Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
40 registered members (Bailes1992, billt460, A1O, Billbert, bbhero, 6 invisible), 643 guests, and 25 spiders.
Topics287,672
Posts4,932,028
Members67,838
Most Online2,967
Mar 10th, 2019
2016 Nissan Quest CVT drain and fill. #4698522
03/18/18 10:58 AM
03/18/18 10:58 AM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
I did another CVT fluid drain and fill on the van yesterday. Currently at ~52K miles. The last d/f was at 33K miles, just about a year ago and the drained fluid was very dark, almost black. I did two close succession d/f's then as we just bought the van as a previous rental.
Yesterday's drained fluid came out dark greenish, but not nearly as bad looking as a year ago. New Nissan NS-3 fluid is bright blue like windshield washer fluid.
I snapped a quick (horrible) pic of the cleanish white rag I used and a w/s washer fluid jug with the ~4qts that drained.
For those who own a Quest, Pathfinder or Murano, I wouldn't let it go more than 20-30K miles between CVT drain/fills. I just get the feeling I would have been lucky to make it to 100K miles had I left the factory juice in there. Drain/fills are easier than an engine oil change on these. The hardest part is getting the locking tab and O-ring to break free on the refill tube that resembles a dipstick tube.
I buy my Nissan NS-3 from eBay when I can get it for ~$10/qt shipped. Dealer cost is double that.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: 2016 Nissan Quest CVT drain and fill. [Re: JTK] #4698543
03/18/18 11:22 AM
03/18/18 11:22 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
Thanks for posting.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 2016 Nissan Quest CVT drain and fill. [Re: JTK] #4698603
03/18/18 12:21 PM
03/18/18 12:21 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
good idea. mine has been squeeling and I believe the new fluid may help. do you simply replace the exact amount you removed? the FSM calls for a procedure that requires (ideally) a scan tool to measure fluid temp...
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: 2016 Nissan Quest CVT drain and fill. [Re: JTK] #4698609
03/18/18 12:25 PM
03/18/18 12:25 PM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
FWIW, a guy over at the Nissan Maxima forums has a 2009 with 375,000 miles, and he changes the CVT fluid (NS2) every 75,000 miles. Still on the original transmission.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: 2016 Nissan Quest CVT drain and fill. [Re: tomcat27] #4698667
03/18/18 01:29 PM
03/18/18 01:29 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
That's how I do it. Drain it cold. What ever amount came out is the amount I replace. There's no way to get it wrong that way.
I have checked the level based on the FSM way I've read on the innerwebs, which is to have the van idling on a level surface with CVT fluid temps of ~98-113F. I just did it with the van fully warmed up, but not scorching hot in regards to fluid temps. Fluid should just dribble out of the level check plug under those conditions. Thank goodness most Nissans equipped with CVTs are easy enough to DIY.
I haven't worked up the courage to do my 2016 Forester CVT yet (currently 47K miles). The fill plug is in kind of a tough spot. I could rig it to fill I-V style with a long piece of tubing and small funnel, but I've got to see if I could get to and remove that fill plug first.
Re: 2016 Nissan Quest CVT drain and fill. [Re: JTK] #4698924
03/18/18 06:14 PM
03/18/18 06:14 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
I guess I'm lucky, our 11 Quest still has a regular dipstick!
The 11 takes NS-2 fluid.
I think I'm just going to do a drain and fill once a year going forward, I did 2 or 3 drain and fills last summer with the Amsoil CVT fluid. (had done a couple drain and fills with genuine Nissan NS-2 when we first got it at 46k) Just pulled the dipstick last week and the fluid looks practically new! The Amsoil fluid is more amber colored like motor oil vs the Nissan NS-2 which was green.
We should be due for an oil change in June, so I think I will do the CVT fluid at that time while I have it on the ramps.
It is nice that Nissan seems to make the maintenance reasonably easy to do, except for the back 3 spark plugs!
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
