 01:42 PM
Olathe, KS
CARJ Offline OP
CARJ  Offline OP
Olathe, KS
I'm just curious as to why some oils are okay and some aren't even if they are the same weight.
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699771
03/19/18 02:11 PM
03/19/18 02:11 PM
California
Bullwinkle007 Offline
California
The us uses thin and light oils, Europe likes heavier weight oil, light weight oil is for fuel economy, ACEA spec is way better than API, read into it, way more demanding, also in Europe, to call an oil synthetic, it must be made with a PAO group IV, not group III, so to get euro spec synthetic, it must meet those mfg specs. Even Honda in Europe calls for acea a3/b4. Only use 0/20 for fuel economy or use 0/30, 5/40 or a 0/40
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699825
03/19/18 03:05 PM
03/19/18 03:05 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
CAFE credits.
The automakers can sell CAFE credits and profit by them. Every 1/10 of 1 MPG counts. The profits are real.
The automakers must be careful by specifying and recommending the same oil viscosity used in testing.
They cant use a 0W20 during the test procedure and print in the owners manual this car requires 5W30.
VW historically didn't play the CAFE credit game in the USA like the others did.
BTW CARJ, I was a technician at a Honda dealer when your Civic HX came out. You have a rare keeper. They got great gas mileage with the 5 speed and
felt faster than the EX model despite having less HP. The rare CVT HX had a short transmission lifespan and most have long been in the junkyard.
Me: 13' VW GTI 3 door 6 speed manual
Re: VW 2.5L and 502 Approved Oils [Re: Bullwinkle007] #4699868
03/19/18 03:29 PM
03/19/18 03:29 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Please tell us what brand of oil is PAO? We will be waiting.
2007 Ford Fusion 242,000 miles
M1 0-20 EP
2017 Ford Fusion 70K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699880
03/19/18 03:40 PM
03/19/18 03:40 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
I always assumed that it was for drain interval, and so specified a quality oil. Audi pretty much said "If you run an oil that is good enough to meet this spec, and you are on time with your intervals, you wont have issues for the lifetime of the car" So if youre running shorter intervals, or have some way of measuring how well the oil is holding up, then I wouldnt worry so much. One of my employees runs our cheaper Cam2 5/30 Semi syn in his 03 1.8t A4, and saw no issues with 5k intervals. I ran it in a friends 2006 BMW 325i and they recommended a 7500 interval with a recheck. He only went 6 or so, no issues what so ever. I have also seen Audis that push the interval with 502 oil and have had no serious issues. A customer of ours HAD an 07 A4 2.0t from new that saw about 45k a year. Everytime he came in hed be 1500-3k over the 10k interval, rarely adding oil. He made it to 290k before it overheated on his commute one day. So their spec isnt so bad for absolute bare minimum needed.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699897
03/19/18 03:55 PM
03/19/18 03:55 PM
South Wales, UK
Bailes1992 Offline
Bailes1992  Offline
South Wales, UK
VW 502/505 is a specifcation that builds on ACEA A3/B4.
Most oils that meet ACEA A3/B4 or ACEA C3 meet VW 502/505. They're very easy oils to find.
As long as the engine oil you pick is of a similar viscosity and has a HTHS of 3.5 or more I doubt you would see any immediate issues, if any long term providing the OCI is reigned in a bit.
However, as I said above VW 502/505 oils are cheap and easy to find. So why bother with anything else?
'17 Volvo V40 D3 Geartronic - Castrol Edge 5w30 LL
'19 Dacia Sandero 0.9T - Shell Helix Ultra 5w40
'96 LR Defender 300TDi - Morris Lubricants HD4 15w40
'12 BMW 320d Sport Auto - Fuchs GT1 5w40
Re: VW 2.5L and 502 Approved Oils [Re: CARJ] #4699918
03/19/18 04:25 PM
03/19/18 04:25 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
M1 ESP has lower TBN (and lower additive levels) not suitable for U.S. gasoline engines.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Page 1 of 5 1 2 5
