CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
61 registered members (antik, 87sammy, Anthony, 2015_PSD, A1O, 7 invisible), 735 guests, and 27 spiders.
Topics287,674
Posts4,932,035
Members67,838
Most Online2,967
Mar 10th, 2019
2006 Acura TSX ATF D&F #4699185
03/18/18 10:11 PM
03/18/18 10:11 PM
MURICA
maverickfhs Offline OP
MURICA
Can anyone please correct me if I did something wrong in my D&F, I followed this procedure:
1- Drained old ATF ~2.5 quarts, added nearly 2.5 quart of ATF while car was on ramps.
2- Drove around the neighborhood, like for 5 mins in lower gears and speed. Drained another ~3.1 quarts and added almost ~3.2 quarts.
Now going to do another one in a week time frame.
Question is, did I overfill? Also, on '2' should I have driven at highway speeds for torque convertor or I should be fine?
Thanks for the help thumbsup
P.S: There's varying information about capacity on various forums, some say to add 3 quarts, some say 3L, some say 3.2-3.5 quarts and have even seen 2.5 quarts too frown
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699196
03/18/18 10:27 PM
03/18/18 10:27 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Sounds good to me.
Longer/faster may have been better to mix more but you are fine.
Is there no dipstick to check fluid level?
If not, adding same Amount you took out seems reasonable.
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699225
03/18/18 11:19 PM
03/18/18 11:19 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Your method works assuming the level was correct to begin with.
Is there a procedure you can use to determine the level? Remember that it probably needs to be checked while the fluid is warm.
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699234
03/18/18 11:31 PM
03/18/18 11:31 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
When I did my drain/refill on my Accord,it took exactly three quarts to get it to the top of the full mark on the dipstick. Do we have the same transmissions?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699410
03/19/18 08:05 AM
03/19/18 08:05 AM
midwest
JamesBond Offline
JamesBond  Offline
midwest
This all sounds fine. I usually measure what I take out then put that amount back in, but I use the dipstick to check the level also. Did you change the filter?
Re: 2006 Acura TSX ATF D&F [Re: JamesBond] #4699411
03/19/18 08:06 AM
03/19/18 08:06 AM
MURICA
MURICA
I didn't change the filter yet, question is how important it is?
Also, by any chance do you know Drain and Fill ATF quantity from manual or Acura/Honda?
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699449
03/19/18 08:29 AM
03/19/18 08:29 AM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Is... There ... No .... Dipstick?
01 Kymco People 50
95 Yamaha Jog
Re: 2006 Acura TSX ATF D&F [Re: Brybo86] #4699454
03/19/18 08:30 AM
03/19/18 08:30 AM
MURICA
MURICA
Yes, there's dipstick. But it was giving some misleading information yesterday. Maybe because I should have checked the level after a few hrs or when car was warm.
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699489
03/19/18 08:53 AM
03/19/18 08:53 AM
MURICA
MURICA
Seems like I slightly overfilled it(cap is 3 quarts), but will take care of it once I'll do the last flush: https://cardiagn.com/2004-automatic-transmissions-servicing-tsx/
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699501
03/19/18 09:01 AM
03/19/18 09:01 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Ive done 25 of these drop and fills in the past 13 years or so. My Honda/Acura 2.4L cars have always drained out about 2.5 to 2.75 quarts, never more than 3 quarts.
I put 2.5 quarts back in, drive it around for a bit, and then check using the dipstick. If its low, add a bit more. Its never above the full point putting 2.5 quarts in.
Dont forget to change the one time use aluminum crush washer. They are supposed to be changed every time you loosen the drain plug. Available on eBay or Amazon in ten packs for cheap.
Ive never changed a transmission filter, as Ive been told they are permanently mounted in the case and you have to dissemble the case to change it. Dont know if that's true or not, but as long as you keep good fluid in it, it will be fine. A drop and fill every 30K miles will keep your transmission fluid healthy. It actually takes me less time to change the transmission fluid than the engine oil, as its so quick and easy.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: 2006 Acura TSX ATF D&F [Re: bubbatime] #4699508
03/19/18 09:05 AM
03/19/18 09:05 AM
MURICA
MURICA
It means I am quite over, I guess? Should I be concerned or it can wait for a week for another drain and fill?
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699526
03/19/18 09:24 AM
03/19/18 09:24 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
What is the dip stick telling you today?
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
QSHM 5W30 & FU (100K)
2000 Ram 4X4 5.9L (93K) PYB 10W30 & FU
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699686
03/19/18 12:29 PM
03/19/18 12:29 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
A little over should be fine. The consensus is that 3 drain and fills changes a majority of the oil in the transmission. Waiting a week to change is fine. Then do one drain and fill every 30K miles once you have a baseline.
Re: 2006 Acura TSX ATF D&F [Re: maverickfhs] #4699936
03/19/18 04:43 PM
03/19/18 04:43 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
They designed the transmission with a filter so I suppose that it's important. With all of the grey paste that I've cleaned from magnets in transmission pans of other cars that I've serviced, I wouldn't want to leave all of that stuff in such a small filter. The filter probably sits on top of the transmission and is easy to change. Follow the transmission hoses from the radiator until you find the filter.
I don't know the normal drain and fill amount which is why I just measure what I take out.
