Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
72 registered members (Anduril, badduxx, bmwpowere36m3, ARCOgraphite, biodiesel, bbslider001, 8 invisible), 1,775 guests, and 55 spiders.
Topics296,775
Posts4,958,671
Members66,969
Most Online2,577
Jan 14th, 2019
BMW Coolant Leak Inside Bell Housing #4699041
03/18/18 06:59 PM
03/18/18 06:59 PM
Upper Midwest
kschachn Offline OP
kschachn  Offline OP
Upper Midwest
After truly believing that there was no further way for this car to have a coolant leak I was proven wrong yesterday. It has been leaking coolant onto the garage floor and yesterday I found it is coming from inside the bell housing between the engine and the transmission. Over the past few years I've replaced all 13 or so coolant hoses, the two transfer tubes under the intake manifold (and their o-rings), the rear coolant manifold, the valley pan, the electric water pump, the engine-driven water pump, the heater core, the heater core pipes through the instrument panel (all three of them), the electrically-controlled water valve, the radiator, the pressurized coolant tank (plus the cap, the level sensor and the two smaller hoses that connect to the radiator), the fan, the fan shroud and the viscous clutch. I didn't know anything was left but now due to this leak I have found there is a "cover" on the aft end of the engine inside the bell housing that commonly leaks. The gasket for the cover is a $4.03 part and is likely all that requires replacement.
Of course the transmission has to come out to replace the gasket which in and of itself isn't a horrible job on this car. The problem is going to be removing the forward exhaust system (two catalytic converters) where they meet the exhaust manifolds. The studs are rusted to oblivion and if they don't snap off during removal they will surely snap while trying to reinstall the exhaust pipes. This will likely require removal of the manifolds to repair, which is relatively easy on one side but very difficult on the other side. Not to mention that it's equally likely the studs in the head will break trying to remove the manifolds. I am not up to removing the heads on an M60 engine.
So this might be it for the old BMW. After thousands in repairs over the years and hundreds of hours of labor a $4 part is going to kill it off. The leak is pretty good so there's really no way I can ignore it and if it's like any of the other coolant leaks on this car it will only get worse with time. The gasket is #6 in the diagram below with the cover being #5. Even if the cover needs replacing too that's only about $60 more.
Oh and the engine driven water pump is leaking again and the bearing is starting to feel like gravel but hey, it's been about 100,000 miles so I guess I should expect that.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699051
03/18/18 07:08 PM
03/18/18 07:08 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
No way that something up front is leaking and running down the valley and out the bell housing?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699059
03/18/18 07:15 PM
03/18/18 07:15 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Is there a freeze plug on the back of the engine?
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699060
03/18/18 07:18 PM
03/18/18 07:18 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Sorry for your (coolant) loss.
Since you apparently have little to lose, and, assuming you dont get better suggestions, might be worth trying the GM ginger tabs?
This was suggested to me recently, but the leak "got better" and I forgot to ask the gf to bring some back from the UK, which I'll probably come to regret.
If you do try the job, candle wax on the studs is another trick I've never tried.
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699065
03/18/18 07:21 PM
03/18/18 07:21 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
I've heard this stuff works great for coolant leaks.
K-Seal
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive236K miles
PPHM 5w30 x 2 Fram Ultra x 2
Currently under the influence of oil shocked2
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699066
03/18/18 07:22 PM
03/18/18 07:22 PM
KY
MCompact Offline
MCompact  Offline
KY
I love BMW V8s when they are new- but I prefer the fours and sixes for long term ownership.
Although an E39 M5 is still a tempting proposition.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: BMW Coolant Leak Inside Bell Housing [Re: Chris142] #4699074
03/18/18 07:27 PM
03/18/18 07:27 PM
Upper Midwest
kschachn Offline OP
kschachn  Offline OP
Upper Midwest
No unfortunately. Because the engine is relatively short compared to the 6-cylinder you can see down on top of the bell housing between the intake manifold and the firewall. It is dry as a bone up there.
I can see the coolant dripping out of the bell housing and there's some inside if I put my finger in the hole. It's coming from inside.
1994 BMW 530i, 241K
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699079
03/18/18 07:29 PM
03/18/18 07:29 PM
Upper Midwest
kschachn Offline OP
kschachn  Offline OP
Upper Midwest
I found this video that shows even much newer engines apparently have the same general design and leaks:
1994 BMW 530i, 241K
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699083
03/18/18 07:32 PM
03/18/18 07:32 PM
Upper Midwest
kschachn Offline OP
kschachn  Offline OP
Upper Midwest
I thought about the coolant tabs and other leak stops, I might try it. It will surely clog up the electric heater valve but that could be bypassed.... I think...
It's leaking pretty good and anything that seals up this leak is probably going to seal up a few other things too.
1994 BMW 530i, 241K
Re: BMW Coolant Leak Inside Bell Housing [Re: tig1] #4699085
03/18/18 07:35 PM
03/18/18 07:35 PM
Upper Midwest
kschachn Offline OP
kschachn  Offline OP
Upper Midwest
I don't know. I haven't seen any freeze plugs on this engine, at least not any that are like the ones on cast iron blocks. Someone who I know mentioned that they seal up the boring passages with some kind of non-replaceable plug on the aluminum blocks.
1994 BMW 530i, 241K
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699152
03/18/18 08:21 PM
03/18/18 08:21 PM
Chris142 Offline
Chris142  Offline
I think I oukd not use a gasket. Clean it and dry it with brackleaner then use ultra grey.
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699153
03/18/18 08:21 PM
03/18/18 08:21 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I'm not a BMW guy, but is there any chance the exhaust could be cut off & welded back on (obviously by an experienced welder)? That sounds easier than dealing with all the rusted hardware (?)
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: BMW Coolant Leak Inside Bell Housing [Re: kschachn] #4699222
03/18/18 10:14 PM
03/18/18 10:14 PM
Under the hood
Carmudgeon Offline
Carmudgeon  Offline
Under the hood
Are you certain it's not the valley pan leaking again? The M6x V8s are notorious for leaks from the valley pan gasket.
Re: BMW Coolant Leak Inside Bell Housing [Re: MCompact] #4699581
03/19/18 09:22 AM
03/19/18 09:22 AM
Up State NY
SEMI_287 Offline
SEMI_287  Offline
Up State NY
Agreed, I'm on an active hunt for a low mileage one.
2005 BMW 325xi- M1 0w40, K&N
2004 Jetta TDI Wagon- Delo SM 5w40, STP.
2007 Chrysler 300C- M1 0w20, Wix
