Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
129 registered members (4WD, 69Torino, AdditiveOCD, 2015_PSD, 2K2AcuraTL, 11 invisible), 1,699 guests, and 48 spiders.
Topics296,749
Posts4,958,204
Members66,964
Most Online2,577
Jan 14th, 2019
Intermittent cold crank, no start 2001 Neon #4699284
03/19/18 02:07 AM
03/19/18 02:07 AM
Ontario, Canada
heyleescomet Offline OP
Ontario, Canada
Been battling this issue for a 2 years. 2001 Dodge Neon R/T
When warm it starts everytime, even warmer weather infact, cold start it may take 2 tries or even several to get started.
Shot of ether in the intake then engine would start and stay running just fine. Fuel pump had been noisier the past couple years so I put a new denso unit in, quite an easy job in these cars. Even more so with only 2gal or gas in it
This didnt resolve the issue, next was checking the crank sensor and the wiring. Good power and ground at the connector, turning the engine by hand I could see the 5 volt return signal turning on and off. Granted this doesnt mean its good but I carried on to the next thing as I dont have the equipment to look at waveforms
Moved to cam sensor and found the inside of the connector to be quite soaked in oil, not sure how, it does face straight up. Cleaned up the connector and put a new Mopar cam sensor in.
Still having the same issue,
Next I may just go on to a ground connection cleaning. Its frustrating since its so intermittent, and may never happen during the warmer times of the year. This is my winter beater (which its great at being at) so I wanna find the issue, Ive gotten more than my moneys worth out of this car but cant part with it for some reason, been too good to me maybe in the 10 years Ive had it.
Its been near 50F outside the past couple days so my days of being able to crank/no-start and finding the culprit may be coming to an end this year. As it keeps starting fine.
This made me think coolant temp sensor or IAT sensor. I verified the coolant temp reading was accurate to ambient. Intake air temp wouldnt give me a number, I unplugged it and the car threw a code for it and battery light came on (only charging system at 13.5 volts) so it appears IAT sensor is at least doing something. Not sure if I should pursue that further. My sister has an 05 neon, so most things I can easily steal for an afternoon to verify any guesses I may have.
Grounds, or PCM is all I can think of now.
Last week, First try it didnt start, so I put a jumper cable from the neg battery terminal to a stud from the shock tower and it fired up fine, hard to say if that worked or was just a coincidence but Ill try it again or even during cranking with a helper. If I get the chance that is.
Anyway thats where Im at, just thought Id share this with you, and will update on anything new. I dont like firing new parts all over a problem, I really want to find the culprit.
2003 F-150 4.6L, 5 speed, PP 5w30
1962 Mercury Comet 200ci, Shell 15w40
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699301
03/19/18 03:34 AM
03/19/18 03:34 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Bad Battery....not enough CCA.
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699303
03/19/18 03:39 AM
03/19/18 03:39 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Even though you replaced fuel pump, I still suspect low fuel pressure. I would check it with a gauge to see what pressure is at during prime and running. May want to check power to the pump. The shot of either gives it away.
The "thinking" man's friend.
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699530
03/19/18 08:28 AM
03/19/18 08:28 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
I say the hot or cold sensor in the starter took a [censored]. Get another starter for it. I had that problem on a older Daytona once -- put in a new starter and it fixed it. The mechanic told me the cold sensor went out/died.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
QSHM 5W30 & FU (96K)
2000 Ram 4X4 5.9L (93K) PYB 10W30 & FU
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699552
03/19/18 08:50 AM
03/19/18 08:50 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I know the caravans develop bad grounds, so I would check there first. Check under the fuse box and battery.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699554
03/19/18 08:52 AM
03/19/18 08:52 AM
USA
mk378 Online content
mk378  Online Content
USA
There is no "cold sensor" in a starter.
The IAT is something that needs to be investigated more, it is important for cold starting.
Low compression makes an engine hard to start cold, though you would also have high oil consumption.
Re: Intermittent cold crank, no start 2001 Neon [Re: mk378] #4699567
03/19/18 09:08 AM
03/19/18 09:08 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
Maybe my mechanic said hot/cold solenoid? My problem was the starter and fixed when replacing with another starter.
Re: Intermittent cold crank, no start 2001 Neon [Re: BAJA_05] #4699573
03/19/18 09:18 AM
03/19/18 09:18 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Oh, you were being serious with your first post? crzy I think your mechanic was messing with you. There is no such thing as a hot/cold sensor or solenoid. And the OP says his car cranks over fine when it's cold, the engine just doesn't start. So his starter is working perfectly fine.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX - totaled
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699600
03/19/18 09:42 AM
03/19/18 09:42 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Idle air controller sticking, not allowing sufficient enrichment? Assuming you've checked the temp sensors as others have recommended.
Basically I'd say anything that can skew the mixture too lean for a cold start: MAP sensor, Throttle Position Sensor, IAC, coolant temp sensor, intake air temp sensor, low fuel pressure).
Speaking of low fuel pressure: does cycling the key to "ON" without cranking, and back to off, then "ON" without cranking 2-3 times before cranking it cause a start? That will run the fuel pump for 3-4 seconds every time you turn the key to "ON" and fully pressurize the fuel rail before you crank. If that makes it start reliably, then it may be a leaking injector O-ring that lets the fuel pressure bleed to zero overnight, and then not come up to pressure quickly enough for a normal start first thing on a cold morning.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699698
03/19/18 11:42 AM
03/19/18 11:42 AM
USA
zvm77us Offline
zvm77us  Offline
USA
Is there a check valve on the fuel lines that's letting fuel leak back to the tank? Next time throw a fuel gauge on the car before you start it when cold. OR put the car in the run position for a few seconds then start it, if it turns on it may be check valve issue.
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699699
03/19/18 11:43 AM
03/19/18 11:43 AM
NC
BigD1 Offline
BigD1  Offline
NC
I don't like throwing parts at problems, but if the fuel filter has not been changed in a long time I would change it.
From past experience, problems with electrical components/sensors usually malfunction when they are hot. Your problem is when it's cold, so it sounds like to me the fuel mixture is not rich enough/too lean to fire. Hard cold starts is a symptom of a faulty air charge temperature sensor.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: Intermittent cold crank, no start 2001 Neon [Re: exranger06] #4699746
03/19/18 12:37 PM
03/19/18 12:37 PM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
Sorry -- my bad!!! frown
Dale
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699925
03/19/18 03:32 PM
03/19/18 03:32 PM
Ontario, Canada
Ontario, Canada
Battery is good, couple months old. Same issue with the old battery
I'll try to get a means of checking the fuel pressure
Map sensor seems to be working, engine almost stalled when I unplugged it, it recovered and watching the o2 sensors it started running rich, both up and downstream went to 1 volt.
Throttle position sensor at idle says 12% and it does respond when moving the pedal.
IAC I haven't looked at, car does idle fine around 1200 at first then 800ish when warm, unless it does something while starting I'm unaware of
IAT, I may try a different one.
I have a gauge for compression testing so I'll see what the numbers are, although it doesn't consume any noticeable amount of oil over a 10k oci
Fuel filter is part of the fuel pump assembly, so it's new
Cycling the key before starting I've done in the past and it was no help.
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699941
03/19/18 03:51 PM
03/19/18 03:51 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
This is telling. Do you have a power probe? Grounds and IAT is where I would be looking first.
Re: Intermittent cold crank, no start 2001 Neon [Re: heyleescomet] #4699982
03/19/18 04:34 PM
03/19/18 04:34 PM
Ontario, Canada
Ontario, Canada
I feel the same Trav.
Compression test results, cold engine no time to warm it up, same number of turns for each, all sparks plugs out, throttle wide open. Only did it dry, no wet tests.
1-211psi
2-209psi
3-210psi
4-203psi
Seems good to me for a neon engine with 200k. Keep in mind this is the r/t engine with the magnum head and I think it has higher compression, not sure on the exact number though.
