Originally Posted By: bullwinkle
At least it's not the flooding carbureted, gas sucking, basically gutless slant 6! I had 3 of these-a '78 Aspen that looked almost as good as this one, a '78 Volare that was a rusted beater, and an '80 LeBaron wagon that I rebuilt a 225 for it and put in. All slower than molasses and lucky to get 13 MPG. Not the highlight of American auto tech, even for Mopar.
Hey that engine had a stout 90HP!
I don't know how you got only 13mpg, I got a solid 22 on the highway. Although my '74 with the 318 did get mid-teens.
OP, the only bad thing I know that's consistent on that year was the frame rails would rust out in the area just behind the engine/front wheel area. If this one doesn't have that rust (and from the one picture of the undercarriage from the rear it shouldn't) then it should be a solid car. As mentioned, the 318/torqueflite combo is pretty much bulletproof, you just might have to replace the alternator every 70000 miles and might need the occasional timing chain (replace with the correct aftermarket parts and these issues will go away)
Price seems a little high for me, but it IS a very well preserved example.
edit: OTOH after reading the entire post, it's a show car so should be in near-perfect condition.
